Home » Eclipse Projects » Eclipse Platform » Trouble with lots of data , Swt Tables and DataBinding
- Trouble with lots of data , Swt Tables and DataBinding [message #331021] Thu, 21 August 2008 09:54 Go to next message
Originally posted by: java14.cshg.com.br
Hi to everyone , I
- [databinding] TreeViewer [message #331039 is a reply to message #331021] Thu, 21 August 2008 15:40 Go to previous messageGo to next message
Originally posted by: krzysztof.daniel.gmail.com
Hi there,
I am trying to learn databinding and I have run into following problem:
I have a tree displayed in a TreeViewer (with databinding):
Account
+- Folder
Now, Folder has messages, and I would like to show only the number of
messages in the Folder:
Account
+- Folder (4)
Then I populate messages in the background job and the Folder label is
*not* updated.
I use the code found somewhere in examples
(TreeStructureAdvisor/IObservableFactory).
How can I update the label of Folder when its observered message list
changes?
TIA
Chris
- Re: [databinding] TreeViewer [message #331042 is a reply to message #331039] Thu, 21 August 2008 18:18 Go to previous messageGo to next message
You need two things: the Folder object must fire some sort of change
event, and you need an observable capable of receiving those event
dispatches.
For your situation, I recommend extending ListeningLabelProvider. You
will have to implement the addListenerTo() and removeListenerFrom()
methods, and you will likely want to reimplement the updateLabel()
method as well.
class FolderLabelProvider extends ListeningLabelProvider {
public FolderLabelProvider(IObservableSet knownElements) {
super(knownElements);
// Must lazy init because addListenerTo is called by superconstructor
PropertyChangeListener listener;
protected void addListenerTo(Object o) {
if (listener == null) {
listener = new PropertyChangeListener() {
public void propertyChanged(PropertyChangeEvent e) {
// If properties may be changed in another thread, you may
// have to wrap this method call in a Realm.asyncExec()
fireChangeEvent(Collections.singleton(e.getSource()));
((Folder)o).addPropertyChangeListener(listener);
protected void removeListenerFrom(Object o) {
if (listener != null) {
((Folder)o).removePropertyChangeListener(listener);
public void updateLabel(ViewerLabel label, Object element) {
Folder folder = (Folder) element;
String text = folder.getLabel();
if (folder.getUnreadItemCount() > 0)
text = text + " ("+folder.getUnreadItemCount()+")";
label.setText(text);
Matthew
> Hi there,
> Account
> +- Folder
> Account
> +- Folder (4)
> *not* updated.
> changes?
> TIA
> Chris
- Re: [databinding] TreeViewer [message #331067 is a reply to message #331042] Fri, 22 August 2008 15:12 Go to previous messageGo to next message
Thank you, thank you, thank you!
I was able to achieve the goal but I had to modify slightly your code,
basically because I had to support different objects (attached below).
The only sad thing is that you have access only to ViewerLabel and you
cannot use styled labels... any idea? should I open RFE?
Chris
public class ServersLabelProvider extends ListeningLabelProvider {
public ServersLabelProvider(IObservableSet itemsThatNeedLabels) {
super(itemsThatNeedLabels);
public String prepareText(Object element) {
if (element instanceof ServerManager) {
return "Mail accounts";
if (element instanceof Server) {
return ((Server) element).getName();
if (element instanceof Folder) {
return ((Folder) element).getName() + " "
+ ((Folder) element).getMessages().size();
return null;
Adapter adapter;
protected void addListenerTo(Object next) {
if (adapter == null) {
if (next instanceof Folder) {
adapter = new Adapter() {
public Notifier getTarget() {
return null;
public boolean isAdapterForType(Object type) {
return true;
public void notifyChanged(final Notification notification) {
Display.getDefault().syncExec(new Runnable(){
public void run() {
fireChangeEvent(Collections.singleton(notification
.getNotifier()));
public void setTarget(Notifier newTarget) {
((Folder) next).eAdapters().add(adapter);
protected void removeListenerFrom(Object next) {
if (adapter != null && next instanceof Folder) {
((Folder) next).eAdapters().remove(adapter);
label.setText(prepareText(element));
> dispatches.
> method as well.
> Matthew
> > Hi there,
> > Account
> > +- Folder
> > Account
> > +- Folder (4)
> > *not* updated.
> > changes?
> > TIA
> > Chris
- Re: Trouble with lots of data , Swt Tables and DataBinding [message #331078 is a reply to message #331021] Sat, 23 August 2008 07:23 Go to previous message
could you provide a test-case and add a snippet for us to reproduce the
faulty behaviour? Then please file a bug and attach me to it tom.schindl
(at)bestsolution.at.
Tom
Nelson Fernando schrieb:
> Hi to everyone , IŽm having some trouble when using databing into SWT tables
> The binding works , but I have a large amount of data ( 600 rows , each with
> 25 colums ) , the table takes 1 hole minute to get ready for presentation
> Then I started looking for a solution and end up up the virtual table , but
> it didnŽt change a thing it still took a lot of time to load the table .
> But when I removed the databinding of the table and inserted the itens by
> hand ( one by one ) using tableItens , it was faster than a split second .
> Is this a know issue in table databinding ? Is there another solution ? Did
> I post this in the right forum ?
> thanks in advance
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Writing to the Eclipse Log
Next Topic:Obtaining an IResource from a fully qualified class name
Current Time: Mon May 05 10:06:05 EDT 2025
Powered by FUDForum. Page generated in 0.05015 seconds
