programmatically call Import->Existing projects into workspace [message #329461] |
Wed, 25 June 2008 10:26 |
Originally posted by: subs._nospam_consertum.com
I am trying to find a way to directly invoke the Import Projects page of
the Import wizard. I can invoke the Import wizard but I can't find a way
to programmatically select "Existing projects into workspace" and then
select Next. Is there a way to do this directly?
While we are on the subject, once opened, I'd like to pre-populate some
of the fields on the Import Projects page - is that possible too?
Derek
Re: programmatically call Import->Existing projects into workspace [message #329463 is a reply to message #329461] |
Wed, 25 June 2008 10:57 |
Derek,
We use ImportOperation directly.
Derek wrote:
> of the Import wizard. I can invoke the Import wizard but I can't find
> a way to programmatically select "Existing projects into workspace"
> and then select Next. Is there a way to do this directly?
> some of the fields on the Import Projects page - is that possible too?
> Thanks
Re: programmatically call Import->Existing projects into workspace [message #329464 is a reply to message #329463] |
Wed, 25 June 2008 11:10 |
Hi Ed,
Thanks for the tip. However, I'd like to usethe Import Project dialog UI
- I'm (effectively) trying to provide a shortcut.
Ed Merks wrote:
> Derek,
> Derek wrote:
>> Hi,
>> Thanks
Derek
Re: programmatically call Import->Existing projects into workspace [message #329474 is a reply to message #329461] |
Wed, 25 June 2008 14:39 |
Originally posted by: eclipse-news.rizzoweb.com
Derek wrote:
I think the wizard class you want to create is
org.eclipse.ui.wizards.datatransfer.ExternalProjectImportWiz ard
You'll have to create a WizardDialog to contain it, too. Here is a
snippet of code that we use to do this for our own Wizards:
// Grab the selection out of the tree and convert it to a
// StructuredSelection for use by the wizard.
StructuredSelection currentSelection = null;
if (activeSelection != null && activeSelection instanceof TreeSelection) {
currentSelection = new StructuredSelection(((TreeSelection)
activeSelection).toArray());
// get the wizard from the child class.
IWorkbenchWizard wizard = constructWizard();
// Get the workbench and initialize, the wizard.
IWorkbench workbench = PlatformUI.getWorkbench();
wizard.init(workbench, currentSelection);
// Open the wizard dialog with the given wizard.
WizardDialog dialog = new
WizardDialog(workbench.getActiveWorkbenchWindow().getShell() , wizard);
dialog.open();
Re: programmatically call Import->Existing projects into workspace [message #329477 is a reply to message #329474] |
Wed, 25 June 2008 15:08 |
Eric Rizzo wrote:
> Derek wrote:
>> Hi,
> dialog.open();
Thanks Eric - is there anything special in constructWizard()?
Derek
Re: programmatically call Import->Existing projects into workspace [message #329483 is a reply to message #329477] |
Wed, 25 June 2008 20:12 |
Derek wrote:
> Eric Rizzo wrote:
>> Derek wrote:
>>> Hi,
>> TreeSelection) {
>> dialog.open();
No, it is just an abstract method in the class that I pulled this from,
so that subclasses can control exactly what kind of wizard gets created.
In your case, you'd just need an instance of ExternalProjectImportWizard
(I think).
Eric
FUDForum. Page generated in 0.03967 seconds
