| Home » Eclipse Projects » Eclipse Platform » Eclipse Shutdown Problem
 Goto Forum:|
| Eclipse Shutdown Problem [message #328714] | Mon, 02 June 2008 13:29  |  |
| Eclipse User  |  |  |  |  | Occasionally, in haste, I exit windows before exiting Eclipse. When I subsequently attempt to restart eclipse (on the workspace that was open
 when I prematurely exited from windows), the launch process hangs up on
 the splash screen, with some of the progress bar showing green. Other
 workspaces are unaffected.
 My work-around has been (apart from taking more care when exiting
 windows), to delete the .metadata/ directory in the affected workspace,
 using the file-system browser, then to open the workspace (which
 initially has no projects), then to import all the projects. Not
 surprisingly, I also loose my java code templates, and other settings,
 at this point.
 Recently I have found that deleting just the
 ../metadata/org.eclipse.core.resources directory gets around the
 workspace launch problem, but other problems (launching ant project
 builders) emerge. It seems that Eclipse is not able to handle my
 disorderly conduct (not able to respond appropriately to shutdown
 warnings from windows).
 Is there a better workaround than deleting .metadata/ ?
 Should I report this as a bug?
 Bill.
| Re: Eclipse Shutdown Problem [message #328715 is a reply to message #328714] | Mon, 02 June 2008 13:35   |  |
| Eclipse User  |  |  |  |  | Bill Winspur wrote: > Occasionally, in haste, I exit windows before exiting Eclipse. When I
 > at this point.
 > Bill.
 I should have mentioned, I am running 3.3.1.1 on XP
| Re: Eclipse Shutdown Problem [message #328719 is a reply to message #328715] | Mon, 02 June 2008 14:49   |  |
 >> open when I prematurely exited from windows), the launch process hangs
 >> up on the splash screen, with some of the progress bar showing green.
 >> Other workspaces are unaffected.
 >> workspace, using the file-system browser, then to open the workspace
 >> (which initially has no projects), then to import all the projects.
 >> Not surprisingly, I also loose my java code templates, and other
 >> settings, at this point.
 >> Bill.
 Apologies, on further investigation, the .metadata/.log file indicates
 that this may be a problem with a third party product (OxygenXML), so
 I'll take it to them.
| Re: Eclipse Shutdown Problem [message #328832 is a reply to message #328714] | Wed, 04 June 2008 12:59  |  |
| Eclipse User  |  |  |  |  | If Eclipse hangs (during startup or otherwise), have a look at: http://wiki.eclipse.org/How_to_report_a_deadlock
 Boris
 "Bill Winspur" <bwinspur@wynnon.com> wrote in message
 news:g21a3d$igq$1@build.eclipse.org...
 > using the file-system browser, then to open the workspace (which initially
 > has no projects), then to import all the projects. Not surprisingly, I
 > also loose my java code templates, and other settings, at this point.
 > ./metadata/org.eclipse.core.resources directory gets around the workspace
 > launch problem, but other problems (launching ant project builders)
 > emerge. It seems that Eclipse is not able to handle my disorderly conduct
 > (not able to respond appropriately to shutdown warnings from windows).
 > Bill.
 Current Time: Thu Oct 30 20:02:41 EDT 2025
 Powered by FUDForum . Page generated in 1.06015 seconds |
