Re: Dynamic changes to a wizard page [message #336252 is a reply to message #336248] |
Wed, 03 June 2009 16:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: eclipse-news.rizzoweb.com
Andy wrote:
> Hi everyone,
> I have a wizard with a few pages in it and I am trying to dynamically
> change the contents of a page based on the inputs of the previous page.
> The issue I am having is how do you do this? createControl is only
> called once at the beginning of the creation of the wizard, which
> doesn't help because it isn't known at that time what the page will look
> like. In essence all I want to do is have a textbox on one page allow
> you to enter a number and then show that number of textboxes on the next
> page. Should be simple, right?
It seems like you could, in the page's createControl() method, just
create an empty Composite to hold the widgets, but not actually create
the Text widgets. Then override setVisible(boolean) on the page and in
there figure out how many widgets you need and create them.
I've used IDialogPage.setVisible(boolean) in a similar way before
(basically, I needed to enable/disable or show/hide parts of a page
based on the model state gathered on the previous page).
Hope this helps,
Eric
Re: Dynamic changes to a wizard page [message #336261 is a reply to message #336257] |
Thu, 04 June 2009 06:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: aurelien.pupier.esial.net
answer below
Andy a écrit :
> Thanks for the input. I tried adding
> public void setVisible(boolean visible){
> super.setVisibile(visible)
> new Label(composite, SWT.NONE).setText("Do you see this");
> in my WizardPage, but it didn't seem to display it to the WizardPage.
> The only contents I saw were the ones that were added during the
> createControl method. I put a print statement in and setVisible is
> indeed being called. Also, composite is a class level variable and was
> instantiated in createControl.
> Is there some kind of forced refresh of the page that I need to do at
> the end of setVisible?
Yes, I think that you have to do a .layout(true) on your parent composite.
> Andy
FUDForum. Page generated in 0.02573 seconds
