Basic case of DLL import failing [message #333187] |
Fri, 28 November 2008 13:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: torbjorn.ghostwriter.no
I've done what I thought were the necessary steps to access a DLL in a
plugin:
1. I put the dll file (jdic_misc.dll) in the plugin root
2. I put the following code in the plugin:
System.loadLibrary("jdic_misc.dll");
However, the line throws the following exception:
java.lang.UnsatisfiedLinkError: no jdic_misc.dll in java.library.path
.... which I interpret as not being able to find the DLL at all, rather than
an issue with further linking.
Have I missed some steps? I read that the Bundle-NativeInclude (or whatever
it was called) is unnecessary in 3.4, and I tried including the DLL in the
build, but nothing helps. Note that I'm running this from Eclipse directly
(i.e. not exported or anything like that)
FUDForum. Page generated in 0.05415 seconds
