Home » Eclipse Projects » Eclipse Platform » Error with Ganymede, can't launch run configuration against current workspace
| Error with Ganymede, can't launch run configuration against current workspace [message #329814] |
Sun, 06 July 2008 23:45  |
Originally posted by: apicard.tampabay.rr.com
Since the days of 3.1 we have always had some launch configurations that
are used for code generation and that run in the current workspace by
running a launcher application.
Now it won't even get that far and it tells me that my workspace is
locked or already in use. Well it is the current workspace. This would
normally happen if you tried to launch a full runtime workbench to its
current workspace, but never to run those applications.
Can you shed some lights on what has changed (btw i went to a 3.3
version and it doesn't do that).
Alain
| Re: Error with Ganymede, can't launch run configuration against current workspace [message #329824 is a reply to message #329822] |
Mon, 07 July 2008 08:54  |
Ed,
The answer to your question is yes, and it has always worked. Like I
said, starting a full runtime-workspace would not work, but this always did.
Any idea what would have changed in 3.4?
Alain
Here is one of those launch config:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.pde.ui.RuntimeWorkbench">
<stringAttribute key="application"
value="com.castortech.iris.IrisApplicationLauncher"/>
<booleanAttribute key="askclear" value="true"/>
<booleanAttribute key="automaticAdd" value="true"/>
<booleanAttribute key="automaticValidate" value="true"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<booleanAttribute key="clearws" value="false"/>
<booleanAttribute key="clearwslog" value="false"/>
<stringAttribute key="configLocation"
value=" ${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/Gen erate
JTB step - C"/>
<booleanAttribute key="default" value="false"/>
<stringAttribute key="deselected_workspace_plugins" value="VMF.editor"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="location" value="${workspace_loc}"/>
<booleanAttribute
key="org.eclipse.debug.core.appendEnvironmentVariables" value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS"
value="-os win32 -ws win32 -arch x86 -nl en_US -nosplash
EDU.purdue.jtb.JTB
"${resource_loc:/CLanguageBundle/src/com/castortech /cinterpreter/Configuration.xml}" "/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER"
value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS"
value="-Xms256m -Xmx512m -ea -XX:MaxPermSize=128m"/>
<stringAttribute key="org.eclipse.jdt.launching.WORKING_DIRECTORY"
value=" ${workspace_loc:CLanguageBundle/src/com/castortech/cinterpre ter} "/>
<stringAttribute key="pde.version" value="3.3"/>
<stringAttribute key="product" value="org.eclipse.sdk.ide"/>
<stringAttribute key="selected_target_plugins"
value=" com.ibm.icu,com.jcraft.jsch,javax.servlet,javax.servlet,net. sourceforge.lpg.lpgjavaruntime,net.sourceforge.lpg.lpgjavaru ntime,org.apache.commons.logging,org.apache.commons.logging, org.apache.log4j,org.apache.lucene,org.apache.lucene.analysi s,org.eclipse.ant.core,org.eclipse.compare,org.eclipse.core. commands,org.eclipse.core.contenttype,org.eclipse.core.datab inding,org.eclipse.core.expressions,org.eclipse.core.filebuf fers,org.eclipse.core.filesystem,org.eclipse.core.filesystem .win32.x86,org.eclipse.core.jobs,org.eclipse.core.net,org.ec lipse.core.resources,org.eclipse.core.resources.compatibilit y,org.eclipse.core.resources.win32,org.eclipse.core.runtime, org.eclipse.core.runtime.compatibility,org.eclipse.core.runt ime.compatibility.auth,org.eclipse.core.runtime.compatibilit y.registry,org.eclipse.core.variables,org.eclipse.debug.core ,org.eclipse.emf.codegen,org.eclipse.emf.codegen.ecore,org.e clipse.emf.codegen.ecore.ui,org.eclipse.emf.common,org.eclip se.emf.common.ui,org.e
clipse.emf.converter,org.eclipse.emf.ecore,org.eclipse.emf.e core.change,org.eclipse.emf.ecore.edit,org.eclipse.emf.ecore .xmi,org.eclipse.emf.edit,org.eclipse.emf.edit.ui,org.eclips e.emf.importer,org.eclipse.emf.ocl,org.eclipse.emf.teneo,org .eclipse.emf.teneo.annotations,org.eclipse.emf.teneo.doc,org .eclipse.emf.teneo.eclipse,org.eclipse.emf.teneo.hibernate,o rg.eclipse.emf.teneo.hibernate.eclipse,org.eclipse.emf.teneo .hibernate.mapper,org.eclipse.emf.teneo.libraries,org.eclips e.emf.teneo.source,org.eclipse.equinox.app,org.eclipse.equin ox.common,org.eclipse.equinox.http.jetty,org.eclipse.equinox .http.servlet,org.eclipse.equinox.preferences,org.eclipse.eq uinox.registry,org.eclipse.help,org.eclipse.help.base,org.ec lipse.help.ui,org.eclipse.jdt,org.eclipse.jdt.compiler.apt,o rg.eclipse.jdt.compiler.tool,org.eclipse.jdt.core,org.eclips e.jdt.core.manipulation,org.eclipse.jdt.debug,org.eclipse.jd t.launching,org.eclipse.jface,org.eclipse.jface.databinding, org.eclipse.jface.text,org.ecl
ipse.jsch.core,org.eclipse.ltk.core.refactoring,org.eclipse. ltk.ui.refactoring,org.eclipse.ocl,org.eclipse.ocl.ecore,org .eclipse.osgi,org.eclipse.osgi.services,org.eclipse.pde.buil d,org.eclipse.pde.core,org.eclipse.swt,org.eclipse.swt.win32 .win32.x86,org.eclipse.team.core,org.eclipse.team.cvs.core,o rg.eclipse.team.cvs.ui,org.eclipse.team.ui,org.eclipse.text, org.eclipse.ui,org.eclipse.ui.cheatsheets,org.eclipse.ui.con sole,org.eclipse.ui.editors,org.eclipse.ui.forms,org.eclipse .ui.ide,org.eclipse.ui.intro,org.eclipse.ui.navigator,org.ec lipse.ui.navigator.resources,org.eclipse.ui.views,org.eclips e.ui.views.properties.tabbed,org.eclipse.ui.win32,org.eclips e.ui.workbench,org.eclipse.ui.workbench.texteditor,org.eclip se.update.configurator,org.eclipse.update.core,org.eclipse.u pdate.core.win32,org.eclipse.update.ui,org.junit,org.junit4, org.mortbay.jetty "/>
<stringAttribute key="templateConfig"
value="${target_home}\configuration\config.ini"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useDefaultConfig" value="true"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<booleanAttribute key="useProduct" value="false"/>
<booleanAttribute key="usefeatures" value="false"/>
</launchConfiguration>
Ed Merks wrote:
> Alain,
> Is the launched application specifying the same workspace as is being
> used by the running Eclipse? It sounds like it is, but I wouldn't
> expect that ever to have worked...
Current Time: Fri Oct 31 20:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.08656 seconds
