Selecting the message.properties files which should be used [message #329205] |
Mon, 16 June 2008 16:57 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I have a program which is used by two different departments. They want to
label the fields in the application differently.
This this I have created different message.properties files, e.g.
message.properties
message_app1.properties
message_app2.properties
I would like to select the correct property files via a startup parameter.
Is this possible and if how?
Best regards, Lars
Re: Selecting the message.properties files which should be used [message #329209 is a reply to message #329205] |
Mon, 16 June 2008 17:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Is this a question about developing Eclipse plugins, or is this a
straight standard Java application question? This newsgroup is for
Eclipse related questions.
Lars Vogel wrote:
> Hello,
> message.properties
> Best regards, Lars
Rich Kulp
Re: Selecting the message.properties files which should be used [message #329213 is a reply to message #329209] |
Mon, 16 June 2008 17:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The question is related to eclipse plug-ins and the mechnismus to select
message.properties files in Eclipse plug-in development.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:g368gd$9te$1@build.eclipse.org...
> Is this a question about developing Eclipse plugins, or is this a straight
> standard Java application question? This newsgroup is for Eclipse related
> questions.
> Lars Vogel wrote:
>> Hello,
>> message.properties
>> parameter. Is this possible and if how?
>> Best regards, Lars
> Rich Kulp
Re: Selecting the message.properties files which should be used [message #329217 is a reply to message #329211] |
Mon, 16 June 2008 19:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Tom,
cool, I didn't know about the -nl option. This should solve my problem.
Hm... any idea what to use to get this parameter? The documentation tells me
to use
BootLoader.getNL();
but this class is @deprecated and no longer relevant according to the source
code.
Best regards, Lars
Best regards, Lars
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:g368vq$hv7$1@build.eclipse.org...
>I think he is searching for the -nl command line option but I'm not sure
>about the following things:
> - NLS supports a 3 application specific suffix
> - One can leave out the first 2 parts
> My wild guess would be that they have to be named:
> message_de_DE_app1.properties and then one can use -nl de_DE_app1 when
> starting up eclipse but I'm not sure about it.
> Tom
>> Lars Vogel wrote:
>>> Hello,
>>> to label the fields in the application differently.
>>> message.properties
>>> Best regards, Lars
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
Re: Selecting the message.properties files which should be used [message #329219 is a reply to message #329217] |
Mon, 16 June 2008 19:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Tom,
I found it: Locale.getDefault().toString(); returns the passed parameter.
I can now read the correct properties via the following:
private static final String BUNDLE_NAME = "messages.messages_";
String nl = Locale.getDefault().toString();
NLS.initializeMessages(BUNDLE_NAME + nl, MessagesEclipse.class);
Thank you again, the -nl was extremely helpful. For the incorrect
documentation I opened a bug report.
Best regards, Lars
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:g36dmd$ase$1@build.eclipse.org...
> Hi Tom,
> me to use
> BootLoader.getNL();
> source code.
> Best regards, Lars
> Best regards, Lars
>> Tom
>>> Lars Vogel wrote:
>>>> Hello,
>>>> message.properties
>>>> Best regards, Lars
Re: Selecting the message.properties files which should be used [message #329267 is a reply to message #329221] |
Tue, 17 June 2008 18:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Tom,
yes works automatically.
Cool. Thank you again, Lars
news:g36fh6$cdr$1@build.eclipse.org...
> Lars Vogel schrieb:
>> Hi Tom,
> Hm. Isn't
> NLS.initializeMessages(BUNDLE_NAME, MessagesEclipse.class);
> enough?
> It looks to me NLS#buildVariants() should be enough if you fully qualify
> your bundlenames.
> So you should have:
> message.properties => English
> message_de.properties => German
> message_de_DE_app1.properties => German special1
> message_de_DE_app2.properties => German special2
> You could of course leave out message_de.properties and directly write
> your german strings to message.properties. You current approach missuses
> Locales as far as I could see.
> Tom
Re: Selecting the message.properties files which should be used [message #329323 is a reply to message #329221] |
Wed, 18 June 2008 18:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
In case someone else is interested in the approach, I documented it here:
http://www.vogella.de/articles/RichClientPlatform/article.ht ml#externalizestrings
Best regards, Lars
> Lars Vogel schrieb:
>> Hi Tom,
> Hm. Isn't
> enough?
> your bundlenames.
> So you should have:
> Tom
FUDForum. Page generated in 0.08294 seconds
