Eclipse program crashes when launched with Java Web Start - query [message #32892] |
Sat, 02 November 2002 17:11 |
Ã?yvind Harboe![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=oyvind.harboe%40zylin.com) Messages: 11 Registered: July 2009 |
I'm trying to find out why my Eclipse "hello world" application crashes
when launched with Java Web Start(output below). It works like a charm
when launched from the command line using -Djava.library.path to point to
the native libraries.
Configuration:
- Red hat 8.0(VMWare).
- Gnome
- SWT 2049
The entire application is available upon request(mail me).
An irrecoverable stack overflow has occurred.
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4CD296B6
Function=XFindContext+0x6
Library=/usr/X11R6/lib/libX11.so.6
Current Java thread:
at org.eclipse.swt.internal.motif.OS.XmCreateScrollBar(Native
Method)
- locked <0x4886bc88> (a java.lang.Class)
at
org.eclipse.swt.widgets.Display.initializeComposite(Display. java:1088)
at org.eclipse.swt.widgets.Display.init(Display.java:1043)
at org.eclipse.swt.graphics.Device.<init>(Device.java:113)
at org.eclipse.swt.widgets.Display.<init>(Display.java:319)
at org.eclipse.swt.widgets.Display.<init>(Display.java:316)
at Chat.createGUI(Chat.java:50)
at Chat.run(Chat.java:36)
at Chat.main(Chat.java:161)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at com.sun.javaws.Launcher.executeApplication(Launcher.java:778 )
at com.sun.javaws.Launcher.executeMainClass(Launcher.java:740)
at com.sun.javaws.Launcher.continueLaunch(Launcher.java:625)
at com.sun.javaws.Launcher.handleApplicationDesc(Launcher.java: 352)
at com.sun.javaws.Launcher.handleLaunchFile(Launcher.java:177)
at com.sun.javaws.Launcher.run(Launcher.java:145)
at java.lang.Thread.run(Thread.java:536)
Dynamic libraries:
08048000-0804d000 r-xp 00000000 08:02 930851
/usr/java/j2re1.4.1/bin/java
0804d000-0804e000 rw-p 00004000 08:02 930851
40000000-40012000 r-xp 00000000 08:02 718085 /lib/ld-2.2.93.so
40012000-40013000 rw-p 00012000 08:02 718085 /lib/ld-2.2.93.so
40013000-4001c000 r-xp 00000000 08:02 2530276
/usr/java/j2re1.4.1/lib/i386/native_threads/libhpi.so
4001c000-4001d000 ---p 00009000 08:02 2530276
4001d000-4001e000 rw-p 00009000 08:02 2530276
4001e000-40021000 r--s 00000000 08:02 2170984
/usr/java/j2re1.4.1/lib/ext/dnsns.jar
40021000-40025000 r-xp 00000000 08:02 1746320
/usr/X11R6/lib/libXtst.so.6.1
40025000-40026000 rw-p 00004000 08:02 1746320
40026000-40033000 r-xp 00000000 08:02 1844169
/lib/i686/libpthread-0.10.so
40033000-40036000 rw-p 0000d000 08:02 1844169
40057000-40059000 r-xp 00000000 08:02 718098 /lib/libdl-2.2.93.so
40059000-4005a000 rw-p 00001000 08:02 718098 /lib/libdl-2.2.93.so
4005a000-404be000 r-xp 00000000 08:02 1110419
/usr/java/j2re1.4.1/lib/i386/client/libjvm.so
404be000-404db000 rw-p 00463000 08:02 1110419
404eb000-404fd000 r-xp 00000000 08:02 718102 /lib/libnsl-2.2.93.so
404fd000-404fe000 rw-p 00012000 08:02 718102 /lib/libnsl-2.2.93.so
40500000-40521000 r-xp 00000000 08:02 1844167 /lib/i686/libm-2.2.93.so
40521000-40522000 rw-p 00021000 08:02 1844167 /lib/i686/libm-2.2.93.so
40522000-40531000 r-xp 00000000 08:02 1485730
/usr/java/j2re1.4.1/lib/i386/libverify.so
40531000-40533000 rw-p 0000e000 08:02 1485730
40533000-40552000 r-xp 00000000 08:02 1485731
/usr/java/j2re1.4.1/lib/i386/libjava.so
40552000-40554000 rw-p 0001e000 08:02 1485731
40554000-40569000 r-xp 00000000 08:02 1485733
/usr/java/j2re1.4.1/lib/i386/libzip.so
40569000-4056c000 rw-p 00014000 08:02 1485733
4056c000-41c39000 r--s 00000000 08:02 1485774
/usr/java/j2re1.4.1/lib/rt.jar
41c7c000-41c93000 r--s 00000000 08:02 1485754
/usr/java/j2re1.4.1/lib/sunrsasign.jar
41c93000-41d04000 r--s 00000000 08:02 1485756
/usr/java/j2re1.4.1/lib/jsse.jar
41d04000-41d17000 r--s 00000000 08:02 1485755
/usr/java/j2re1.4.1/lib/jce.jar
41d17000-41fd3000 r--s 00000000 08:02 1485772
/usr/java/j2re1.4.1/lib/charsets.jar
41ffb000-41ffc000 r-xp 00000000 08:02 522275
/usr/X11R6/lib/X11/locale/common/xlcUTF8Load.so.2
41ffc000-41ffd000 rw-p 00000000 08:02 522275
41ffd000-41fff000 r--s 00000000 08:02 947188
/home/oyvind/.javaws/cache/http/D10.0.0.2/P80/DMfun/RMchatx. jar
42000000-42126000 r-xp 00000000 08:02 1844165 /lib/i686/libc-2.2.93.so
42126000-4212b000 rw-p 00126000 08:02 1844165 /lib/i686/libc-2.2.93.so
4c3b3000-4c572000 r--p 00000000 08:02 473365
/usr/lib/locale/locale-archive
4c572000-4c580000 r--s 00000000 08:02 2170986
/usr/java/j2re1.4.1/lib/ext/ldapsec.jar
4c585000-4c58e000 r-xp 00000000 08:02 718118
/lib/libnss_files-2.2.93.so
4c58e000-4c58f000 rw-p 00008000 08:02 718118
4c793000-4c7b0000 r--s 00000000 08:02 2170983
/usr/java/j2re1.4.1/lib/ext/sunjce_provider.jar
4c7b0000-4c84f000 r--s 00000000 08:02 2170985
/usr/java/j2re1.4.1/lib/ext/localedata.jar
4c84f000-4c8e5000 r--s 00000000 08:02 1404178
/home/oyvind/javaws/javaws.jar
4c8e5000-4c8f7000 r-xp 00000000 08:02 1485736
/usr/java/j2re1.4.1/lib/i386/libnet.so
4c8f7000-4c8f8000 rw-p 00011000 08:02 1485736
4c979000-4c98e000 r--s 00000000 08:02 1404182
/home/oyvind/javaws/javaws-l10n.jar
4c98e000-4cbd0000 r-xp 00000000 08:02 1485741
/usr/java/j2re1.4.1/lib/i386/libawt.so
4cbd0000-4cbe5000 rw-p 00241000 08:02 1485741
4cc0a000-4cc7c000 r-xp 00000000 08:02 1485740
/usr/java/j2re1.4.1/lib/i386/libmlib_image.so
4cc7c000-4cc7d000 rw-p 00071000 08:02 1485740
4cc7d000-4cc83000 r--s 00000000 08:02 1762752
/usr/lib/gconv/gconv-modules.cache
4cc90000-4cc97000 r-xp 00000000 08:02 1746310
/usr/X11R6/lib/libXp.so.6.2
4cc97000-4cc98000 rw-p 00006000 08:02 1746310
4cc98000-4cce6000 r-xp 00000000 08:02 1746318
/usr/X11R6/lib/libXt.so.6.0
4cce6000-4ccea000 rw-p 0004d000 08:02 1746318
4ccea000-4ccf2000 r-xp 00000000 08:02 1746288
/usr/X11R6/lib/libSM.so.6.0
4ccf2000-4ccf3000 rw-p 00007000 08:02 1746288
4ccf3000-4cd07000 r-xp 00000000 08:02 1746284
/usr/X11R6/lib/libICE.so.6.3
4cd07000-4cd08000 rw-p 00013000 08:02 1746284
4cd0a000-4cd17000 r-xp 00000000 08:02 1746298
/usr/X11R6/lib/libXext.so.6.4
4cd17000-4cd18000 rw-p 0000c000 08:02 1746298
4cd18000-4cdf3000 r-xp 00000000 08:02 1746290
/usr/X11R6/lib/libX11.so.6.2
4cdf3000-4cdf6000 rw-p 000da000 08:02 1746290
4cdf6000-4ceb6000 r-xp 00000000 08:02 1485743
/usr/java/j2re1.4.1/lib/i386/libfontmanager.so
4ceb6000-4ceb7000 ---p 000c0000 08:02 1485743
4ceb7000-4cede000 rw-p 000c0000 08:02 1485743
4cf5f000-4cf7b000 r-xp 00000000 08:02 522273
/usr/X11R6/lib/X11/locale/common/ximcp.so.2
4cf7b000-4cf7d000 rw-p 0001b000 08:02 522273
4d202000-4d2da000 r--s 00000000 08:02 947185
/home/oyvind/.javaws/cache/http/D10.0.0.2/P80/DMfun/RMlinux_ swt.jar
4d35b000-4d4df000 r-xp 00000000 08:02 131269
/home/oyvind/.javaws/cache/http/D10.0.0.2/P80/DMfun/RNlinux_ swt_lib.jar/libXm.so
4d4df000-4d4f2000 rw-p 00183000 08:02 131269
4d4f3000-4d538000 r-xp 00000000 08:02 131285
/home/oyvind/.javaws/cache/http/D10.0.0.2/P80/DMfun/RNlinux_ swt_lib.jar/libswt-motif-2049.so
4d538000-4d53b000 rw-p 00044000 08:02 131285
Local Time = Sat Nov 2 18:34:45 2002
Elapsed Time = 21
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (Blackdown-1.4.1-beta mixed mode)
# An error report file has been saved as hs_err_pid10729.log.
# Please refer to the file for further information.
FUDForum. Page generated in 0.02861 seconds
