Re: Eclipse won't start after computer crash and -clean option [message #333923 is a reply to message #333902] |
Wed, 14 January 2009 09:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
On Tue, 13 Jan 2009 15:30:14 +0000 (UTC), aochsner@cs.stanford.edu
(Andrew Ochsner) wrote:
>I've looked around but I'm not sure I have a <version-specific-dir> under
>%APPDATA%. So far, seems that removing the org.eclipse.equinox.weaving
>and the AJDT plugins as well as the plugins that refer to AJDT and
>reinstalling them has at least made things work again.
>Whats an example of this directory you're talking about? First I've heard
>of it.
I meant the directory you can specify using the -configuration command
line option or by setting the "osgi.configuration.area" variable. It
contains bundle descriptions and several not workspace related
settings. Since we use an shared installation on a Windows 2008
Terminal Server this directory is in %APPDATA% or in the users "local
home" which is "C:\Users\<userid>" on our server (if I remember right
this can be configured by the server admin). The default locations are
documented in the Eclipse Help for the "osgi.configuration.area"
variable.
If this directory constains invalid data it will not be cleared by the
"-clean" option. The only way to get a clean base is removing the
directory.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Achim Lörke
FUDForum. Page generated in 0.04658 seconds
