Home » Archived » BIRT » Wrong results in crosstab
Wrong results in crosstab [message #328861] |
Mon, 28 January 2008 13:43 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hans![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=st.hanxxx%40gmail.com) Messages: 2662 Registered: July 2009 |
Hi people,
I have a crosstab that shows some summarized fields, (A, B, C), when I
preview the results (at preview's tab), all goes fine, but viewing the
results in xls or web viewer, it results in strange data. The C field
shows strange numbers, very very big numbers. I have tried with a new
report file, but happens the same problem.
Any ideas?
Hans.
Re: Wrong results in crosstab [message #339386 is a reply to message #328861] |
Mon, 28 January 2008 13:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I forgot to add that I have two crosstabs. The problem happens sometimes
in first crosstab and other times it happens in the second crosstab
Hans escribió:
> Hi people,
> I preview the results (at preview's tab), all goes fine, but viewing the
> Any ideas?
> Hans.
Re: Wrong results in crosstab [message #339387 is a reply to message #328861] |
Mon, 28 January 2008 14:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: tigeleo.yahoo.com
Hans ?????:
> Hi people,
> Any ideas?
> Hans.
May be you display rowid or time in milliseconds
Re: Wrong results in crosstab [message #339461 is a reply to message #328861] |
Hans escribió:
> Hi people,
> Any ideas?
> Hans.
Re: Wrong results in crosstab [message #339462 is a reply to message #328861] |
Hans ?????:
> Hi people,
> Any ideas?
> Hans.
Re: Wrong results in crosstab [message #344491 is a reply to message #339387] |
Mon, 28 January 2008 14:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nope, and after a many crazy things, I can fix the problem. The solution
was to change all the report parameters to String. I've never had this
problem with crosstabs, indeed, I've worked with a template with the
same report parameters and same crosstabs, it's the first time that I
see this strange behaviour. Could be a bug?
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> when I preview the results (at preview's tab), all goes fine, but
>> viewing the results in xls or web viewer, it results in strange data.
>> The C field shows strange numbers, very very big numbers. I have tried
>> with a new report file, but happens the same problem.
>> Any ideas?
>> Thanks,
>> Hans.
Re: Wrong results in crosstab [message #344566 is a reply to message #339387] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
Re: Wrong results in crosstab [message #344642 is a reply to message #339462] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
Re: Wrong results in crosstab [message #348630 is a reply to message #339462] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
Current Time: Sun Sep 01 12:47:43 GMT 2024
Powered by FUDForum. Page generated in 0.06028 seconds
