Re: How to create a "document literal wrapped" WSDL ? [message #332395 is a reply to message #332390] |
Mon, 20 October 2008 21:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Lawrence Mandel![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=lmandel%40gmail.com) Messages: 486 Registered: July 2009 |
Hi Gary,
From the article:
"This wrapped style originates from Microsoft®. There is no specification
that defines this style; so while this style is a good thing,
unfortunately, the only choice right now, in order to interoperate with
Microsoft's and other's implementations, is to make educated guesses as to
how it works based on the output of the Microsoft WSDL generator. This
pattern has been around for awhile, and the industry has done a good job
of understanding it, but while the pattern is fairly obvious in this
example, there are corner cases in which the proper thing to do is not
particularly clear. Our best hope is that an independent group like the
WS-I organization will help stabilize and standardize this in the future."
Given that there is no standard and that this is a MS specific pattern I
think it is out of scope of WTP to provide support for this binding. Of
course I'm no longer part of WTP leadership so perhaps someone like Kathy
Chan or Valentin Baciu would have a more official answer.
That said, if you want to use the binding you don't need to rely on the
wizard. Generate the WSDL, open the WSDL file, change to the source tab,
and make the required changes as outlined in the article.
Lawrence Mandel
Co-author Eclipse Web Tools Platform: Developing Java Web Applications
http://www.eclipsewtp.org
>Gary,
>I guess you're using the Web Tools project for this and should ask on
>the WTP newsgroup, which I've added to the "to" list of the reply.
>Gary Williamson wrote:
>> When I create a new WSDL I am asked on the options page which
>> "SOAP Binding option" I would like to use:
>> - document literal
>> - rpc literal
>> - rpc encoded
>> I miss an entry for:
>> - document literal wrapped
>> This style is described e.g. on page:
>> http://www.ibm.com/developerworks/webservices/library/ws-whi chwsdl/
>> How can I get this WSDL skeleton?
>> Gary
FUDForum. Page generated in 0.03752 seconds
