Home » Eclipse Projects » Eclipse Platform » disable use of socks proxy in 3.5
disable use of socks proxy in 3.5 [message #336516] Thu, 18 June 2009 09:52 Go to next message
is there a way of disabling the use of the socks proxy in eclipse 3.5?
I'm not able to do this in the prefs gui, and I think the proxy I'm behind
only offers http/https (I get a java.net.SocketException: Malformed reply
from SOCKS server).
Thx,
Jens
Re: disable use of socks proxy in 3.5 [message #336520 is a reply to message #336516] Thu, 18 June 2009 13:11 Go to previous messageGo to next message
Jens wrote:
> behind only offers http/https (I get a java.net.SocketException:
> Malformed reply from SOCKS server).
"not about to do this in the prefs" ... you mean you can't find the
prefs, or when you change the SOCKS pref it does nothing?
The network connection prefs are in "Preferences>General>Network
Connections"
PW
Paul Webster
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: disable use of socks proxy in 3.5 [message #336549 is a reply to message #336520] Mon, 22 June 2009 07:36 Go to previous messageGo to next message
OK, in 3.4.2 I took "System proxy configuration" and it works. In 3.5,
(20090611-1022) using either the "native" or manual provider does not
work. My assumtion was that this comes from trying to use the given proxy
as a socks proxy (which I think is not possible for the proxy here).
So I was seeking a way of disabling the use of the socks proxy. But the
checkboxes in the "Network Connections" Preferences are only changeable by
the choose of an "Active provider".
Hope this makes it clearer...
Re: disable use of socks proxy in 3.5 [message #336551 is a reply to message #336549] Mon, 22 June 2009 08:44 Go to previous messageGo to next message
If this is not working for you properly, please open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=Team
PW
Paul Webster
Re: disable use of socks proxy in 3.5 [message #336620 is a reply to message #336551] Thu, 25 June 2009 08:42 Go to previous messageGo to next message
does a bug have been filled for this issue? I searched on bugzilla but
found nothing. If not, I will.
I have the same problem problem here: I can't connect anymore to internet
through my proxy in eclipse 3.5.
thanks,
Gildas
> PW
Re: disable use of socks proxy in 3.5 [message #336622 is a reply to message #336620] Thu, 25 June 2009 09:34 Go to previous messageGo to next message
I had the same pb with a proxy which refuse sockets, but It's work for me
now.
In Network Connections, with "Manual" for Active Provider, I can desactive
the SOCKS with the button "Clear" (the checkbox is always checked) but the
fields (Host, Port, Auth, User) are empty, and now, I can install new
software from network behind the proxy.
Re: disable use of socks proxy in 3.5 [message #336637 is a reply to message #336620] Thu, 25 June 2009 12:19 Go to previous messageGo to next message
we have the similar problem here..
No update sites found when behind a proxy ( the proxy here ).
Switching to manual and clearing the socks proxy didn't help.
I described our case here
http://www.eclipse.org/newsportal/article.php?id=81774&g roup=eclipse.platform#81774
Ivan
Re: disable use of socks proxy in 3.5 [message #336642 is a reply to message #336620] Thu, 25 June 2009 15:17 Go to previous messageGo to next message
Gildas Guillemot wrote:
> internet through my proxy in eclipse 3.5.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281472
Make sure that you monitor this bug, as descriptions of the problem and
potential work arounds will be posted there.
PW
Paul Webster
Re: disable use of socks proxy in 3.5 [message #336655 is a reply to message #336551] Fri, 26 June 2009 02:56 Go to previous messageGo to next message
> PW
I found a bug for this issue:
A hint in the bug description did the trick for me:
http://wiki.eclipse.org/ECF_Filetransfer_Support_for_NTLMv2_ Proxies
Jens
Re: disable use of socks proxy in 3.5 [message #789990 is a reply to message #336622] Fri, 03 February 2012 12:04 Go to previous messageGo to next message
I had the same problem in Eclipse 3.7. We're behind a firewall. I had put proxy settings in for HTTP, HTTPS, and SOCKS, but couldn't download anything. When I removed the SOCKS proxy setting using the Clear button, it started working. This should be documented for the user in a more obvious spot than an obscure forum. No one except the developers of Eclipse know (or care) what SOCKS is. Bleah.
Re: disable use of socks proxy in 3.5 [message #991515 is a reply to message #336516] Wed, 19 December 2012 11:15 Go to previous message
just as previous mentioned here, I deactivated SOCKS by hitting the "Clear" button, and then it started to work fine. Smile
Previous Topic:Eclipse 4.2 Garbled Text while scrolling
Next Topic:How to Run an invisible Workbench
Current Time: Tue Mar 11 13:13:10 EDT 2025
Powered by FUDForum. Page generated in 0.04311 seconds
