Re: Paint a line across Eclipse? [message #334592 is a reply to message #334584] |
Thu, 19 February 2009 14:44 |
Originally posted by: chlache.talita.org
Prakash G.R. wrote:
> Doesn't seems to fit into Eclipse! What is the requirement?
> - Prakash
I want to create a dreamwaver like "point to file button".
When you click and drag on this button a line is drawn starting from the button following your custom mouse pointer.
This line is drawn across different windows. It is a visual enhancement of the drag and drop functionality.
You can see it in action using the dreamweaver properties panel.
Do you have any ideas of how to achieve that?
Re: Paint a line across Eclipse? [message #334655 is a reply to message #334627] |
Mon, 23 February 2009 15:23 |
Thanks for your answer. I did not think about that moveAbove call.
I hope I can combine that with the standard drag and drop behavior to get
the necessary information about the control below the mouse.
I will post the solution once I have it.
ac
FUDForum. Page generated in 0.03657 seconds
