Re: Trouble with Jobs after multiple calls to PlatformUI.createAndRunWorkbench [message #330793 is a reply to message #330625] |
Wed, 13 August 2008 14:07 |
Originally posted by: tom.seidel.spiritlink.de
When you want to implement a tray icon, that shows up, if the user
closes the window you can override the preWindowShellClose() in your
WorkbenchWindowAdvisor:
public boolean preWindowShellClose() {
final boolean[] res = new boolean[] { true };
this.fMinimizeFromClose = true;
getWindowConfigurer().getWindow().getShell().notifyListeners (SWT.Iconify,
new Event());
res[0] = false;
this.fMinimizeFromClose = false;
return res[0];
Tom
Gary Louttit schrieb:
> My application uses a TrayIcon which is wrapped around the call to
> PlatformUI.createAndRunWorkbench(). When the user choose to Exit the
> application (from File->Exit, which is the IWorkbenchAction from the
> ActionFactory), I call Display.readAndDispatch() until the MenuItems for
> Open or Exit on the TrayIcon are pressed. If Open is pressed then i
> call PlatformUI.createAndRunWorkbench() again.
> One key point is that I create a new Display from PlatformUI and use a
> new WorkbenchAdvisor each time PlatformUI.createAndRunWorkbench(),
> otherwise more issues arise.
> The only problem i am experiencing is with my Jobs on subsequent
> createAndRunWorkbench() calls .. while they do execute correctly, they
> do not appear in the ProgressView, nor do they display progress
> information in a dialog.
> Does anyone have insight onto calling PlatformUI.createAndRunWorkbench()
> multiple times? Or a better way to hide the workbench with the ability
> to retrieve it from a Tray Icon?
> I have noted that the ProgressManager object is the same through both
> launches of the Workbench.
> Gary
FUDForum. Page generated in 0.03547 seconds
