Home » Archived » BIRT » Wrong results in crosstab
Wrong results in crosstab [message #334011] Mon, 28 January 2008 13:43 Go to next message
Hans is currently offline HansFriend
Hi people,
I have a crosstab that shows some summarized fields, (A, B, C), when I
preview the results (at preview's tab), all goes fine, but viewing the
results in xls or web viewer, it results in strange data. The C field
shows strange numbers, very very big numbers. I have tried with a new
report file, but happens the same problem.
Any ideas?
Hans.
Re: Wrong results in crosstab [message #340736 is a reply to message #334011] Mon, 28 January 2008 13:51 Go to previous messageGo to next message
I forgot to add that I have two crosstabs. The problem happens sometimes
in first crosstab and other times it happens in the second crosstab
Hans escribió:
> Hi people,
> I preview the results (at preview's tab), all goes fine, but viewing the
> Any ideas?
> Hans.
Re: Wrong results in crosstab [message #340737 is a reply to message #334011] Mon, 28 January 2008 14:00 Go to previous messageGo to next message
Originally posted by: tigeleo.yahoo.com
Hans ?????:
> Hi people,
> Any ideas?
> Hans.
May be you display rowid or time in milliseconds
Re: Wrong results in crosstab [message #346298 is a reply to message #340737] Mon, 28 January 2008 14:19 Go to previous messageGo to next message
Nope, and after a many crazy things, I can fix the problem. The solution
was to change all the report parameters to String. I've never had this
problem with crosstabs, indeed, I've worked with a template with the
same report parameters and same crosstabs, it's the first time that I
see this strange behaviour. Could be a bug?
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> when I preview the results (at preview's tab), all goes fine, but
>> viewing the results in xls or web viewer, it results in strange data.
>> The C field shows strange numbers, very very big numbers. I have tried
>> with a new report file, but happens the same problem.
>> Any ideas?
>> Thanks,
>> Hans.
Re: Wrong results in crosstab [message #346373 is a reply to message #340737] Mon, 28 January 2008 14:19 Go to previous messageGo to next message
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
Re: Wrong results in crosstab [message #350666 is a reply to message #340737] Mon, 28 January 2008 14:19 Go to previous messageGo to next message
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
Re: Wrong results in crosstab [message #359558 is a reply to message #346298] Tue, 29 January 2008 01:42 Go to previous message
Tianli Zhang is currently offline Tianli ZhangFriend
Hi Hans
Where did you use the parameters? Is the result strange only in XSL and
Web Viewer and it is ok in layout preview?
Re: Wrong results in crosstab [message #359633 is a reply to message #346298] Tue, 29 January 2008 01:42 Go to previous message
Hi Hans
Re: Wrong results in crosstab [message #359708 is a reply to message #346373] Tue, 29 January 2008 01:42 Go to previous message
Hi Hans
Previous Topic:Wrong results in crosstab
Next Topic:Wrong results in crosstab
Current Time: Thu Jan 30 02:17:59 GMT 2025
Powered by FUDForum. Page generated in 0.04381 seconds
