Where to put log4j.properties [message #332612] |
Fri, 31 October 2008 11:33 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Christoph Jäger![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=christoph.jaeger%40cargodata.at) Messages: 14 Registered: July 2009 |
I am trying to use log4j (via slf4j) for logging in an RCP application.
I downloaded OSGIified bundles for slf4j and log4j from SpringSource.
Everything seems to work fine (slf4j and log4j bundles / plugins are
included in my exported RCP application, and seem to be found upon
application start), only the system does not find my log4j.properties
file, so it complains that log4j is not configured properly.
I would like to include the log4j.properties file in the plugin defining
my RCP application. How can I make log4j find my log4j.properties file
this way? I tried putting it in the src directory (hoping it would be
written to the same place as the compiled class files, and be on the
classpath this way), I tried the base directory, META-INF, tried adding
it to the plugins classpath, nothing seems to work.
Any ideas?
Christoph Jäger
Re: Where to put log4j.properties [message #333148 is a reply to message #332627] |
Wed, 26 November 2008 21:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: stephenmccants.yahoo.com
Hi Christoph,
I ran into the same problem and found a slightly different solution that lets you keep the
log4j.properties file in the plugin that is doing the logging. I haven't tried this with different
plugins using different properties files, so I don't know if it will break down there, but I hope
not as that is my end goal.
I placed this code into my Activator and then put the log4j.properties file in the root folder for
the plugin:
Properties log4jProperties = new Properties();
URL url = this.getBundle().getResource("log4j.properties");
log4jProperties.load(url.openStream());
PropertyConfigurator.configure(log4jProperties);
Hope that helps!
--Stephen McCants
Christoph Jaeger wrote:
> I found a solution/workaround: create a fragment containing only the
> log4j.properties file, and attach this fragment to the plugin containing
> the log4j libraries.
> Still I would like to keep the log4j settings in my RCP application
> pluging instead of creating a fragment for just this single file.
> Christoph
FUDForum. Page generated in 0.03071 seconds
