Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Use of operation parameters and @pre in ocl constraints
Use of operation parameters and @pre in ocl constraints [message #33367] |
Fri, 05 May 2006 14:00 |
Originally posted by: sebastien.xxxxx.com
I'm working with EMFT OCL and I have some problems :
- When I write constraints on an operation the parameters aren't recognize
when they are used. By example :
context ClassName::operationName(param::Integer)
pre : param > 0
the error is : org.eclipse.emf.ocl.parser.SemanticException: ERROR in
(variableExpCS): (Unrecognized variable: (param))
- When I use @pre in ocl constraints : this keyword seems to not be
recognize : The errors are :
org.eclipse.emf.ocl.parser.ParserException: 1:11:1:11 token "@ is invalid"
and org.eclipse.emf.ocl.parser.ParserException: 1:1:1:3 token "pre is
invalid"
Do you know theses problems ? and if yes are they planned to be resolved ?
Re: Use of operation parameters and @pre in ocl constraints [message #33401 is a reply to message #33367] |
Fri, 05 May 2006 15:22 |
Hi, Sebastien,
In the first case, you are declaring a parameter named "param::Integer".
You only want one colon (":"). I think this should have been caught as a
syntax error :-) In any case, with only one colon, it should work.
I suspect that your @pre problem is due to attempting to use it in an
invalid context; it is only recognized on feature call expressions
(operation calls, property navigation). If you provide an example as you
did for the parameter problem, I could help you to identify the cause.
HTH,
Christian
Sebastien wrote:
> Hello,
> pre : param > 0
> invalid"
> Regards
Re: Use of operation parameters and @pre in ocl constraints [message #33432 is a reply to message #33401] |
Fri, 05 May 2006 15:35 |
Sorry for my mistake in my post but I use ":" in my OCL constraint and not
"::". The problem doesn't come from that.
For the @pre I use it like that :
context ClassName::operationName(param:Integer)
pre : param > 0
post : classParam = classParam@pre + param
Thanks for your answer
Sebastien
Christian W. Damus wrote:
> Hi, Sebastien,
> HTH,
> Christian
> Sebastien wrote:
>> Hello,
>> pre : param > 0
>> invalid"
>> Regards
Re: Use of operation parameters and @pre in ocl constraints [message #33465 is a reply to message #33432] |
Fri, 05 May 2006 20:02 |
Hi, Sebastien,
What is 'classParam'? Is that a property of the 'ClassName' classifier?
Ah ... I think I see it now. You need a ":" after the context operation
declaration, even if it has no result type. So, this should read
context ClassName::operationName(param:Integer) :
pre : param > 0
HTH,
Christian
Sebastien wrote:
> pre : param > 0
> Sebastien
<snip>
Re: Use of operation parameters and @pre in ocl constraints [message #33499 is a reply to message #33465] |
Fri, 05 May 2006 20:14 |
Just to clarify: the requirement of the ':' in the operation context
declaration is a quirk of the OCL 2.0 specification and is, IMO, an error.
Looking at operationContextDeclCS (section 12.13.8), it includes operationCS
(12.13.10) which in both the [A] and [B] forms requires the ':' despite the
typeCS being optional.
The attrOrContextCS (12.13.3) does not have this problem because the typeCS
is mandatory for property context, and the classifierContextDeclCS
(12.13.5) also doesn't have a trailing ':'.
The reason why I think this is an error in the spec is that the examples of
operation constraints in section 7.5.14 do not show a ':'.
Perhaps you could raise a bugzilla requesting that the ':' be optional when
the operation has no result type? I would like to still support the ':'
for compatibility, but the OCL is cleaner without it.
Christian
> Hi, Sebastien,
> pre : param > 0
> HTH,
> Christian
> Sebastien wrote:
>> Hi,
>> not "::". The problem doesn't come from that.
>> pre : param > 0
>> Sebastien
> <snip>
Re: Use of operation parameters and @pre in ocl constraints [message #576936 is a reply to message #33367] |
Hi, Sebastien,
HTH,
Christian
Sebastien wrote:
> Hello,
> pre : param > 0
> invalid"
> Regards
Re: Use of operation parameters and @pre in ocl constraints [message #576948 is a reply to message #33401] |
Sebastien Messages: 20 Registered: July 2009 |
pre : param > 0
Sebastien
> Hi, Sebastien,
> HTH,
> Christian
> Sebastien wrote:
>> Hello,
>> pre : param > 0
>> invalid"
>> Regards
Re: Use of operation parameters and @pre in ocl constraints [message #576973 is a reply to message #33432] |
Hi, Sebastien,
pre : param > 0
HTH,
Christian
Sebastien wrote:
> pre : param > 0
> Sebastien
<snip>
Re: Use of operation parameters and @pre in ocl constraints [message #577000 is a reply to message #33465] |
Christian
> Hi, Sebastien,
> pre : param > 0
> HTH,
> Christian
> Sebastien wrote:
>> Hi,
>> pre : param > 0
>> Sebastien
> <snip>
Current Time: Fri Sep 27 05:01:29 GMT 2024
Powered by FUDForum. Page generated in 0.05253 seconds
