Setting parameters via API [message #339809] |
Thu, 24 January 2008 21:53 |
Originally posted by: pmills.systemcore.ca
I'm missing something that I suspect must be obvious. Using the report
engine API, I have no problem running and rendering a report. I also see
calls to find out all kinds of information about report parameters through
the IGetParameterDefinitionTask. What I don't see is the mechanism for
setting a parameter.
Let's say I schedule a report to run every Sunday night to calculate the
past week's activity. In my scheduler code (Java), I know the start and
end times, which I want to map to '?' parameters in my SQL. What chain of
events has to happen?
Re: Setting parameters via API [message #345069 is a reply to message #339809] |
Thu, 24 January 2008 23:13 |
Originally posted by: jasonweathersby.alltel.net
Phillip,
In the report engine api the run task and the runandrendertask have
methods that use task.setParameterValue(s)
either use task.setParameterValue(parmname, parmvalue)
task.setParameterValues(parmmap);
IGetParameterDefinitionTask is used to get parameter info, primarily to
build user entry dialogs.
Jason
Re: Setting parameters via API [message #345144 is a reply to message #339809] |
Phillip,
Jason
Re: Setting parameters via API [message #349132 is a reply to message #339809] |
Phillip,
Jason
Re: Setting parameters via API [message #349208 is a reply to message #339809] |
Phillip,
Jason
Re: Setting parameters via API [message #357570 is a reply to message #345069] |
Fri, 25 January 2008 13:46 |
Thanks! I'll have a look in that direction.
(A "BIRT Cookbook" would be wonderful. There's a big contrast between the
helpfulness of the report design tutorials and the bare API listings in the
programming sections of Eclipse help books.)
Re: Setting parameters via API [message #357645 is a reply to message #345069] |
Re: Setting parameters via API [message #357720 is a reply to message #345144] |
Re: Setting parameters via API [message #357795 is a reply to message #345144] |
FUDForum. Page generated in 0.04942 seconds
