Home » Eclipse Projects » Eclipse Platform » New databinding idiom
| New databinding idiom [message #335780] |
Wed, 29 April 2009 09:26  |
Originally posted by: gaston.tonietti.teracode.com
Hi all,
I've seen here: http://fire-change-event.blogspot.com/ some databinding
examples using new API from 3.5 builds, and I liked it too much.
So the question is, if I want to migrate my old databinding code to the new
style, where can I start reading some documentation?
Maybe a migration path or an old/new comparative table or any other kind of
documentation about the new way of doing databinding.
Thanks a lot.
Gaston.
| Re: New databinding idiom [message #335784 is a reply to message #335782] |
Wed, 29 April 2009 14:06   |
I understand it is more an API extension than a replacement, so it is just
as you said, I want to use it when possible as I like it more.
I'm not concerning with viewers that much as I have a few views (one tree
and some tables) but I will take a look at ViewerSupport for sure since it
seems very powerful.
My main concern is for forms, I make extensive use of eclipse forms in my
application's editors, so I like the new Property API for binding form
fields with domain objects properties.
So, I think I should pay special attention to WidgetProperties and
BeanProperties clases, also to DuplexingObservableValue as my editors
support bulk edition.
Is it right?
Thanks in advance.
Gaston.
Matthew Hall wrote:
> Gaston,
> See responses below.
> I'm glad you like it!
> I'm assuming you're talking about the properties API vs the existing
> observable factory API, e.g.:
> BeansObservables.observeValue(bean, "name")
> vs.
> BeanProperties.value("name").observe(bean)
>> new style, where can I start reading some documentation?
> First let me say that you don't *have* to migrate your code; existing
> code will continue to work without modification. However if you want to
> use the property API as a matter of personal taste then you could
> certainly do that.
>> of documentation about the new way of doing databinding.
> If you could provide some examples of existing code that you want to
> migrate, I'd be happy to convert it to use the IProperty APIs.
> Other than a case-by-case basis the only other thing I'd recommend you
> look at is the ViewerSupport class, which uses properties to make
> binding a viewer very simple.
> Matthew
| Re: New databinding idiom [message #335786 is a reply to message #335782] |
Wed, 29 April 2009 16:01   |
Matthew, ideally you would write at least a new¬eworthy paragraph about
the new API...
Boris
"Matthew Hall" <matthall@woodcraftmill.com> wrote in message
news:gt9ra5$2vo$1@build.eclipse.org...
> Gaston,
> vs.
> First let me say that you don't *have* to migrate your code; existing code
> will continue to work without modification. However if you want to use
> the property API as a matter of personal taste then you could certainly do
> that.
> look at is the ViewerSupport class, which uses properties to make binding
> Matthew
| Re: New databinding idiom [message #335791 is a reply to message #335786] |
Wed, 29 April 2009 17:42   |
That's a good reminder, when is the deadline for M7?
Matthew
> the new API...
> Boris
>> Gaston,
>> vs.
>> that.
>> Matthew
| Re: New databinding idiom [message #335792 is a reply to message #335784] |
Wed, 29 April 2009 18:09  |
I've been doing the same thing, although I tend to migrate existing code
as I go rather than trying to do everything at once.
It sounds like you've got a good handle on it. The only thing I would
suggest is to familiarize yourself with all of the new property factory
classes:
org.eclipse.core.databinding.BindingProperties -
DataBindingContext#validationStatusProviders, DBC#bindings,
Binding#model, Binding#target, ValidationStatusProvider#models,
VSP#targets, VSP#validationStatus
org.eclipse.core.databinding.property.Properties - general purpose
properties such as self properties, the value of an IObservableValue.
org.eclipse.core.databinding.beans.BeanProperties - beans
org.eclipse.core.databinding.beans.PojoProperties - pojos
org.eclipse.jface.databinding.swt.WidgetProperties - SWT widgets
org.eclipse.jface.databinding.util.JFaceProperties - properties using
the JFace IPropertyChangeListener listener interface
org.eclipse.jface.databinding.viewers.CellEditorProperties -
CellEditor#control property, useful for building nested properties e.g.
TextCellEditor.control.text. Use in conjunction with
ObservableValueEditingSupport.create()
org.eclipse.jface.databinding.viewers.ViewerProperties - Viewer single-
or multiple-selection, checked elements, filters, input
Matthew
Current Time: Sun Oct 26 02:42:59 EDT 2025
Powered by FUDForum. Page generated in 0.18524 seconds
