How to create different CellEditors per row? [message #334647] |
Mon, 23 February 2009 09:17 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: TheRealHawk.Freenet.de
in my project I need to edit a lot of different objects - so I need to
implement a dialog for each object.
Because theere are a lot of properties on each object it takes some time to
create such a dialog.
So my idea was to implement a simple-dialog, which only shows a table and a
property and ints value per row.
--> This is no problem.
My problem is: How can I set different CellEditors for each value-column?
Currently I use a TableViewer and TableViewerColumns together with an
EdititingSupport for each column.
Markus
Re: How to create different CellEditors per row? [message #334650 is a reply to message #334649] |
Mon, 23 February 2009 14:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:gnttff$24f$1@build.eclipse.org...
> You simply need to make your EditingSupport return the appropriate
> CellEditor or do I miss the point?
> Tom
> Markus Koch schrieb:
>> Hi,
>> to
>> a
>> Markus
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
Yeah - thats it. :-)
Now I have another question: are there some default jface-classes for java
Beans?
e.g. ICellModifier or EdititingSupport or ITableLableProvider?
Of course I can implement them - but maybe there are some ready classes
that I can use?
Re: How to create different CellEditors per row? [message #334652 is a reply to message #334651] |
Mon, 23 February 2009 14:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
news:gnuar2$pm9$1@build.eclipse.org...
>> java
>> Beans?
>> that I can use?
> No we don't have such stuff but you could take a look at
> JFace-Databinding which I'd suggest to use. It provides specialized
> LabelProviders for observed attributes of a bean and integration into
> EditingSupport.
> http://wiki.eclipse.org/JFace_Data_Binding/Snippets
> Tom
Thank you very much for the link - the examples are exactly what I'm looking
for.
Markus
FUDForum. Page generated in 0.03547 seconds
