Re: [CommonNavigator] Customizing the ViewPart [message #330697 is a reply to message #330696] |
Sat, 09 August 2008 20:32 |
Francis Upton IV Messages: 472 Registered: July 2009 Location: Oakland, CA |
You can have as many instances of the Common Navigator as you like, just
create a normal view and then associated the navigator with that view.
You configure the placement of the view just as you do with any other view.
Just define two views using the org.eclipse.ui.views extension point,
and for each of those, define the configuration for the CN using two
org.eclipse.ui.navigator.viewer instances.
You may want to subclass the getInitialInput() method of the
CommonNavigator class to have it get the input from where you want it,
the default gets the input this way:
return getSite().getPage().getInput();
Francis
Thomas wrote:
> I would like to have a viewer with a layout similar to the Type
> Hierarchy View in Eclipse, i.e. one view on the top and a different view
> on the bottom, using the common navigator framework. My intention is to
> have a common viewer on top and a common viewer on the bottom that both
> display different trees, e.g. the top displays one model and the bottom
> displays another one. Is there an easy way using the Common Navigator
> Framework to create a viewpart like this and/or would I have to adapt
> the CommonNavigator class?
> Kind regards,
> Thomas
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
Re: [CommonNavigator] Customizing the ViewPart [message #330714 is a reply to message #330697] |
Mon, 11 August 2008 17:10 |
Thomas Fritz Messages: 2 Registered: July 2009 |
Hi Francis,
thanks a lot for your answer. I might be wrong, but I think we are talking
about two different things and I think it's because I wasn't clear enough
in my first post.
If I define two views using the org.eclipse.ui.views extension point, as
you suggest, I thought I would get two separate views, which is not
exactly what I want.
What I would like is one single viewer that contains two parts inside like
the type hierarchy view: on the top it would show a tree and on the bottom
it shows another tree. However, I would like each of those two
parts/controls being a common viewer and have the support of the common
navigator framework with it.
So I thought I need to have one viewer that has a createPartControl method
in which both parts, the top and the bottom are defined and then using
some layout put on top of each other, and both of those would be common
viewers. However, this seems a little more tedious as I would have to copy
quite a bit of the CommonNavigator code, and I was wondering if there is
an easier solution to this.
It would be great if you could give me some advice and let me know if I am
wrong.
Thank you,
Thomas
FUDForum. Page generated in 0.07447 seconds
