Home » Eclipse Projects » Eclipse Platform » customize strings/messages from WorkbenchMessages
Re: customize strings/messages from WorkbenchMessages [message #329050 is a reply to message #329049] |
Wed, 11 June 2008 11:03 |
Parvez,
I think you'd need to open the jar and change the *.properties file
with. Translations typically do this by providing *.properties files
that are applicable when in the corresponding locale. Are you looking
to do that, or to change the basic English strings?
PC wrote:
> I think earlier I posted in wrong group
> ( http://dev.eclipse.org/newslists/news.eclipse.technology.bab el/msg00080.html)
> I want to override/customize certain strings/messages from
> WorkbenchMessages
> But as this is in internal package i.e. org.eclipse.ui.internal
> So just wondering is there right way to do it?
> Any help will be appreciated.
> Thanks.
> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329082 is a reply to message #329051] |
Thu, 12 June 2008 08:47 |
Parvez Messages: 181 Registered: July 2009 |
Still thinking on the line of customizing English strings, I am just
wondering if there is no recommended way at the moment, then is it
possible to have extension point where messages.properties file can be
specified? Something like
http://publib.boulder.ibm.com/infocenter/sametime/v7r5m1/ind ex.jsp?topic=/com.ibm.help.sametime.admin.doc/st_adm_comm_cu stommessage_t.html
Any thoughts/suggestions?
Thanks.
- Parvez
PC wrote:
> Hi Ed,
> Yes, I am looking to change basic English strings which are in
> messages.properties under "org.eclipse.ui.internal" package and
> WorkbenchMessages class reads it.
> In my workspace, I have created a nl fragment for
> "org.eclipse.ui.workbench" plugin and other language properties files
> (like messages_de.properties) are picked up from it (earlier
> Fragment-Host value was wrong), but I am not sure what do for English
> strings i.e. messages.properties.
> Any suggestions?
> Thanks.
> - Parvez
> Ed Merks wrote:
>> Parvez,
>> PC wrote:
>>> Hi,
>>> WorkbenchMessages
>>> Thanks.
>>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329086 is a reply to message #329082] |
Thu, 12 June 2008 10:49 |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236829
> Thanks.
> - Parvez
> PC wrote:
>> Hi Ed,
>> Any suggestions?
>> Thanks.
>> - Parvez
>> Ed Merks wrote:
>>> Parvez,
>>> files that are applicable when in the corresponding locale. Are you
>>> looking to do that, or to change the basic English strings?
>>> PC wrote:
>>>> Hi,
>>>> WorkbenchMessages
>>>> Thanks.
>>>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329088 is a reply to message #329082] |
Thu, 12 June 2008 12:29 |
Parvez,
No, the English strings are not designed to be replaced. Imagine
multiple different plugins trying to do that and then all running in one
application: which replacement wins? So opening the jar and changing
the properties seems like the only way to go (other than perhaps faking
a locale and treating the strings you want to replace as translations
for that locale)...
> Thanks.
> - Parvez
> PC wrote:
>> Hi Ed,
>> Any suggestions?
>> Thanks.
>> - Parvez
>> Ed Merks wrote:
>>> Parvez,
>>> PC wrote:
>>>> Hi,
>>>> WorkbenchMessages
>>>> Thanks.
>>>> - Parvez
Re: customize strings/messages from WorkbenchMessages [message #329089 is a reply to message #329088] |
Thu, 12 June 2008 12:46 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Why faking a locale. The last part of the locale is designed to be
application specific.
messages_de_AT_beso.properties at least it is for ResourceBundle I don't
know how NLS uses this kind of thing.
Tom
Ed Merks schrieb:
> Parvez,
> for that locale)...
>> Thanks.
>> - Parvez
>> PC wrote:
>>> Hi Ed,
>>> Any suggestions?
>>> Thanks.
>>> - Parvez
>>> Ed Merks wrote:
>>>> Parvez,
>>>> PC wrote:
>>>>> Hi,
>>>>> WorkbenchMessages
>>>>> Thanks.
>>>>> - Parvez
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: customize strings/messages from WorkbenchMessages [message #329090 is a reply to message #329089] |
Thu, 12 June 2008 13:31 |
Sometimes a word could have a different meaning in a tool which is
targeted for a specific industry e.g. resource, perspective etc.
Though I see the point that different plugins overriding same thing, but
these scenarios can be applied to any other objects as well.
There were other thoughts:
a. Class can be removed from internal package so that individual can
provide another messages.properties.
b. messages.properties file from user defined nl fragment should be
given preference.
But now I tried messages_en.properties instead of messages.properties in
fragment and it worked.
Thanks Ed and Tom.
Parvez
> Tom
> Ed Merks schrieb:
>> Parvez,
>> one application: which replacement wins? So opening the jar and
>> changing the properties seems like the only way to go (other than
>> perhaps faking a locale and treating the strings you want to replace
>> as translations for that locale)...
>>> be specified? Something like
>>> Thanks.
>>> - Parvez
>>> PC wrote:
>>>> Hi Ed,
>>>> files (like messages_de.properties) are picked up from it (earlier
>>>> English strings i.e. messages.properties.
>>>> Any suggestions?
>>>> Thanks.
>>>> - Parvez
>>>> Ed Merks wrote:
>>>>> Parvez,
>>>>> you looking to do that, or to change the basic English strings?
>>>>> PC wrote:
>>>>>> Hi,
>>>>>> WorkbenchMessages
>>>>>> Thanks.
>>>>>> - Parvez
Current Time: Tue Sep 17 17:29:16 GMT 2024
Powered by FUDForum. Page generated in 0.07363 seconds
