Home » Archived » Buckminster » Buckminster 3.4 headless subversion plugins AWOL
Buckminster 3.4 headless subversion plugins AWOL [message #385365] Thu, 14 May 2009 07:24 Go to next message
Douglas Palmer is currently offline Douglas PalmerFriend
Member
I am trying to install
org.eclipse.buckminster.subversive.headless.feature into buckminster
3.4. However I get a 404 message from
http://download.cloudsmith.com/buckminster/external/site.xml . Have the
svn plugins moved somewhere else or has support for them been dropped?
Doug
Re: Buckminster 3.4 headless subversion plugins AWOL [message #385366 is a reply to message #385365] Thu, 14 May 2009 08:24 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Oh, sorry. I accidentally built this repository using the 3.5 build. That makes it a pure P2 repository (i.e. no
site.xml, but content.jar and artifacts.jar instead). That doesn't play to well with the headless 3.4 installer since
it's built on the old update manager.
I'll fix this, hopefully during the day today.
Thomas Hallgren
Douglas Palmer wrote:
> Hi
> Regards
> Doug
Re: Buckminster 3.4 headless subversion plugins AWOL [message #385371 is a reply to message #385366] Fri, 15 May 2009 08:37 Go to previous messageGo to next message
Hi again,
Time ran out and I will not be able to attend to this for some days to come. You can however always use our archived sites.
http://download.cloudsmith.com/buckminster/archivedsites/
The last one built using 3.4:
http://download.cloudsmith.com/buckminster/archivedsites/buc kminster.externalsite-1.0.0.r09908.zip
should work well with a 3.4 environment.
Thomas Hallgren
> That makes it a pure P2 repository (i.e. no site.xml, but content.jar
> 3.4 installer since it's built on the old update manager.
> Regards,
> Thomas Hallgren
>> Hi
>> Regards
>> Doug
Re: Buckminster 3.4 headless subversion plugins AWOL [message #385374 is a reply to message #385371] Fri, 15 May 2009 09:27 Go to previous message
Member
Ok, thanks Thomas. I will use an archive until you can fix this.
Doug
> Hi again,
> Regards,
> Thomas Hallgren
>> headless 3.4 installer since it's built on the old update manager.
>> Regards,
>> Thomas Hallgren
>>> Hi
>>> the svn plugins moved somewhere else or has support for them been
>>> dropped?
>>> Regards
>>> Doug
Previous Topic:Online Bundle Repositories - springsource bundle repository
Next Topic:pattern definition for a matcher
Current Time: Wed Feb 05 04:05:01 GMT 2025
Powered by FUDForum. Page generated in 0.03832 seconds
