| Home » Eclipse Projects » Eclipse Platform » File hiding in perspectives
 Goto Forum:|
| File hiding in perspectives [message #331776] | Mon, 22 September 2008 03:14  |  |
| Eclipse User  |  |  |  |  | Originally posted by: massimiliano.fanciulli.intecs.it
 Hi All,
 i'm here to ask you the following, since i haven't found any answer in
 the documentation. I'm developing a plugin extension for eclipse 3.2 and
 i have added some new perspectives. No problem with that except for the
 fact that, when enabled, files with filename that start with a dot are
 not hidden by default. Those files are not visible if, for example, i
 activate the Java perspective. Can you tell me how to enable/disable
 this behaviour programmatically?
 Thanks in advance,
 Massimiliano Fanciulli
| Re: File hiding in perspectives [message #331791 is a reply to message #331776] | Mon, 22 September 2008 11:51   |  |
| Eclipse User  |  |  |  |  | Originally posted by: eclipse-news.rizzoweb.com
 Massimiliano Fanciulli wrote:
 > Hi All,
 What View is showing the files? Note that I am not asking about the
 Perspective, but rather the View (for example, Navigator, Project
 Explorer, Package Explorer, etc).
 For reference, the only View that shows the . files is the Navigator
 view (I think). Package Explorer and Project Explorer do NOT show those
 files by default.
 Hope this helps,
 Eric
| Re: File hiding in perspectives [message #331805 is a reply to message #331791] | Tue, 23 September 2008 05:22   |  |
 Hi Eric,
 yes i'm referring to the navigator view put in my perspective.
 Massimiliano
 >> Hi All,
 >> and i have added some new perspectives. No problem with that except
 >> for the fact that, when enabled, files with filename that start with a
 >> dot are not hidden by default. Those files are not visible if, for
 >> example, i activate the Java perspective. Can you tell me how to
 >> enable/disable this behaviour programmatically?
 > files by default.
 > Hope this helps,
 > Eric
| Re: File hiding in perspectives [message #331813 is a reply to message #331805] | Tue, 23 September 2008 09:12  |  |
 > Hi Eric,
 If you want the files hidden, you might want to consider using either
 Project Explorer or Package Explorer views instead. Those views hide .*
 files by default.
 I think the Navigator view
 (org.eclipse.ui.views.navigator.ResourceNavigator) can be configured
 with a pattern filter to hide files, but you'd have to examine its API
 to learn how to set them programatically.
 Hope this helps,
 Eric
 >>> Hi All,
 >>> in the documentation. I'm developing a plugin extension for eclipse
 >>> 3.2 and i have added some new perspectives. No problem with that
 >>> except for the fact that, when enabled, files with filename that
 >>> start with a dot are not hidden by default. Those files are not
 >>> visible if, for example, i activate the Java perspective. Can you
 >>> tell me how to enable/disable this behaviour programmatically?
 >> those files by default.
 >> Hope this helps,
 >> Eric
 Current Time: Fri Oct 31 17:42:31 EDT 2025
 Powered by FUDForum . Page generated in 0.03807 seconds |
