Re: Can I open several workspaces with one running Eclipse instance [message #328694 is a reply to message #328683] |
Mon, 02 June 2008 11:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Danail,
starting several Eclipse instance consume a lot of memory.
Best regards, Lars
"Danail Nachev" <d.nachev@prosyst.bg> wrote in message
news:g20bf4$nmb$1@build.eclipse.org...
> Why don't you just launch Eclipse installation several times with
> different workspaces?
> BR,
> Danail
> Lars Vogel wrote:
>> Hi,
>> is it possible to start / view several workspaces at the same time in one
>> running Eclipse instance?
>> Switching between workspaces takes a long time while starting several
>> Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328701 is a reply to message #328695] |
Mon, 02 June 2008 13:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Danail,
ok. Thank you. Best regards, Lars
news:g20m89$ktv$1@build.eclipse.org...
> Unfortunately there is no other way if you want to work with multiple
> workspaces at once.
> Lars Vogel wrote:
>> Hi Danail,
>> Best regards, Lars
>>> BR,
>>> Danail
>>> Lars Vogel wrote:
>>>> Hi,
>>>> one
>>>> Best regards, Lars
Re: Can I open several workspaces with one running Eclipse instance [message #328702 is a reply to message #328697] |
Mon, 02 June 2008 14:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Tom,
Yes I'm using working sets already. Still, as I'm developing some really
different things I like to have them also separated in Workspaces, e.g. my
private developments vrs. my work developments.
But opening several Eclipse instances is not really a big problem, I just
wanted to be sure that I'm not missing something.
Thank you, Lars
Best regards, Lars
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:g20mh5$m0s$1@build.eclipse.org...
> Are you familiar with working sets? This way you have 1 workspace and
> configure it for different projects you work on. The others are hidden.
> Tom
> Lars Vogel schrieb:
>> Hi Danail,
>> Best regards, Lars
>>> BR,
>>> Danail
>>> Lars Vogel wrote:
>>>> Hi,
>>>> one
>>>> Best regards, Lars
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
FUDForum. Page generated in 0.03522 seconds
