Plug-in Installation messes up Ant Home Classpath [message #330242] |
Tue, 22 July 2008 17:27 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: marcio.debarros.gmail.com
I have a 3.2.2 based plug-in that after installed, the value set for the
Ant home under Window->Preferences->Ant->Run time->Classpath->Ant Home
Entries(Default) is changed, causing Ant build to be broken.
After the installation is done the value previously set to the location
of the org.apache_ant_1.7.0 plug-in (eclipse\plugins) is changed to
(..configuration\org.eclipse.osgi\bundles\578\1\.cp\) which happens to
be an older version of Ant (1.5.2).
Note that plug-in that is being installed, does not depent on ant
itself, it only requires the org.eclipse.osgi plug-in.
Any ideas on how to prevent this from happening ?
-MD
Re: Plug-in Installation messes up Ant Home Classpath [message #330245 is a reply to message #330244] |
Tue, 22 July 2008 19:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Darin,
The plug-in is something that I wrote, so I know that does not pack an
ant jar with it. The only connection that I could find so far is that
my plug-in requires the org.eclipse.osgi to be present, and from there
it points to a ant.jar file that is part of the eclipse configuration
directory, rather that taking one from the plugins directory.
As I was trying to rule out conflicts with third party plug-ins or
corrupt jar files, I tested and was able to duplicate the problem even
on a fresh install on the 3.2.2 SDK. And I still have the problem, and
the following error shows up on the log file.
!ENTRY org.eclipse.ant.core 4 2 2008-07-22 15:18:31.320
!MESSAGE Malformed URL.
!STACK 0
at
org.eclipse.core.internal.runtime.Activator.getURLConverter( Activator.java:313)
at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.j ava:163)
at
org.eclipse.ant.core.AntCorePreferences.addLibraries(AntCore Preferences.java:834)
at
org.eclipse.ant.core.AntCorePreferences.getDefaultAntHomeEnt ries(AntCorePreferences.java:440)
at
org.eclipse.ant.core.AntCorePreferences.getDefaultAntHome(An tCorePreferences.java:301)
at
org.eclipse.ant.core.AntCorePreferences.restoreAntHome(AntCo rePreferences.java:289)
at
org.eclipse.ant.core.AntCorePreferences.restoreCustomObjects (AntCorePreferences.java:194)
at
org.eclipse.ant.core.AntCorePreferences.<init>(AntCorePreferences.java:160)
at
org.eclipse.ant.core.AntCorePlugin.getPreferences(AntCorePlu gin.java:219)
at
org.eclipse.ant.internal.ui.preferences.AntTasksPage.initial ize(AntTasksPage.java:123)
at
org.eclipse.ant.internal.ui.preferences.AntRuntimePreference Page.createContents(AntRuntimePreferencePage.java:83)
at
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:233)
at
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1456)
at
org.eclipse.jface.preference.PreferenceDialog$13.run(Prefere nceDialog.java:1213)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1207)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:433)
at
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:698)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
at
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
at
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:65)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Darin Swanson wrote:
> Which plug-in are you installing?
> It would appear that that plug-in is rolling out its own JARed version of
> Ant (1.5.2) and changing the Ant Home to point to it.
> Doubly strange if it does not depend on Ant???
> Darins
> http://runnerwhocodes.blogspot.com
> "Marcio DeBarros" <marcio.debarros@gmail.com> wrote in message
> news:g65597$jph$1@build.eclipse.org...
>> Hi,
>> After the installation is done the value previously set to the location of
>> (..configuration\org.eclipse.osgi\bundles\578\1\.cp\) which happens to be
>> Note that plug-in that is being installed, does not depent on ant itself,
>> Thanks,
>> -MD
FUDForum. Page generated in 0.04298 seconds
