Re: Eclipse freezes after stopping at breakpoint in a static block [message #336812 is a reply to message #336796] |
Fri, 03 July 2009 18:27 |
Originally posted by: eclipse-news.rizzoweb.com
Thomas Wiedmann wrote:
> Hello,
> trying to debug code written in Java 5 I set a breakpoint within a
> static block like
> static {
> x Java statements
> The x indicates the breakpoint. Debugging the application it really
> stopped at the breakpoint and for a short moment I could even see the
> stacktrace of the thread. Afterwards - without any further interaction -
> the screen became white and Eclipse hang. There was no chance to access
> Eclipse in order to continue the debug run.
> What may be the reason for this behaviour, which I only observed with
> the breakpoint the static block, or how can the cause be determined?
> How can it be avoided, that Eclipse suddenly hangs after stopping at the
> breakpoint?
> I work with Eclipse 3.4.2.
I tried to reproduce this in both 3.4.2 and 3.5 but it works just fine.
Can you provide more detailed steps to reproduce it?
Some information that would be useful:
What OS are you using? What JVM? Have you specified in eclipse.ini what
JVM it should use?
Eric
FUDForum. Page generated in 0.03245 seconds
