Home » Eclipse Projects » Eclipse Platform » Best strategy to bind handler to a control
Best strategy to bind handler to a control [message #327855] Tue, 06 May 2008 13:46 Go to next message
Teddy Walker is currently offline Teddy WalkerFriend
What is the best strategy to activate command handlers for a single
control? For example, bind a special handler for the copy command to
each control in a form or a dialog. Three ideas:
1) Use IServiceLocatorCreator to create a handler service for each
control and activate/deactivate the ServiceLocator on focus change
- internal code, will it be public in future versions?
- it works
2) Create an expression for each control, use it when register the
handlers and reevaluate it on focus change
- does this work?
3) Write a "wrapper handler" selecting the handler of the control which
has the focus
- requires most new code
Teddy
Re: Best strategy to bind handler to a control [message #327958 is a reply to message #327855] Fri, 09 May 2008 13:45 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Within one context (like your dialog or form), one common pattern is to
activate one handler and have it delegate to different controls in
focus. Similar to org.eclipse.ui.actions.TextActionHandler for actions.
Another way would be to use the IFocusService to register the controls
that can accept focus, and then use IHandlerService to activate the
handlers for those controls (also available declaratively while using
org.eclipse.ui.handlers)
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Best strategy to bind handler to a control [message #328257 is a reply to message #327958] Tue, 20 May 2008 12:04 Go to previous message
Hi Paul,
thank you very much. I didn't know IFocusService - it works fine!
Teddy
Paul Webster wrote [2008-05-09 15:45]:
> PW
Previous Topic:Tableviewer with databinding and inline edit support for boolean
Next Topic:Launching 3.4M7 as PDE runtime workbench from Eclipse 3.3.2
Current Time: Thu Jan 02 13:17:12 GMT 2025
Powered by FUDForum. Page generated in 0.04064 seconds
