Home » Eclipse Projects » Eclipse Platform » Editors opening very slowly on Linux
Editors opening very slowly on Linux [message #334486] Thu, 12 February 2009 08:33 Go to next message
I'm using Eclipse 3.4.1 on Fedora, although colleagues who use Ubuntu have
also seen similar issues. Every time I open a new file, it takes a
perceptibly long time -- several seconds -- to actually open the editor
window. I've tried with an empty .eclipse directory and a fresh workspace
and with both GCJ 1.5 and OpenJDK 1.6, and it always happens.
Oddly, for me this is only on my desktop machine; I have no issue on my
laptop, which is running the same version of Fedora.
Is this a known problem? Where should I look for suggestions?
MEF
Re: Editors opening very slowly on Linux [message #334487 is a reply to message #334486] Thu, 12 February 2009 08:58 Go to previous messageGo to next message
Addendum: here's a video of the sort of speed that I'm talking about:
http://www6.informatik.tu-muenchen.de/~foster/eclipse.ogg
In the video, I only open one Java editor and one Ant editor, but
subsequent Java/Ant editors are equally slow to open -- it seems to have
nothing to do with initialising classes on first opening or anything like
that.
MEF
Re: Editors opening very slowly on Linux [message #334491 is a reply to message #334486] Thu, 12 February 2009 09:58 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Do you see the same problem with SUN or IBM JDK? I am on Ubuntu and have
not seen any performance problems running Eclipse using either JDK.
Igor
> have also seen similar issues. Every time I open a new file, it takes a
> workspace and with both GCJ 1.5 and OpenJDK 1.6, and it always happens.
> MEF
Re: Editors opening very slowly on Linux [message #334493 is a reply to message #334491] Thu, 12 February 2009 11:24 Go to previous messageGo to next message
Originally posted by: mickael.istria.openwide.fr
I agree with Igor.
My colleagues and I experimented the same troubles under Ubuntu with gcj
or OpenJDK, and the only solution we found was to switch to the Sun JVM...
Hope that helps
Mickael
> Regards,
> Igor
>> a perceptibly long time -- several seconds -- to actually open the
>> editor window. I've tried with an empty .eclipse directory and a fresh
>> my laptop, which is running the same version of Fedora.
>> Thanks,
>> MEF
Re: Editors opening very slowly on Linux [message #334505 is a reply to message #334486] Fri, 13 February 2009 03:10 Go to previous messageGo to next message
On Thu, 12 Feb 2009 13:33:13 +0000 (UTC), mefoster@gmail.com (Mary
Please don't use gcj: it's not supported by Eclipse and causes a
significant amount of questions in the "Why does my Eclipse doesn't
start/keeps crashing" section in the newsgroups.
Have a look at http://www.eclipse.org/downloads/moreinfo/jre.php for a
list of supported VMs.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Re: Editors opening very slowly on Linux [message #334507 is a reply to message #334486] Fri, 13 February 2009 04:09 Go to previous messageGo to next message
Besides not using GCJ you might see this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153936
Dani
> MEF
Re: Editors opening very slowly on Linux [message #334526 is a reply to message #334507] Mon, 16 February 2009 03:15 Go to previous message
>> editor window.
Hallelujah! Adding -Dorg.eclipse.swt.internal.gtk.disablePrinting to the
-vmargs fixed the problem! My colleagues and I thank you. :)
MEF
Previous Topic:JRE Refresh on the Mac
Next Topic:Open Resource window issue
Current Time: Wed Apr 16 10:15:36 EDT 2025
Powered by FUDForum. Page generated in 0.04099 seconds
