Home » Archived » Service Oriented Architecture Tools Platform (STP) » STP BPMN Modeler Message FLow connection with pools
STP BPMN Modeler Message FLow connection with pools [message #374080] |
Fri, 22 June 2007 10:13 |
Originally posted by: hoppechristian.gmx.net
Hi there,
I've tested the STP BPMN Modeler and noticed that it isn't possible to
conect Messageflow Elemnts with Pools (it's only possible to connect
with them with activities). Will you provide the possibility to connect
with pools in future?
Re: STP BPMN Modeler Message FLow connection with pools [message #374081 is a reply to message #374080] |
Fri, 22 June 2007 18:00 |
Originally posted by: atoulme.intalio.com
Hi Christian,
yes, we will do it as we want to be specification compliant.
Now, it's not very high on the todo list. Drawing messaging edges
between activities already cover the most common cases to our
understanding, and doing this modification is going to change the
semantic model a bit.
I would be personally interested in knowing how you use messaging edges
between pools?
Antoine
Christian Hoppe wrote:
> Hi there,
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: STP BPMN Modeler Message FLow connection with pools [message #374107 is a reply to message #374105] |
Tue, 03 July 2007 18:13 |
Aurelien,
as I stated before, this i not currently implemented.
Please file a bug against us regarding this issue so that we can keep
track of it.
Antoine
Aurélien MOREAU wrote:
> I have the same problem. I would like connect a message connection
> with a pool to avoid having to expose the behavior of a participant. Can
> I simulate this use with current bpmn model ?
> Thank you.
> Aurélien
> Antoine Toulme wrote :
>> Hi Christian,
>> edges between pools?
>> Antoine
>>> Hi there,
>>> to conect Messageflow Elemnts with Pools (it's only possible to
>>> connect with them with activities). Will you provide the possibility
>>> to connect with pools in future?
Re: STP BPMN Modeler Message FLow connection with pools [message #374111 is a reply to message #374107] |
Wed, 04 July 2007 08:52 |
Aurélien Moreau Messages: 11 Registered: July 2009 |
Bug 195349
Antoine Toulme a écrit :
> Aurelien,
> track of it.
> Regards,
> Antoine
>> Hi,
>> Can I simulate this use with current bpmn model ?
>> Thank you.
>> Aurélien
>>> Hi Christian,
>>> Antoine
>>>> Hi there,
Re: STP BPMN Modeler Message FLow connection with pools [message #589406 is a reply to message #374080] |
Hi Christian,
between pools?
Antoine
> Hi there,
Re: STP BPMN Modeler Message FLow connection with pools [message #589603 is a reply to message #374105] |
Aurelien,
track of it.
Antoine
> Thank you.
> Aurélien
>> Hi Christian,
>> Antoine
>>> Hi there,
Re: STP BPMN Modeler Message FLow connection with pools [message #589640 is a reply to message #374107] |
Bug 195349
> Aurelien,
> track of it.
> Regards,
> Antoine
>> Hi,
>> Thank you.
>> Aurélien
>>> Hi Christian,
>>> Antoine
>>>> Hi there,
Current Time: Sat Oct 19 16:04:02 GMT 2024
Powered by FUDForum. Page generated in 0.04139 seconds
