Home » Modeling » M2T (model-to-text transformation) » EMF Iterate through an String array
- EMF Iterate through an String array [message #32443] Wed, 05 September 2007 11:25 Go to next message
Hi again,
I've been stuck on a problem even I know that the solution must be simple.
How can I iterate on a attribute of a class which is a String array to get
all the values from this array ?
I tried
<c:iterate select="$myClass/@myStringArray" var="myValue">
<c:get select="$myValue" />
</c:iterate>
but this only gets me the 1st value of the array.
Thank,
regards,
Tex
- Re: EMF Iterate through an String array [message #32548 is a reply to message #32443] Thu, 06 September 2007 05:03 Go to previous messageGo to next message
more details about my question. This is a part of my xmi EMF model:
<rooms name="idRoom">
<compartments>A</compartments>
<compartments>B</compartments>
<compartments>C</compartments>
<compartments>D</compartments>
</rooms>
All I want is to iterate through the "compartments" of the current "room"
access the A, B .. compartments. It's seems quite easy but I'm stuck. I
tried
$currRoom/child::compartments
but it doesn't seem to work.
"Tex Twil" <chaljan@hotmail.com> a écrit dans le message de
news:fbmhp2$7ph$1@build.eclipse.org...
> Hi again,
> I tried
> </c:iterate>
> Thank,
> regards,
> Tex
- Re: EMF Iterate through an String array [message #32616 is a reply to message #32548] Thu, 06 September 2007 07:04 Go to previous messageGo to next message
This was my first try but it doesn't work
<c:iterate select="$currRoom/compartments" var="currCompartment" >
<c:get select="$currCompartment" />
</c:iterate>
I realized that if I write an "@" in <c:iterate
select="$currRoom/@compartments" var="currCompartment" > I access the value
of the first compartment i.e. "A".
Tex
news:fbofon$1m7$1@build.eclipse.org...
> </rooms>
> tried
> Thanks
>> Hi again,
>> simple. How can I iterate on a attribute of a class which is a String
>> array to get all the values from this array ?
>> I tried
>> </c:iterate>
>> Thank,
>> regards,
>> Tex
- Re: EMF Iterate through an String array [message #32752 is a reply to message #32616] Thu, 06 September 2007 08:22 Go to previous messageGo to next message
Tex:
I wouldn't be surprised if JET does not handle attribute arrays properly.
Please submit a defect:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org
Paul
"Tex Twil" <chaljan@hotmail.com> wrote in message
news:fbomrm$csc$1@build.eclipse.org...
> </c:iterate>
> value of the first compartment i.e. "A".
> Thanks
> Tex
- Re: EMF Iterate through an String array [message #32921 is a reply to message #32752] Thu, 06 September 2007 09:44 Go to previous messageGo to next message
it seems that a string array is stored in a xmi file as I wrote before i.e.
myClass
String name
String[] myArray
An instance of this class is stored in xmi:
<myClass name="This is my class">
<myArray>A</myArray>
<myArray>B</myArray>
<myArray>C</myArray>
</myClass>
So it should be possible to iterate through those <myArray> to get the
values. (see my other posts) :)
Tex.
"Paul Elder" <pelder@ca.ibm.com> a écrit dans le message de
news:fborgc$lms$1@build.eclipse.org...
> Tex:
> Paul
>> </c:iterate>
>> Thanks
>> Tex
>>> Hi,
>>> </rooms>
>>> "room" access the A, B .. compartments. It's seems quite easy but I'm
>>> stuck. I tried
>>> Thanks
>>>> Hi again,
>>>> I tried
>>>> </c:iterate>
>>>> Thank,
>>>> regards,
>>>> Tex
- Re: EMF Iterate through an String array [message #33024 is a reply to message #32921] Thu, 06 September 2007 11:06 Go to previous messageGo to next message
Tex:
But JET does not read the XMI file, EMF does. What JET sees is EObjects and
their corresponding EMF metadata (EClasses, EReferences and EAttributes).
JET has no idea how the model was represented on disk. It could be an XMI
file, as in your case, a relational data base (which you can do with Teneo),
or any number of other possibilities.
JET is attempting to map EReferences to XPath Elements, and EAttributes to
XPath Attributes. But, XPath does not have a concept of arrays, and so, an
Attribute that is an array is a problem. The only 'fix' I can imagine is, on
finding an array is to treat is like an XPath Element. I will investigate.
In the meantime, if you want to make progress with the way JET is currently
implemented, I can suggest the following work arounds (all involve modifying
your Ecore meta-model).
1) Instead of using arrays of simple types (e.g. String), create an EClass
to represent the object, have it define an attribute for the value, and then
create a multi-valued, containment EReference instead of an EAttribute
array.
2) If you are familiar with the EMF annotations for XML Schema, you may be
able to add the right annotations to get JET to look at the EAttribute as a
'simple' Element.
An example. I can describe your myClass example as the attached
texschema.xsd XML Schema.
If you create an EMF Project from this schema, you get a ECore model like
the attached texschema.ecore. In particular, not that the myArray attribute
has an ExtendedMetaData annotation that indicates that the attribute is to
be treated as an XML element. JET understands these. You may be able to just
hack one of these into your ECore model, and JET will magically understand
that the array attribute should be treated as an XPath element. (I say 'may'
because, I'm not sure whether EMFs extended meta data mechanism works if
there isn't extended metadata attached to the EPackage itself. My theory is
you could get away with just by hacking in the following annotation:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="myArray"
unique="false"
upperBound="-1" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String">
<!-- start of hack --!>
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="element"/>
</eAnnotations>
<!-- end of hack --!>
</eStructuralFeatures>
Paul
news:fbp078$q5v$1@build.eclipse.org...
> i.e.
> myClass
> String name
> String[] myArray
> </myClass>
> Tex.
- Re: EMF Iterate through an String array [message #33096 is a reply to message #33024] Thu, 06 September 2007 11:11 Go to previous messageGo to next message
Forgot the attach the texschema.ecore model.
Here it is.
Paul
- Re: EMF Iterate through an String array [message #33166 is a reply to message #33024] Thu, 06 September 2007 11:34 Go to previous messageGo to next message
Thank you Paul,
I understand the problem better now.
I will try those solutions and let you know.
regards,
Tex
news:fbp53h$tig$1@build.eclipse.org...
> Tex:
> and their corresponding EMF metadata (EClasses, EReferences and
> EAttributes). JET has no idea how the model was represented on disk. It
> could be an XMI file, as in your case, a relational data base (which you
> can do with Teneo), or any number of other possibilities.
> on finding an array is to treat is like an XPath Element. I will
> investigate.
> currently implemented, I can suggest the following work arounds (all
> involve modifying your Ecore meta-model).
> then create a multi-valued, containment EReference instead of an
> EAttribute array.
> a 'simple' Element.
> attribute has an ExtendedMetaData annotation that indicates that the
> attribute is to be treated as an XML element. JET understands these. You
> may be able to just hack one of these into your ECore model, and JET will
> magically understand that the array attribute should be treated as an
> XPath element. (I say 'may' because, I'm not sure whether EMFs extended
> meta data mechanism works if there isn't extended metadata attached to the
> EPackage itself. My theory is you could get away with just by hacking in
> unique="false"
> <eAnnotations
> </eAnnotations>
> Paul
>> Hi,
>> i.e.
>> myClass
>> String name
>> String[] myArray
>> </myClass>
>> Tex.
>>> Tex:
>>> properly.
>>> Paul
>>>> </c:iterate>
>>>> Thanks
>>>> Tex
>>>>> Hi,
>>>>> </rooms>
>>>>> stuck. I tried
>>>>> Thanks
>>>>>> Hi again,
>>>>>> I tried
>>>>>> </c:iterate>
>>>>>> Thank,
>>>>>> regards,
>>>>>> Tex
- Re: EMF Iterate through an String array [message #33237 is a reply to message #33024] Fri, 07 September 2007 04:55 Go to previous messageGo to next message
Hi Paul,
I'm not really familiar with EMF annotations for XML , nevertheless, I tried
your second solution.
I tried your "hack" and I attached an EAnnotation only to the myArray
attribute (kind -> element)
When I derive the ecore to the genmodel and then generate the Model code I
have some compilation errors, some of them saying that
org.eclipse.emf.ecore.xmi cannont be resolved.
When I do the same wih your attached ecore (where the EAnnotations are
everywhere) I don't have those errors. What am I doing wrong ?
regards,
Tex.
> Tex:
> investigate.
> EAttribute array.
> a 'simple' Element.
> unique="false"
> <eAnnotations
> </eAnnotations>
> Paul
>> Hi,
>> i.e.
>> myClass
>> String name
>> String[] myArray
>> </myClass>
>> Tex.
>>> Tex:
>>> properly.
>>> Paul
>>>> </c:iterate>
>>>> Thanks
>>>> Tex
>>>>> Hi,
>>>>> </rooms>
>>>>> stuck. I tried
>>>>> Thanks
>>>>>> Hi again,
>>>>>> I tried
>>>>>> </c:iterate>
>>>>>> Thank,
>>>>>> regards,
>>>>>> Tex
- Re: EMF Iterate through an String array [message #33307 is a reply to message #33237] Fri, 07 September 2007 08:30 Go to previous messageGo to next message
Tex:
Well, I'm not exactly sure what's going wrong :-)
You are getting Java compilation errors, so the first thing I would do is
compare the dependencies of the two plug-ins.
Paul
news:fbr3mf$bb5$1@build.eclipse.org...
> Hi Paul,
> tried your second solution.
> regards,
> Tex.
- Re: EMF Iterate through an String array [message #35534 is a reply to message #32443] Tue, 06 November 2007 23:34 Go to previous messageGo to next message
I have also hit this same bug. Does anybody know if this has been reported
as an issue, if there is a fix, one itwill come through. This is a serious
glitch! How many metamodels do not use multiplity many attributes? Very few,
I presume ...
> Hi again,
> I tried
> </c:iterate>
> Thank,
> regards,
> Tex
- Bug: Values of Multiplicity Many attribute ignored in EMF to JET mapping [message #35568 is a reply to message #35534] Tue, 06 November 2007 23:43 Go to previous messageGo to next message
description:
For a multiplicity-many eAttribute attr of an instance of eClass class, with
any number of entries above one, the following xpath expression ALWAYS
results in 1, when it should provide the number of attribute nodes.
<c:get select="count($instance/@attr)"/>
This also means that iteration over the ignored nodes is not possible.
"J
- Re: Values of Multiplicity Many attribute ignored in EMF to JET mapping [message #35601 is a reply to message #35568] Wed, 07 November 2007 01:12 Go to previous message
Further, you can observe that the bug is in the model loader, as any
<c:dump select="$instance"/>
will only show the first value.
"J
Previous Topic:Re: [JET] Switching on eClass()
Next Topic:Bug: Values of Multiplicity Many attribute ignored in EMF to JET mapping
Current Time: Tue May 13 21:06:51 EDT 2025
Powered by FUDForum. Page generated in 0.05257 seconds
