Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333402 is a reply to message #333400] |
Tue, 09 December 2008 17:05 |
Matthew Hall Messages: 368 Registered: July 2009 |
Any cross-observable or compound constraint validators should be
enforced using a ValidationStatusProvider. You can extend
ValidationStatusProvider and manually monitor your address collection
for validation errors. Or, you could extend MultiValidator and have it
monitor the relevant observables to check for errors. If you are using
ObservableMapLabelProvider then I would suggest observing the values()
for the IObservableMap used by the relevant table column.
As an example:
TableViewer addressViewer = ...
ObservableListContentProvider cp = new ObservableListContentProvider();
final IObservableMap[] maps = BeansObservables.observeMaps(
cp.getKnownElements,
Address.class,
new String[] {"street", "street2", "city", "province", "code" } );
addressViewer.setLabelProvider(new ObservableMapLabelProvider(maps));
MultiValidator addressValidator = new MultiValidator(realm) {
protected IStatus validate() {
Set addresses = maps[0].keySet();
IStatus status = ValidationStatus.ok();
for (Iterator it = addresses.iterator(); it.hasNext(); ) {
Address address = (Address) it.next();
// validate address, update status variable if more severe
// than current value
return status;
Hope this helps,
Matthew Hall
Thomas wrote:
> This is parially a cross post to something I asked on the SWT group.
> Guess I have an editor that edits a person object. a person has many
> adresses so the editor shows them in a table. but withmy current
> solution the fields in the table can only be validated when the user
> edits cells (via EditingSupport) bindings are dynamically created. But
> in my scenario I cant create a valid new record. So if the user doesnt
> edit it he will never see any validating message. Are there any ideas
> out there to solve that ?
Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333419 is a reply to message #333403] |
Wed, 10 December 2008 14:25 |
Thomas Kratz Messages: 165 Registered: July 2009 |
Thanks Matthew,
thats exactly what I was looking for !
Thomas
>> Address.class,
>> return status;
> Forgot to say, you need to add the MultiValidator to the
> DataBindingContext:
> dbc.addValidationStatusProvider(addressValidator);
> Matthew
Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333443 is a reply to message #333419] |
Thu, 11 December 2008 15:06 |
Boris Bokowski Messages: 272 Registered: July 2009 |
Hi Thomas,
Would you be able to write a new snippet for this and contribute it through
Bugzilla?
Boris
"Thomas" <thomas.kratz@eiswind.de> wrote in message
news:ghojga$ta5$1@build.eclipse.org...
> Thanks Matthew,
> Thomas
>>> Address.class,
>>> return status;
>> DataBindingContext:
>> Matthew
FUDForum. Page generated in 0.04032 seconds
