Re: delete action as object contribution ... [message #329081 is a reply to message #329004] |
Thu, 12 June 2008 08:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Carmelo ![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=carmeloscala%40hotmail.com) Messages: 224 Registered: July 2009 |
From Rahul Kamdar
Object contribution will add your action as you said to the context menu. In
order to override the default key/Edit>Delete you need to retarget these
actions.
As far as the navigator is concerned, I think you need to implement the
requisite methods. I am not writing my own Navigator, am just extending the
native Eclipse Project Explorer and have defined actionProviders that
override the default ones for Open, Edit and Refactor actions.
For your reference, my action provider is as follows:
<actionProvider
class="com......cnf.action.providers.EditActionProvider"
id="com......explorer.actionProvider.EditAction"
overrides="org.eclipse.ui.navigator.resources.actions.EditActions ">
<enablement>
</enablement>
</actionProvider>
In this actionProvider I have written my own cut/copy/paste/delete actions
and further in the action Provider class (one that extends
CommonActionProvider) in the fillActionBars method, I set these actions as
the default using:
IActionBars.setGlobalActionHandler(ActionFactory.whatever_ac tion.getId(),
whatever_action);
Try and follow these and let me know if it works. You could copy/paste this
reply and further reply on the newsgroup itself so someone else can also
help you out.
Rahul
"KarSc" <carmeloscala@hotmail.com> ha scritto nel messaggio
news:g2lu9i$igb$1@build.eclipse.org...
> Hi Rahul,
> thanks for ur help and the article u send ... but honestly I'm quite
> confused now ...
> the point right now is:
> plain object contribution will just allow me to stick the action on the
> object displayed in a tree/table but there will no be key and global
> action association ...
> if I use the mechanism of the navigator can I still use a normal view
> which extends ViewPart or do I have necessarily implements all the methods
> in InavigatorContentService (honestly I don't know what method is
> important and must be coded)?
> if the answer is No. I have already tried ...
> - created the action provider
> <extension point="org.eclipse.ui.navigator.navigatorContent">
> <actionProvider
> class="com.inspector.ui.views.actions.PropertyActionProvider "
> id="com.inspector.ui.views.actions.PropertyActionProvider">
> </actionProvider>
> </extension>
> - added the action provider at the view using the navigatorContent
> extension (not sure is correct ... )
> still nothing work and no action is displayed.
> I will try to put in place an example using the eclipse plugin view
> example and I will see what I can do.
> any help will be appreciated.
> Ciao
> Kar
> "Rahul Kamdar" <rtkamdar@kamdars-india.com> ha scritto nel messaggio
> news:g2b092$jv2$1@build.eclipse.org...
>> You need to override the default delete and set the GlobalActionHandler
>> for delete action's id against your action implementation.
>> In order to override the default delete, you need to override the
>> EditActionsProvider
>> "org.eclipse.ui.navigator.resources.actions.EditActions". I do that using
>> a navigatorContent extension in my plugin.xml under a new actionProvider
>> for Edit Actions - retargeting cut/copy/paste/delete.
>> Then in your action provider, you need to
>> setGlobalActionHandler(ActionFactory.Delete.getId(), your delete action);
>> on the actionBars object given by the fillActionBars method.
>> Maybe you could refer to
>> http://scribbledideas.blogspot.com/2006/06/building-common-n avigator-_115067357450703178.html
>> Rahul
>> "KarSc" <carmeloscala@hotmail.com> wrote in message
>> news:g2anp3$qpi$1@build.eclipse.org...
>>> Hi all
>>> I have an object action that I would like to link to the global action
>>> EDIT/DELETE .
>>> I can see my action correctly activate in the popupMenus on the selected
>>> object type . but cannot link it with the edit/delete menu + plus key
>>> action
>>> delete .
>>> Does anyone can help me?
>>> Thanks
>>> Kar
FUDForum. Page generated in 0.03783 seconds
