Home » Archived » GMT (Generative Modeling Technologies) » Re: oaw: Error in xtend-Editor
Re: oaw: Error in xtend-Editor [message #375578] |
Wed, 25 October 2006 03:59  |
Dear Tobias,
Could you ask your question on the new GMT newsgroup:
news://news.eclipse.org/eclipse.modeling.gmt ?
The newsgroup eclipse.technology.gmt will be closed and archived soon.
Freddy.
Tobias Buhr a écrit :
> Hi all,
> I've got a problem with the eclipse xtend-editor, it says me there is an
> error:
> "Couldn't find operation 'createTypeDeclaration(uml::String,Boolean)'
> for type 'jast::CompilationUnit'"
> but when starting the worklflow it works. Problem is that the types
> uml::String and the builtin String are not identical.
> Here is the code-snippet:
> create CompilationUnit this createCompilationUnit(uml::Class c):
> this.types.add(createTypeDeclaration(c.name,false));
> create TypeDeclaration this createTypeDeclaration(String name, Boolean
> isInterface):
> this.setTypeName(createSimpleName(name)) ->
> this.setInterface(isInterface);
> What to do?
> Thanks, Tobias
Re: oaw: Error in xtend-Editor [message #375581 is a reply to message #375578] |
Wed, 25 October 2006 06:40   |
Hi Tobias,
the Xtend component needs to be configured with the UML2Metamodel
adapter, which maps the uml types (e.g. uml::String) to the datatypes
used in the oaw typesystem.
See the reference documentation
http://www.eclipse.org/gmt/oaw/doc/4.1/r50_uml2AdapterRefere nce.pdf
If this doesn't help, please post the workflow description.
regards,
Sven
>> Hi all,
>> error:
>> isInterface):
>> What to do?
>> Thanks, Tobias
Re: oaw: Error in xtend-Editor [message #375584 is a reply to message #375581] |
Wed, 25 October 2006 09:39   |
Originally posted by: tobiasbuhr.gmx.de
Sven Efftinge schrieb:
> Hi Tobias,
Hi Sven,
thanks for the advice, I didn't notice that document before.
However, the error still occurs in the editor.
Remark, that when executing the workflow everyting is goes fine.
What I've done:
- included the profiles from org.eclipse.uml2.uml.resources/profiles
(would these profiles be the right ones?)
- added UML2 profile support in the oaw-preferences page
- I tried to adapt my workflow file, but the way it is written down in
the document stated above, it doesn't work (I think the worklow is only
important for executing and not for the xtend-editor, is this assumption
right?)
Relevant part of the workflow:
<component id="t1" class="org.openarchitectureware.xtend.XtendComponent">
<metaModel id="mm_uml2"
class="org.openarchitectureware.type.emf.EmfMetaModel">
<metaModelPackage value="org.eclipse.uml2.uml.UMLPackage"/>
</metaModel>
<metaModel id="mm_mymodel"
<metaModelPackage value="myModel.MyModelPackage"/>
</metaModel>
<metaModel id="mm_ecore"
<metaModelPackage value="org.eclipse.emf.ecore.EcorePackage"/>
</metaModel>
<invoke value="templates::myTemplate::transform(model)"/>
<outputSlot value="transformed_model"/>
</component>
Best regards, Tobias
Re: oaw: Error in xtend-Editor [message #560410 is a reply to message #375578] |
Hi Tobias,
regards,
Sven
>> Hi all,
>> error:
>> isInterface):
>> What to do?
>> Thanks, Tobias
Re: oaw: Error in xtend-Editor [message #560417 is a reply to message #375581] |
> Hi Tobias,
Hi Sven,
What I've done:
right?)
</metaModel>
</metaModel>
</metaModel>
</component>
Current Time: Wed Apr 16 09:02:36 EDT 2025
Powered by FUDForum. Page generated in 0.04770 seconds
