Home » Eclipse Projects » Eclipse Platform » [Databinding] Problem with MasterDetail and EObjectObservableMap
| [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328173] |
Fri, 16 May 2008 06:27   |
Eclipse User  |
I am using a  org.eclipse.jface.databinding.viewers.ObservableListTreeCont entProvider as content provider in my master
tree view. I use a IObservableFactory which provides a combination of two IObservableList lists like follows:
public IObservable createObservable(Object target) {
     final IObservableList list1 = EMFEditObservables.observeList(domain, target, XYZPackage.Literals.TARGET_FEATURE1);
     final IObservableList list2 = EMFEditObservables.observeList(domain, target, XYZPackage.Literals.TARGET_FEATURE2);
     return new UnionList(new IObservableList[] {categoryList, childList});
     return new ComputedList() {
         protected List calculate() {
             List list = new ArrayList(list1.size()+list2.size());
     	    list.addAll(list1);
     	    list.addAll(list2);
     	    return list;
So now I have objects in my tree which represent different features, and so I have different details pages.
In the details pages, I have code like this:
IObservableValue selection = ViewersObservables.observeSingleSelection(viewer); //viewer is the master view tree viewer
EMFEditObservables.observeDetailList(realm, domain, selection, XYZPackage.Literals.FEATURE_OF_SELECTION));
And here is my problem: EMFEditObservables uses a IObservableFactory which assumes that the target (=selection) is
always an EObject having the specified feature:
         return observeList(realm, domain, (EObject)target, eStructuralFeature);
If the above method was changed to the following:
         if  (eStructuralFeature.getEContainingClass().isSuperTypeOf(((EO bject)target).eClass()))
         return null;
then my problem is gone.
Before opening a bug I just wanted to ask if this is the right way to solve it or if I should have done something different?
Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328174 is a reply to message #328173] |
Fri, 16 May 2008 06:55    |
Eclipse User  |
Sorry, the method in EMFEditObservables has to be changed to:
         if  (eStructuralFeature.getEContainingClass().isSuperTypeOf(((EO bject) target).eClass()))
         return new EmptyObservableList(realm, eStructuralFeature);
i.e. we must not return null here.
Michael
Michael Haeberlen wrote:
> I am using a
> as content provider in my master tree view. I use a IObservableFactory
>             list.addAll(list1);
>             list.addAll(list2);
>             return list;
> which assumes that the target (=selection) is always an EObject having
>         if
>         return null;
> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328183 is a reply to message #328174] |
Fri, 16 May 2008 10:08    |
Eclipse User  |
Michael,
This approach would end up not supporting open content features, i.e.,
features of a document root that are accepted by a wildcard feature of
the actual class.  I don't think you should be applying it for invalid
cases.  I believe it fails with an exception right now if you do that,
which seems to me the right approach.
>         if
> target).eClass()))
> Michael
>> Hi,
>> I am using a
>> childList});
>>             list.addAll(list1);
>>             list.addAll(list2);
>>             return list;
>>         if
>>         return null;
>> Thanks,
>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328186 is a reply to message #328183] |
Fri, 16 May 2008 10:38    |
Eclipse User  |
Ed,
I'm not quite sure I understand. (actually I don't know what a "wildcard feature" is). So, you are saying that the
solution I sketched will not work in general? Would you agree that in my special case I described it does work? Or do
you see problems even there? (however, I don't think this solution makes it worse, logically at least).
Or are you saying that I should not use a ComputedList the way I did in order to combine the two lists? (btw., forget
the line with the "UnionList" it should have been commented out)
The other question is what else could I do in order to fix the problem (and still use (emf-)databinding) ?
Michael
Ed Merks wrote:
> Michael,
>>         if
>> target).eClass()))
>> Michael
>>> Hi,
>>> I am using a
>>> childList});
>>>             list.addAll(list1);
>>>             list.addAll(list2);
>>>             return list;
>>>         if
>>>         return null;
>>> Thanks,
>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328188 is a reply to message #328186] |
Fri, 16 May 2008 10:57    |
Eclipse User  |
Michael,
> Ed,
They're kind of annoying confusing things, but necessary to support XML
Schema-based models.
> So, you are saying that the solution I sketched will not work in general?
It's not a general change that I would put in the framework no, because
there would be cases it disables that would work well today.
I can imagine why you'd want an empty list in specialized cases where
you're trying to view objects but not all are uniforming of a type where
the feature is applicable.
> Or do you see problems even there? (however, I don't think this
I'm not sure what would happen if you tried to modify the empty list,
but maybe that's not an issue.
> in order to combine the two lists? (btw., forget the line with the
No, my comment was purely about what the base framework does, not about
how you might specialize it in specific scenarios.
I'm not sure the problem was entirely sketched out in a way that I
understand it.  Whatever makes it work for you is fine.  You just talked
about opening a bug, and I'm commentingon the fact that I don't see the
behavior in the base framework as a bug.  The framework is not intended
to gracefully support creating no-op/empty observables for features that
have no meaning relative to the target object.
> Michael
> Ed Merks wrote:
>> Michael,
>> i.e., features of a document root that are accepted by a wildcard
>> feature of the actual class.  I don't think you should be applying it
>> for invalid cases.  I believe it fails with an exception right now if
>> you do that, which seems to me the right approach.
>>>         if
>>> target).eClass()))
>>> Michael
>>>> Hi,
>>>> I am using a
>>>> childList});
>>>>             list.addAll(list1);
>>>>             list.addAll(list2);
>>>>             return list;
>>>>         if
>>>>         return null;
>>>> Thanks,
>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328287 is a reply to message #328186] |
Tue, 20 May 2008 14:08    |
Eclipse User  |
Michael,
I would be surprised if you could not implement a variant of
EMFEditObservables.observeDetailList that works the way you need it to.  The
method observeDetailList is a convenience method for
MasterDetailObservables.detailList(master, listFactory, propertyType); you
should be able to write a list factory that wraps the original one but first
performs whatever checks you need.
Boris
"Michael Haeberlen" <haeber@de.ibm.com> wrote in message
news:g0k68c$8vi$1@build.eclipse.org...
> Ed,
> feature" is). So, you are saying that the solution I sketched will not
> does work? Or do you see problems even there? (however, I don't think this
> Michael
> Ed Merks wrote:
>> Michael,
>>>         if
>>> target).eClass()))
>>> Michael
>>>> Hi,
>>>> I am using a
>>>> childList});
>>>>             list.addAll(list1);
>>>>             list.addAll(list2);
>>>>             return list;
>>>>         if
>>>>         return null;
>>>> Thanks,
>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328477 is a reply to message #328287] |
Mon, 26 May 2008 08:34    |
Eclipse User  |
Boris,
thanks for your hint, in fact, this is exactly what I already did. The point that I was trying to make - and I admit
that  this has not been very clear - is that I was hoping that this functionality could - somehow? - be provided by the
framework itself. I still think that the scenario described by me is not a "special" case, I rather tend to claim that
this is the "general" case and the EMFEditObservables "only" handles a "special" case (where all children of the master
list are of the same type).
Michael
Boris Bokowski wrote:
> Michael,
> Boris
>> Ed,
>> Thanks,
>> Michael
>> Ed Merks wrote:
>>> Michael,
>>>>         if
>>>> target).eClass()))
>>>> Michael
>>>>> Hi,
>>>>> I am using a
>>>>> childList});
>>>>>             list.addAll(list1);
>>>>>             list.addAll(list2);
>>>>>             return list;
>>>>>         if
>>>>>         return null;
>>>>> Thanks,
>>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328482 is a reply to message #328188] |
Mon, 26 May 2008 09:02    |
Eclipse User  |
Ed,
sorry, I have been on vacation for a week, but if you don't mind I'd like to continue this discussion a little bit. I've
put some specific comments below:
Ed Merks wrote:
> Michael,
>> Ed,
As I already mentioned in my reply to Boris, I rather think that the base framework "only" handles a special case in
Master-Detail scenarios, namely those where the Master list contains only elements of the same type, whereas the usecase
described by me is more general. The question is of course if this case can be handled by the framework at all or if
customizations are unavoidable.
This is of course my fault and I apologize both for the bad description and for being suggestive of considering the
current behavior as a bug, which I don't. To give a concrete example of what I mean, consider the a file system model
like the one that you presented in  http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html (ignoring
the extensibility features described there) Here a selection in the master can either be a "File" or a "Folder". If I
want to present a feature which is only present for "File" in my details part and use
EMFEditObservables.observeDetailValue as-is, I get into trouble. And the problem is, that
EMFEditObservables.valueFactory assumes that "eStructuralFeature" is a feature of "target" (using the variable names of
the implementation), and it even does not check if this is the case (potentially) causing strange runtime errors.
>> Thanks,
>> Michael
>> Ed Merks wrote:
>>> Michael,
>>>>         if
>>>> target).eClass()))
>>>> Michael
>>>>> Hi,
>>>>> I am using a
>>>>> childList});
>>>>>             list.addAll(list1);
>>>>>             list.addAll(list2);
>>>>>             return list;
>>>>>         if
>>>>>         return null;
>>>>> Thanks,
>>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328490 is a reply to message #328482] |
Mon, 26 May 2008 10:39    |
Eclipse User  |
Michael,
Comments below.
> Ed,
> like to continue this discussion a little bit. I've put some specific
> comments below:
> Ed Merks wrote:
>> Michael,
>>> Ed,
>> XML Schema-based models.
>>> general?
>> because there would be cases it disables that would work well today.
>> where the feature is applicable.
>> about how you might specialize it in specific scenarios.
> base framework "only" handles a special case in Master-Detail
> of the same type, whereas the usecase described by me is more general.
> at all or if customizations are unavoidable.
I still don't see how this generally  makes sense.  You might have a
feature that's multi-valued so you return a list that can be modified.
The list might be empty.  Then in other cases you return an empty list
that can't be modified.  I don't see how the downstream code can deal
with it sometimes being modifiable and sometimes not.
>> talked about opening a bug, and I'm commentingon the fact that I
>> don't see the behavior in the base framework as a bug.  The framework
>> is not intended to gracefully support creating no-op/empty
>> observables for features that have no meaning relative to the target
>> object.
> description and for being suggestive of considering the current
> mean, consider the a file system model like the one that you presented
> in
> (ignoring the extensibility features described there) Here a selection
> in the master can either be a "File" or a "Folder". If I want to
> and use EMFEditObservables.observeDetailValue as-is, I get into
> trouble. And the problem is, that EMFEditObservables.valueFactory
> variable names of the implementation), and it even does not check if
Probably any runtime error will be considered strange, but it can only
be check at runtime.  We could certainly check for validity at the time
the observable is created, so I'd be open to adding such a fail-faster
check. But I still don't understand how returning a read-only list is a
good thing. E.g., how will the details view indicate that some field is
not actually bound to an editable feature?  I.e., shouldn't the widget
that controls the value be disabled?
Again, I've not used the framework for any significant development work
myself, which is why it's marked as provisional API.  Hopefully in the
next release I'll have an opportunity for that.
>>> Thanks,
>>> Michael
>>> Ed Merks wrote:
>>>> Michael,
>>>> it for invalid cases.  I believe it fails with an exception right
>>>> now if you do that, which seems to me the right approach.
>>>>>         if
>>>>> target).eClass()))
>>>>> Michael
>>>>>> Hi,
>>>>>> I am using a
>>>>>> childList});
>>>>>>             list.addAll(list1);
>>>>>>             list.addAll(list2);
>>>>>>             return list;
>>>>>>         if
>>>>>>         return null;
>>>>>> Thanks,
>>>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328529 is a reply to message #328490] |
Tue, 27 May 2008 07:59    |
Eclipse User  |
Ed,
comments below.
Ed Merks wrote:
> Michael,
> Comments below.
>> Ed,
>> comments below:
>> Ed Merks wrote:
>>> Michael,
>>>> Ed,
>>>> general?
I agree that it does not make too much sense. But given the fact that createObservable() gets called (by
 org.eclipse.core.internal.databinding.observable.masterdetai l.DetailObservableValue#updateInnerObservableValue()
with an EObject argument which does NOT have the given feature, the current implementation makes even less sense.
Returning null as I suggested initially does not work either.
But maybe I was just trying to "cure the symptoms" rather than looking for the root cause of the problem, which is that
createObservable() is called with an argument that does not make sense?
Here what happens before createObservable() called:
The situation occurs if I change the selection in the master view.
Once there is a SelectionChangedEvent,
 org.eclipse.jface.internal.databinding.viewers.SelectionProv iderSingleSelectionObservableValue creates and fires a
ValueChangeEvent which the outerChangeListener(s) in DetailObservableValue handle (and call updateInnerObservableValue()).
This is all JFace Databinding code, so is there a problem in that framework? Or am I just using the frameworks in the
wrong way (which is always my first working hypothesis, you know, but I just don't see what I could do differently)?
>>> object.
>> in
No, you have different detail views for each selection.
>>>> Thanks,
>>>> Michael
>>>> Ed Merks wrote:
>>>>> Michael,
>>>>>>         if
>>>>>> target).eClass()))
>>>>>> Michael
>>>>>>> Hi,
>>>>>>> I am using a
>>>>>>> childList});
>>>>>>>             list.addAll(list1);
>>>>>>>             list.addAll(list2);
>>>>>>>             return list;
>>>>>>>         if
>>>>>>>         return null;
>>>>>>> Thanks,
>>>>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328532 is a reply to message #328529] |
Tue, 27 May 2008 08:51    |
Eclipse User  |
Michael,
Comments below.
> Ed,
> comments below.
> Ed Merks wrote:
>> Michael,
>> Comments below.
>>> Ed,
>>> Ed Merks wrote:
>>>> Michael,
>>>>> Ed,
>>>>> general?
>>>> where you're trying to view objects but not all are uniforming of a
>>>> type where the feature is applicable.
>>>> list, but maybe that's not an issue.
>>>>> did in order to combine the two lists? (btw., forget the line with
>>> the framework at all or if customizations are unavoidable.
>> modified.  The list might be empty.  Then in other cases you return
>> an empty list that can't be modified.  I don't see how the downstream
>> code can deal with it sometimes being modifiable and sometimes not.
> current implementation makes even less sense. Returning null as I
> for the root cause of the problem, which is that createObservable() is
> creates and fires a ValueChangeEvent which the outerChangeListener(s)
> framework? Or am I just using the frameworks in the wrong way (which
Given my complete lack of experience with how to use the framework in an
application I'm at a loss to provide anything insightful to say.
>>>> framework is not intended to gracefully support creating
>>>> no-op/empty observables for features that have no meaning relative
>>> I mean, consider the a file system model like the one that you
>>> presented in
>>> details part and use EMFEditObservables.observeDetailValue as-is, I
>>> a feature of "target" (using the variable names of the
>> only be check at runtime.  We could certainly check for validity at
>> the time the observable is created, so I'd be open to adding such a
>> fail-faster check. But I still don't understand how returning a
>> read-only list is a good thing. E.g., how will the details view
>> indicate that some field is not actually bound to an editable
>> feature?  I.e., shouldn't the widget that controls the value be
>> disabled?
So I'd imagine the details view should not need to (obviously can't)
access features that aren't appropriate for the selection.
Again, sorry that I don't understand the picture.  Perhaps if you
provided a running example I'd be in a better position to try it to
gather insights...
>> work myself, which is why it's marked as provisional API.  Hopefully
>> in the next release I'll have an opportunity for that.
>>>>> Thanks,
>>>>> Michael
>>>>> Ed Merks wrote:
>>>>>> Michael,
>>>>>> applying it for invalid cases.  I believe it fails with an
>>>>>> exception right now if you do that, which seems to me the right
>>>>>> approach.
>>>>>>>         if
>>>>>>> target).eClass()))
>>>>>>> Michael
>>>>>>>> Hi,
>>>>>>>> I am using a
>>>>>>>> childList});
>>>>>>>>             list.addAll(list1);
>>>>>>>>             list.addAll(list2);
>>>>>>>>             return list;
>>>>>>>> is always an EObject having the specified feature:
>>>>>>>>         if
>>>>>>>>         return null;
>>>>>>>> Thanks,
>>>>>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328579 is a reply to message #328532] |
Tue, 27 May 2008 16:51    |
Eclipse User  |
--------------080403010306060206020904
Ed,
ok, I spent some time to create a demo showing the issue. (sorry, but you were asking for it ;-))
In the attached zip there is a demo project with a .genmodel. You will have to generate model (a basket containing
apples and pears), edit and editor code and copy the provided files from the editor project. I am working in a 3.3
workspace but use all databinding stuff from 3.4. I just added an additional page to the generated multipage editor to
display the fruits. You will have to create a model with an apple and a pear in the basket and then go to the
master-detail page. select the apple and then select the pear and you will get a NPE.
Thanks for your patience,
Michael
Ed Merks wrote:
> Michael,
> Comments below.
>> Ed,
>> comments below.
>> Ed Merks wrote:
>>> Michael,
>>> Comments below.
>>>> Ed,
>>>> Ed Merks wrote:
>>>>> Michael,
>>>>>> Ed,
>>>>>> general?
>>>> presented in
>>> disabled?
> gather insights...
>>>>>> Thanks,
>>>>>> Michael
>>>>>> Ed Merks wrote:
>>>>>>> Michael,
>>>>>>> approach.
>>>>>>>>         if
>>>>>>>> target).eClass()))
>>>>>>>> Michael
>>>>>>>>> Hi,
>>>>>>>>> I am using a
>>>>>>>>> childList});
>>>>>>>>>             list.addAll(list1);
>>>>>>>>>             list.addAll(list2);
>>>>>>>>>             return list;
>>>>>>>>>         if
>>>>>>>>>         return null;
>>>>>>>>> Thanks,
>>>>>>>>> Michael
Content-Type: application/x-zip-compressed;
 name="demo.zip"
Content-Disposition: inline;
 filename="demo.zip"
 UEsDBBQACAAIAHe0uzgAAAAAAAAAAAAAAAAPAAAAZGVtby8uY2xhc3NwYXRo nZBPTwIxEMXP
 mvgdNr0zKxfjYVdizJpAIhhYvZLSTpaROi3TlsC3B/8QjQkcvM2b/Oa9l6kG 23dXbFAiea5V
 H65VgWy8Je5q9dI+9m7V4O7qsjJOxxh0Wh7ExY9CTrIrVsS2VlGMKj6WX2N5 mjSej6SXDtA4
 ChHhzSZwOrNZHtJhNG3mD5Nxez8cN9PyL0ecUFg7sLjIHWT6vkSBWdJstdjX p3YXsBzpjZ41
 vT7c/KNSsAjGC4LgOpOgfXa5I47nrHxOIaej24L4E67K3y/cA1BLBwj0pbHS 0AAAAHgBAABQ
 SwMEFAAIAAgAd7S7OAAAAAAAAAAAAAAAAA0AAABkZW1vLy5wcm9qZWN0vZLP isIwEMbPCr6D
 9G7i3jzECu7iTVno7gPEZKwpzR+SVPbxN0lTpYjgQbzN92W+/IZhyOZPtvML WCe0WhcfaFnM
 QTHNharXxe/PbrEqNuVsSozVDTD/BY5ZYXzoDu6EKCqh5CA1wamMHtNSgvIl wUMV3fyBSwKP
 1LETLa8MsKiy/AxRqnhyMkbbGgFrhXGAGu4R0zYU9EJTAOxthJCgtu4i22WN xwbBd5SnuIYD
 2lMlTuD89r3Yip1B0pdAszOsPPB8ZyF39+Lxtvv3OEDqe5SJI3+3XS3U4S4w 1JF4vYXxaf0D
 UEsHCCorfbzkAAAAmQIAAFBLAwQUAAgACAB3tLs4AAAAAAAAAAAAAAAAFQAA AGRlbW8vYnVp
 bGQucHJvcGVydGllc3WOMQoCMRBF+4G5Q8AtNbmAChYKW2hlaaPJsEayO2GS gN7exG5hne69
 B8NHWKmt5fgRPzzzHhuaGTfV9a5DQHj4SfvJhuIoqZ3S6xuCmt/IjoJZCOfj 9bDpL6elFkMZ
 6uv3GP7HKBxJsqeE8LpL0pbH6ANpFkfS1iAkLmJJ60pJrEHgkmPJP1G3V/EF UEsHCMO5lKSM
 AAAA8AAAAFBLAwQUAAgACAB3tLs4AAAAAAAAAAAAAAAAFgAAAGRlbW8vcGx1 Z2luLnByb3Bl
 cnRpZXOtUUFqwzAQvBv8hyGNb8G9l6YQsAuBxg6OPqDaG1tUkYTsRM3vK1kt tLcerNPuzu7s
 7ChNHvDcanO3oh+mlzSkj3/yUFrvu3WahGi7wAs8TKPVHaGjG0ltyD6FKlBo VDVDO3DVE6aB
 YGyAJ0Ej3mlyRMqXxQgpFIGrLjTF2VWWZSirAvUrWLOrTm87VhY4NvWxbNi+ PME3rObBPE4c
 +IfngCL3s+YOxS+0ATeGAreeNYRQn+fwLGRcGyVGngDM5/j+6xh1/ybNl7Nu yU/4j19LKjfy
 2gtVeYOxBaNxwsGbJj1g9U10ZL8h51xOn/xiJOXa9mnyBVBLBwh83Ai49QAA AKYCAABQSwME
 FAAIAAgAd7S7OAAAAAAAAAAAAAAAAA8AAABkZW1vL3BsdWdpbi54bWxNT7Fu wyAQ3S35HyjK
 CrTqElXYXqpIGSJ1SOfKgitBwYCAVMnfl4stJzege/ce793J4To58gcp2+A7 +sZfKQGvgrbe
 dPT7uGNbOvRtIwdQzsYMD+171SJVyRfG2oZIFeItWXMqPSLxDOtgs9ebtmFs /hLdxVg/M0TC
 tYBHWxKD9aWjIRm+JHKYfmsfEnADHtJYQP/EUZ1HAxSTaskFkxnWuiRLOkJP pcQPITRMgT5I
 5cackcY5/6zP1+K3SmrUIWhwqJqwEUfIBTe4I0pEf/eTYt19Pkysl/0DUEsH CB6MT1LZAAAA
 XAEAAFBLAwQUAAgACAB3tLs4AAAAAAAAAAAAAAAAGQAAAGRlbW8vTUVUQS1J TkYvTUFOSUZF
 U1QuTUZVkD9PwzAQxfdI+Q5e2LBFGRhcdQFlQS2qiMTuOtf0hP+Esx01/fQ4 SRXCdD693733
 5INyeIYQ+RdQQO8k24insnhNrjHAD3d1EZ8X6UNZkOyhM6lFNy6LUg/25A3q mWjA+i0L6FoD
 MVvsIqU/dp26yn0zKoSjihfJxIp1jacxk3yPDdC/1L3XyuBNxclurrWIn/CT kKCprqDTSFSu
 R/LOgouSvate1RXfiJeyqK6dp8iPSn+r9l7/sSymKdB2ZlmyjymLuzOfgyTz 1ArQBrsAQnsC
 QclFtDCerTWw5/zOwLbHgCc0GAe5I4ApP/eYOb5Xt6GOinLN+eN+AVBLBwi9 I54k+wAAALEB
 AABQSwMEFAAIAAgAd7S7OAAAAAAAAAAAAAAAABUAAABkZW1vL21vZGVsL1Rl c3QuZWNvcmWt
 k11rwjAYhe8F/0PIrjXqbkaxim4KwgbiB+w2xrc12KQlSVe3X783tRULG0xm LlJIznlyTtoO
 xyeVkA8wVqY6pP1ujxLQIt1LHYd0u5l3nuh41G4NQaQGgtmSiyOPgZyUDC6u AbraLYIDYdoG
 uBnSg3NZwFhRFN1Uxd3UxOz9bUFriW1KisdSMej1+ih7XYsDKN6R2jquBTTo ZZKGGUQiMwsl
 AVTkKQM28zJKNFco3oNKK4i229XiYi83cG1pIJKnSjjyyiE8J9xaGUmsSTBv 4D4zRFUXUW7W
 +Cm3R3Bnn3euncmFyw1P5sDxCT8AVhCBAV+ugkQmlw6ReZaBmaa53oe0069S +wGb0v/A2NxL
 KRGpdlxqBdqFFI8Eys7R2XX2m9tUdL6zznBRo28qN3HOyF3uLuX8TOsGleiF O+4XyJ9eJdae
 4dH4Xd6n5STLEh9pneN1+xj26mr/VzYz8usObRfa3afqErj5rak/APGNvxuX vgFQSwcI3fFA
 LnQBAAAYBAAAUEsDBBQACAAIAHe0uzgAAAAAAAAAAAAAAAAYAAAAZGVtby9t b2RlbC9UZXN0
 Lmdlbm1vZGVstZRfT9swFMXfkfgOkfe8uOsDmqKmCChBSANVE5P2apyb1ML/ dO20ZZ9+tpMA
 YVRDQuQp9j3n3N91rCxO90pmW0AnjC7Jt3xGMtDc1EK3Jfl1V339Tk6Xx0eL FrQyNcjiCvRN
 fMn2ShRPxnkwHh9l4Ql52hWhWJKN97agdLfb5Ua1ucGW/r65JoMEuEGYiIBL YR0kIaiGzmez
 Ob2Mskn2iPJ/78hKsmRYCQTuDT6WhNagDHXIh+RUX8uuFfp6VZJYHUy3TAXK O3CeZEJZgx4w
 SkKjp6ahYT7WcngBzI2yUjDN4QdsI/FJPGBu7COKduMrAbJ2JWmYdECW0bNo glu0Pfcytu0D
 F3RSSNJwEGvGH1gLLrMIjdiXZJXIa+GscexewhrNVtSAFRsm99hB+MYxczD3 0/VtvtAeo0+/
 kMy5EJ5KaTHV0nPmHsCPlt5UAfMdJiRjAX3oeWt06Mk3QtYIemTgGJRwEXcn WENASdKquPwJ
 DQQbh+yN3rTBTnhH6IhNn7nfmESoNHB/4IfnqmLogbEm2C+DXnOfeY/ivvOv uFM21eFavRf6
 IOaZtRI+CTNlU4viz8c518BwCEkR462NPxb6z58l7P4FUEsHCHcBE/zIAQAA lwQAAFBLAwQU
 AAgACAB3tLs4AAAAAAAAAAAAAAAAGQAAAGRlbW8vdGV4dC9kZXNjcmlwdGlv bi50eHSVkM1q
 wzAQhO8Gv8PcCgUrPYc00J8EcgiENi+wtte2iCwJaZ2kffpKaSgp9NLb7ux8 uyNtXcsGe45S
 FmWxH3TEeJFajk3QXrSzSKJ1AkJgMlht16AguqNGFDaCE0X0bDmQcIv6AzJw WbjQK26M9pEV
 j53iM43ecFRXqwvqSEa3uYI3U19pC3HQxkxR8i4M7pSv3cWyaFIo/JBoyKJm 8FnYttyqa/Sr
 3OpItUlZTloGVMeRQh9Rvf4n0mNHJtnyr+yoOVCf1vLosBhE/Hw2y80yT4EX QzHimeKBJffA
 G3cc2DaMLkxaIuZY52KxeFDqfvmLuwy+sSeRoOspvdzSyAlavSfB9rf2J58S o1r+zfmgPy/g
 xsottWMKN9AXUEsHCKzEDE0bAQAA9gEAAFBLAwQUAAgACAB3tLs4AAAAAAAA AAAAAAAAIAAA
 AGRlbW8uZWRpdG9yL01FVEEtSU5GL01BTklGRVNULk1GjZI/T8MwEMX3SvkO GehGLMrAkIoB
 UAZQiyqK2F3nEg78J5ztqO2nx0lKSFGQstl+737vzvaaayzAuuQNyKLRabxg V9Hs3utcQrI+
 qb143UvPXEEazyvpS9TNple2B7UzEkXnyEEZBjk6Q8vYoi4luEC6deR/S4bh g/gHya3dcPee
 xqw/vBMOax5wJ3ZFYEE77gKAvYZmszZs0zZ28agqCepHHwTqvCHMKzI15kBn E6yM4BKPbUka
 dyP24gt8eSTIsz0I3zgyXSMZ3YSk8ROv+TZLFuwmmmX7ypBLNlx88hJG2o1m J1jSsdPYUMlA
 SKwsMGEIGHntUMFlNBvRwBpPAuyyRos7lOgO6S0BtLlNSX/5/zqGUFBFWDfk vcLpFQHP/DS/
 RxYue6q1MKTs6OQ5d3yHOg/faayl6XLb/V/PR8HFWUZ4yk5KVvx42DpO4aW7 D/wNUEsHCInl
 9hdTAQAAQAMAAFBLAwQUAAgACAB3tLs4AAAAAAAAAAAAAAAANwAAAGRlbW8u ZWRpdG9yL3Ny
 Yy9kZW1vL3ByZXNlbnRhdGlvbi9BcHBsZURldGFpbHNQYWdlLmphdmHFV1tv GjkUfqZS/4OV
 p0Fih6bSvrSKugmQLBIJCGgj7UtkZg7g1jMe2R7S7Gr/+x5f5gqEpIq0LzDj c/Hn73y2z2Q0
 +kE3QGJIRJhJUJBqqplIP79/9/4dSzIhNRFyE0LEWaYgjISEMKaarlgas3QT DvH5yj0PRKrh
 p/78skCxUiB3dMUh3FGeQzieliPfzMDhPJCsG2lGt9cvhXAgtJpSHY75vqZR E7d61OHifvkL
 kTsGjyBV+M39vzBDETVeAIfI1+ak91ICuHkOe/tVHDdy+iRyHd5IFht+X+Q4 sY/HXR9ZvAGt
 woFAu2L6SInrrsuj1cxZuBYyQWKGoCnjaoZCPuV6jX8zKk+mvKUpZouN+wnX AqhxXQrBf7BT
 yYuIxXPV3PNeGqHcS5odr8bxmLIwZZzd8EP8mbkTwNqyfMVZRCJOlSKXWcah Ri3BSA4JHhCK
 1Ckn/5jQTibZjmoglfDIrtBfZcRqkpQmUB+sk02StaPc2B2aNo5gb4augdDp 6C1TXv/kojb5
 v/VsO8FiEknAie1ZgasJSjmSjEoc8fla7BEndEydwiNpGYOumanj94IW2S2V G5ai8+9o6PdL
 E4e1bthKi2SbbdvU73vjSmgtktL60Vod2lCB9iCcs4Vi7DVJEu3/Lwgqww96 0F6HRJ2j1fuF
 jiJvCtxMPeLfw+FoMZiPZ8vx9M7lUOdhYsHds1hvMc/5h2Ic4ZmyB2e2kGdd z4ezDEFFkmV2
 EgOMaVPraqzr0jfET3TcLoIZDhpv4fV4Mnm4mV9edWtAHE/WW8fO0FxwKYUF 4JqpFjJQ586x
 UgluN2Rjj6zSoQypzkSyaainMvgaeHOLxObon2AUUpsWCbsSMga50E8cgu7F BZ7o4dV0PhzN
 v3z49LGROc2TgeB5kqpSP24dNf1sKgHtUzOhK+CBi+mRszvcxZ/OClezp/cI sWUvA85QPghv
 Mb67mYzcqk1UqywFO/bF+Js6ukj3pGUOPbKmXIEXx0moM8kijxWlZI6gzIy8 Gm+lo4F18r4V
 iv1GhKyar678B3sWr4R2F0RUce1j8H7n4NsoWGAiDmWLEPiT8XDKRMTA3eMF aXZBRT534Fqf
 oLkGIzscZ7HtE+dAeRJ0exXMHqldK+EE94PEYoXX86/j5cPD3eXt6AgqA7kA 1WywClC2QEY0
 rjS3ImbrJ5ethdG8OvBl1l5t2T2S5py730LC/wcpl7PZZPTwMJuP//KsvJAE K+C3ZsHflH9M
 dyBxC0L71hRJgpfGCvcM0JSIdEF34O/Kfp8sp8Mpucy1+G0DKS5PQ0wS0FsR E6XzlU39/AQx
 U3iA4kH2hjlZyjTDwvwNQaPPMG1GvW+wfQdy7tsPl/Vw3oIApoZM6qfXwO10 JOhcpu78epby
 apaFpvxVpLxiFsuRhDV++W3flHc8JK9FlKu3SlrQYfPKZJxmeF9NV99xe2GN 8eUN+Gni9zt3
 sKUpiiYoPx1Mk4j3Q/U5Vvn+ylozKTRGo73ertWbNJfUQ7Y6Dds9nE2FP/8B UEsHCOfVYFly
 BAAAzw8AAFBLAwQUAAgACAB3tLs4AAAAAAAAAAAAAAAAMQAAAGRlbW8uZWRp dG9yL3NyYy9k
 ZW1vL3ByZXNlbnRhdGlvbi9EZW1vRWRpdG9yLmphdmHtPWtT5EaSn9kI/weZ u9gRu4w8vou7
 DzPL7GJg7A4PjwPGE46LiwnRXdAy6lafSg3Devnvl5n1yiqV1ALT+OzYXcfQ kuqR9chnZWZ9
 9ac/ffGH5E/JX8bV4q4urqbNW/X8lf+CXv7raPKv+OOrL/6wyMfX+ZVIJmJW ZYtaSDFv8qao
 5m+++AP+v5gtqrpJfspv8qyostHxweexWOgC4cf5YtmcNbXIZ2/CusumKLPd us7v3heyeRP5
 uFeVpRhHWg6+ytjngxuA+/jiJygS+/xdLqeH+SL2adSIOm+qOvbtfTG/FpOe yl1jUcXth6q+
 ysS4LBZSZOOqFhnMc7Wsx0Jmo3dFKd4MKnmY19eiHlb2VP98WOm9aT6/EjSX j6mIsyHmDwVx
 X5RN/ogqPxSy8Natp6apKE/K5VUx71+b5bwpZgJ2XC0im72z/Ogkb6aDytXV FYAmD6v5qgHo
 KkfLsmzXitb76TIfiywnTIEtI+bL/lVplz/M50AQBhU/A1KxlIAl4gGVzquq /Cavh9d4GFBn
 YpEbhO4pPSnysrqS0LiU0PI+PfY1byoE62Ar9lS9KcStqCXSsOVs/lEgMd7P uza9X2d0JlpU
 cUhphZGTIYvfrgxjvCkmQ2s19XLcLGsxeRCoCNkP9HtI6XBcPTQqqPg46Fy1 4TCe5xeleJ/f
 VctBkFHxB7ReiweUtiWjZeVtk519PO/7PF7KppplewDlu6qc9Lc1mU+y/aP9 OGCmwHmdz+Vl
 f0MClxURZd7UVbk7yRdN13jbxc2e6Cx+VeeLaTEGHK6K/pIlrWIGvLm0C9pZ +LaYXAkCA74D
 T+pgurwokrTVpWiHDCymaMuAwrCNhpWyLUZLL4tstEvoBLRcxlvEMgcTpJIk Ga4qdJLXK8uc
 dU4vlsEW+ikelvpY1dcXYj6e9naIH0dA4rkI0FXW8Iaz/Ebsyj5eAoUvq3om M0HDyd7BgxpZ
 T/NAirPRt1VTWQmwqySwPtq1Ysi0U+HDZdkUJ8ABvTXoqoLkRYJsMocpbgAt SmD9hH4ofavH
 zu4G1EU4HlZ/FG2gv4lFXS1E3RQoUZ6o33dnUyGaAd2zul7VR1brg1fMLmG0 sxnINPgnBxL6
 TS6L8Z56ANlrfB3vNlJTV3po+Ud1QpUYGq6qPq+a4vIu09T+HchxVX23slNd 6wj/FOO8D0NZ
 LVgRhUTfiXLRRST88oqVnuTzISsF5TVmwzoDWZ6tRiu/tmLg2Uj36gSxlXVR 76QNAvTnal7J
 phivHh5Wemj5D6ejPngEqS4HoTLeUeyHvCwmfeK6K2vUuaxfue2pcCZ6V0HV UvYETVd6RZCw
 Dv78AL96+4D9kE2qWV7Mgx2PO6WYX+3Tt54OWQOPqDLy6gzZX1R7oQsGMI8a MQNlXFzlnYps
 uwklJ4nJUIT3a5+KS5LjbwR2bgbQamtga60t8gsaBezVOqg3x1ZKIjG1uFiu 2uy6rbEoS01L
 fEBQOOuXGXgzKHp78CjKsg9saPXmZm28r8Z5yWT4AVVMT/mV62llxY6dpvGx XzMd0M77/EKU
 j2jlw/wWtIcFzGJMS17ZjiIQ8PBhNIz/RCoOIi2ahWQHn2G6JmLSK25oo68e 4j48PXz7210v
 MxSs5QLU0MNqArz5eIGWVWdK/kqbqM+nhUzgv3yeiM/5bFGKpLpM8gT7T2bV RJSJ3vfKgv3l
 y5fJhbgq5i+XUtQvJ9U4efnyrfsG42x/+dsVSh95IybG0L28KItxMi5zKakr hUJf/GFD0FTJ
 xMni8LJAuGaoXiZxkrmdtO0l8I5b3ODRZ+Pwwonxyc/QDc3JhpmUayEWMmlq kJ9wSpqpoJmA
 vhNFvuFV3uDcwXgnSVPpsnlZJmMyjEh6CfVoHjPVducMbnRP4UYwhxs0iRuw WRoYM3Tew7wM
 0JYvtQYK/yGQ1VwkuWonuVQNqZGBjpSofYljJxnaTMjaBxZnTwZOjg3xQWkN JdEqSrIApFsn
 vBEVyMAQakVtgPPkulyCzp9lawWxZSgOIIwZkh8yvy9kogXnNY7CWeAC6Jmx LQ6yVv/uEolU
 eO07okXzLQA+F4gDqyZSURo5zSfVrXovDbVLiA61FiIzTeGS1PihFiXR/2S2 lA2MEmrUNbRR
 3gHnuYQqCtEb7BzI1i2wj2daPzuWnqWb38CMqaHXFRBYoD96XKDjArktykk4 E4aVUgk5rW51
 DcAzRLUGAHimAap+u0eHwMkEIVRg0arTCshngrDh9uxe+Epgp234dt17aG1S CTl/ARt2uSAJ
 pRijQLLGkbjjC4Jj4EyjpTY2FPVhDBIRYAlxQNowNMLbopmufzzsNEJB8+C9 g2COyWYsf6WN
 9BFAUFZrGYM7Il3lpEiaTbTI52Lb4PRFVa2VGjmzUjJe1g5braFpMPSG+qhR bCe302I8TWb5
 HW4mAXMCQ0NJS9fSR0RmnMiMQLiqo7x1/UzVMFQ+BbHhlyRTKz5B4xNAns3C oSBDc7FeIabj
 bNVxk/ah66plRMkdJ/7nv8F8Xz/mZPdeKlYNBF9PEorMpAVAd1aRWqO4bBxz /tIJ49vOKZLJ
 TjIH6mE9g3oaSbcG4oWTVJgSBTucaOrttCqfaZ/oft3zThI5js4ODk/Of2wN TSTcUIBbvBZy
 AVygQFaBctO4FjnphrdG706MOQuwH+vKRHt0aUAR5w/U9gKJWVuoJeHgOmfE G8iMP6jFb9tF
 4kttaAAO/nYqFP0ypOpCjKuZMIRgnevLTxlR0HIPO1BwA0fklUm3SNXf2NAm iJuqmFA9tAze
 YC+pfyaZLEyNjeIySRewbLLJ52MB29lX9mw5KpimwdfFVnYlmj1FW1HsB1B2 diLaoWtnAyrE
 LJbpVibVlxttfEydESVDWqOXjP4nba+KoqcxhQkrUOl79Vf/EaUUSWvcnk4T Dtv/2DHqlg70
 VINWTQCxmpTCLGm6enAAUtiYBaijMdXIfXQzfVNXy6tpc16dV4vu/fTVV8no ao5HFj1N7ZVo
 //iFjeyLfPX2HtTS8QKw6IGN3Af0wzoAKmY5zW+QYgAJqWEJbgCrZQH7LClz ELg13Eian4dv
 GuDeGmgctCF3tEVbFLJzhMow+P9lhBqaJx2hhF+TZx8J9fqYcRzmC5TPJKC9 IBY2sQewIKLI
 alwgGEqhyi1LXy+DXlh4txN3HvzW9n5eubcIvxqt5x8db6E1eu2sJZGDk2qi DWQoigDBn+iz
 fNQyl+WE9OHFBOFe5wSAslcK0L5VV1owGjlgdkDAXIZqmTYQW1u8qtw1HhJY rEcyiesTge4S
 ULms8sl6BxicZxsA3RDNh53EyDBBFSvF/O0YNK+6mIgWsVYuGVpsT7lnhvqk Hzzhhn9Atq1q
 UXeM+5ut5TikBPQALbBV/x3IxCBej/ZTUyejI58txu3HOTBh+/n04Oz4w+ne wadPo7NP7493
 9w/2X68qeXB6enx6trLYx93To9HRt2evXd8bppiT1XcSC+tW93RYQWPDYRen HDtJPs/Lu78L
 05YR79Pa4uV8WZasIZx/1wJ2d4ZaddHcwex/ucPQODv+ns3fxkYHWcgWy4Z1 59pmnd7bXyQL
 DWhUMUXbrt+WN5gO9PVAx1EWKFPReKeiLNXP/UIuyhxGnuXybj4++CzGrtJG ihhxupzP0TSW
 eg1ubCQcCerlPPy+0UVX+KpisXv2lNxHJ+0ClL5r+8G8jwiZFlGWIPVmPmp6 2BjKljEkt3SE
 hggy8Xlew5zZfZs09GzHfYF+SGe2mP76ZngXy/nATj6wgmE3bTGwrUZa1Vmf n67VMhAPl7GU
 IHjttMl4vahe6bcFUnMktichv2kuPx/Py7vQeiSkFqixAGIX1UJUOb9baJ3K j8jJTo7Pzj/t
 fbd79O3BlqpqdqFfEDgf/ruT2CbptUOHpr5j5JqO7GOxPwk/pY8WcHjoloF5 g9npwt87/rk1
 gsWKclx9Whl3WKMPVw10s2pzGAnnBicmjS2HR7SINdCaIk8t8yupWEKw4Ie7 p98fnJ4lf/yj
 q5rA/2xVU1zR2MjGyd6N3h/49JJ0etvC9yBDQZ0/JgHQmdpn+8k/QqBODw6P fzjY3yKAXwW0
 OMZ+2SbwYP5wOsrIyCbgF5sOjMbKmymMqanOmhp2TLq1tZ1c5kB3fYqOQ7Ed ATTEgAPm0DHc
 jkHFxoSs098cWT6ZxBgm5xnqf9Yg8aWvz7S4bqvPcJcP7pM/sN+cmcOAQIqb G6k7UkJv6yiq
 oPUnAC4NxBdqPRzBo3o6DaY+2lO4PhHOzrqMUrIb/VehfawIIyZqO+VjDF1I dU1OFWjB9fss
 OoiskAezBUqCfDyxfbYLElRvU4HE+WUh94s6bPnXkcu8TpWpENSFSnZY+6I4 vhGa8bIJgAxt
 PFy6u+9eofaGjq9QDCuDFWo3FaxQbFauAjvoVq/98tdazy4j7AMWwPsLIjIq mV4ocCLML9b9
 uZCNdvWnCONsdHR2vnu0d5CV1VXqakStwlFR9TsaimS2uuA0C8Wf5oXkJiMV bLJGCZZmPpxk
 NQsgJJ7iEQyogMoGAoxzklQoWIIa3yhZ8itsjvZYp6h1Xp1CRRRIQfdTQgfj mkm3jBZUBDwW
 uT1IgooE4CUwqCloyneJdlpVtkR1WI4HSDAruPUmOL2Ax/Q7Mw2ovxL1ZM0L CFfsg0YkjcaE
 wi2K2cJaLKamlMjiXjW/hE3eMLT+ZVRqBXVSW5CrjC2Q3UxGKYz/ORAjvI/3 ena42NFqrjVB
 rRIKQKRqfme6FzWZbSr3Jt6aB2EP9Aj3fRxHb3EPgdI0qbQbjDa5O3MfYO/z GN0ZhnbJQCum
 HYR5zqSTf/wjiW9Psz4tjORxYLBVL8ulnDqlpNvGSttWrQPq5k7xtyL065bM 5hkTra28kO/J
 pMp5o/24nKO9tUPZtKWoDMs6oo7pPx3unoRE3HAJlhslyiM0PYgbufCAFKZP fi/u4jL3MJPb
 ahugg8wxwKgZ6X7FajnZvN+6pfEmSTjmfKAqkhvLpWctRzTCj8Uc42XVy4mQ 47q4ENbvUi7E
 GM2jE2ZqXDtydY7WYdcKO2QQpedZcdUKoBQUlNJLlHpG2W39NtmEyWx06OGm ffvK/kIW6h6g
 dRWel/z3/yQ/rzB7WEmJcJKBTS6w7Pl112lRdpOXS5IzObIG1Qebn9lSo8YZ NBM3Zxbzhk4+
 TTTmFar9mpnuVcs5DvNl8vUby5CDwm9B6Ua6CFU0z/ULbAWuCn7kp4WdPBWC b51Nku+BG1ja
 tqY/0n5vXRpIlAh6jXgaWF798L5awzXIzt4ohbZV0tLnVo2V8xKt4bkXcSck U4uzAdhYNDl/
 /rM/Pdtt+LfdpqBwe6ZNSbXBzsXnJl3ZjpLt6uYonwm/jZWLtYEeuef5hQwc RQxjaqUyiLGn
 B2owAX7B7uBzmk1zqSZcdkv6RF0cTfDqT0CmbsTAJn4ZOnjs3wNC2f4MEJHT rF9DTWxLoWfk
 j50nKguF9gaV1xJxdqzFNbTqmwgxd7IOqsA4r9d89Gwsz1EhUk2NspLRIL18 TFm1EPP/AtaB
 k6JJaMyuoDkbmXOUPXbz04fRJ0yEYbr6VGLg52a0KB7TeoU31Z66jxweqT2B 0x1EKj71/ClT
 h1PezFzReZ5G9AKQGiaq+Lvw4u/STuiBmkgQYGKRhZfaBXzNw/Jlqc4BWJvC Hs03xoqGgYK0
 z+8KUU5gpzdiZqNvJDM1+FF7mtfEI/zS+Otsn6TOBU7HKcyBBHph0dYoNX43 ZHPz2+Y22+4Y
 W0PLBjXXH677oKaGxNSrBv1VUSEDpOyhkWd8rRbltihL7QzCvdDR/1qXVv4v 4rMYL7Vnj16v
 VoYTU0M9qPVrFUoZaLuTiY6coUNUdLQSjd7ZEg/8xngCqltF89nlpdqQFUnE FGFwIeJ+5Drc
 gJSTy2q85DuNw4nTHEuGQrQn1Vuw9dWZMz1DJ2/YnOpeFqDnJSzpZXCkS/Rt T6mU2PAKw2vS
 bXZN+o2uSXJZ1ML43yrwUpbPKTs5PT75tD86Pf/RO5VU9rhzRONKz7MKaQlW I/Nr8Cc9hbSs
 p7Sq5s1Ogp7Qbta27DHzmT6MpAk5DCt69uKERN5249FTPN8oeF5pr+dWbTKj 6yGqhfOt79DQ
 fQhCy2/ZgIAKyZetr5le+boq6YxgX5n7JsFxCy5sq2qt7KNpF0Tsd+IM6Pql etEmEAGf0W6N
 pLrDHvbIB0MnT+QzZ93dIeepT+e2PazZptptN8VvlGTyNu1m9/DfVNTCckdO V4BKUNge/Bxj
 HE/RPD2/9N1kAu4ZQT1UdJVlm4sLWaSkLtUrKYRhvyb46rlirxjlieIXO5P9 61sMPtRPeuyK
 SvqFYEg8HmfMkw7Tzj3Mr2HQS1hzOl2prvO74OjCa4LjIv/QNmOjmzogAUap Xs+rW8TtRodT
 anEcqKt6NRGXsOY0E1TvQoxzmLHkFpgYJg9Vvs+wGlcY/8cjnEjIH9M32Cxj EKY549Ieqipt
 omkcsW8qdCXmw6qyLsDOkU2my/I/hlsg1OoHs11FWEkPG4lyAhTpbJCiDg8M Qh39A7HMNWd+
 kZmJx6HEqLdXIPMOd3AokYgtbwdkTUU+OOQCgjbRbrOq+mDmK6NZ6DpaICRU epGMkdEcv/7v
 EvAats4djyGMpyu5R/QVNcUU+vRN5XTJYVYvuUcV+YEh/mM68HEyE820mlAW Dt1PDzW+Vz3g
 zsI2dVA2thiJc4zkT9LcUoXk3K+NsPhJS7QZp6WEaBeOMKdJuGBPD57xewNi K0VvNqTEpLDp
 L6V0KgK4H+I+kFswG06loR4Cb9qbW8Ugp9J0g2/8gHVtQ/FcU/W4nMEcN4r2 Okz1WyWtGsD1
 S50tYidRPFjZ9+BNqktrcqC2V2pKa37y16R99nR2cJ689t5L2JGlaIAkqepb W44c/f+YqT00
 zwNo/5ypyEw505h8+nnShTXH+7V3g4M1OkANM4d0/QTWCJZ7Yf6FlCVnuLE/ 2QFfK2MDTnOr
 ZHdRTwZplcjQnv8O7Qsp9+RQYkS7Pd6znbxICG6rG1gT/a1bAZqBOCyVPEy2 HUwkESac0Dkm
 jI5khDXMLGESS/CEEtso+hYoxEplRdlW/Zn8Trp6NV+/SuHPkJYR1bCcCXJE 0KLtFzUnoCMq
 WRbTCFoyptcEFelKgGDIGPfGZ8qz1Tfp+JtMCKaY+tvdrhY+KYCgK6dCKIXj iv+EyZpUhAgd
 0FcSQYFhs0QT1kyjRU+pZeG2CO5PuA9FGs3q3yp24Ju2aGs7WTxaOou5ZXki uUUpowadNdWi
 FQKRVOXEbEQ7qtVaha9SKHelziXoWsGtCIh4XtqCEVc4BuNNHDid0yWfTJ4A pFOQg2YXaAbw
 lUR/fgxCvGFj0UZZpbtJZma4yDGesvIVP1X/BSvndeftiKBvKyZ05t5AtyJv xTqc+lbqaHrG
 e3QzPx9kWyl7elKnp4HRek+tCRPvrDj0ItL/uQF1cL60BN8MG9Q92FWSm99h Km4FzH5NJyei
 NlqlrU+ai3wOpzg1iD01AEzT+a6q0/CeD59ys5tnzMjxlTZHsq/p5r+cVIsP i021V1hZ8lEh
 O4K5lybdhFcFSaX6nNErL40L/W5ZfpyKOZ7uzlNnWAja5vlGU5eRgsDESd7h gGetOdBEwjMa
 qxYiH8iNAithw6qUO401K8wbZ10rG2xPFl0NiT1lQkvmZD6xSWQx4Gn/aD/b xwOFveOTH5N/
 uGeMjeHP70dH3xN8JmExKCON/mkip9innxMvuzEOeqT9edD/ic8HTDkmND5T Jo3Ug3Db9aGG
 20qAzAfpN1kthjXZn8rZ95TYTnh3HeZthY1o3CErtgplR+dHlntAmX7bVqgX 0hXBUzaPdCvK
 /gJteIvlGkzj3hmZ8tTAo2tD3z6cjixw+HsncVmUcYExpCvuuRNx4UiYEhWL ILMfnTMJ8Dj0
 QdWu8CaCdUpZWiJT6bEz1nK/64sXrsZGyy2RJPJoDxU2NOu9y8Yo3jxV90xv 0dLC46PWA7eY
 R7n5DPOefYT7rPJm758lYwzDoB1kB13JF2JoeqrFi5zPmnaENcwUdG4UoZD/ 3ub1nER14sDW
 UdbA/4W1y/rus24TpDC9+fxua30eLSzZScdstzBsO+l2q/K8qnHuD2g2eHwU urB7RT7qWYoF
 UYXOuRfB84M8dClPxGAn3cB9ac8RNRrTp5nyjdrcTvhgkJBtbXU79zr8tpKw tsFsMb96V8yc
 6wYDz2aivhKpveQi07E+zBPTLRdRH98cddG6miQMBXEgBCoLcw/7Lcx7MO33 W8FYPYuXR60+
 Gb+iXo3DZ9qUfUZrGZd1PhOY0gB5OHkkw3LfAcQJyJAkCGLmnadHbe+MmrFl 7UZrI0+sbUMy
 V7PLuprxM0wSF5x9xWPtzsGAMhaMWWMV2aBUNlM6WsVjezxerXCiFKnMG5Nj F/tSpktnxfmy
 fQLUy/F8GqNC4DH4/cv0EQ1h/opXyi9FH5ZEqRPziFP2NaODOf3ZpuT1RAqt /EcNm56tiFlB
 I3Fn2z0xn35CD2f7MSleCW57cq/vykNHDfWLW3gwva8aiJHVhUhtye3k7ON5 dvjh/fmIeaqw
 lMBQhT25JnTn2DCraGzPvFLLYNQ5Op1143/RS3XXhnh5XlLKWh8p42CIWqH9 BIOB6WrDrR9T
 61BP812/nNtVkPQc3aTcgLdYc8xW8CZaFRXB8Eiv7aATlghO8joBw9a9a1oi bfvfIy13tKsE
 /WH+5JHqq10DhgvMDOt9xwG2EpjbpmhKMQBixx67bgtKwwFhRg5ELOi/fcqq 2osaTYJ2rP+9
 tvmDXCs+o2Svgyj8nRWYGfwoCVt9O2TKzl4ARYwzd9seGSeO+ijsn5Txn5Qx Shn5bQkPIYu8
 HmWKXTbVwecF6FfvQSUt039/1VUyRj0HeU50kLqw/V9MP3vQn/f1LLivDo77 Ed+7boXjPrsl
 4reL9Q4R2cUTDu3bqPCbRkos7i7VQIR0g+5HSFfryUSUdrPrxC3X07NgFs7r I/HKMtPfCV4x
 Lvh7xquGc//BjM7VelK88pt9IrzqFYFZj4+Vfl0Tz4KiCONjUdReNyTq37DI y5HU3Uz0+8ZS
 dhsToql77MZTVfNchaQoh3x+kxPtd+WT/4YVfZ/fVUtMjkB/dtwsqw+pB5HC UnqvKrS+fidy
 QE5MSIc9ca3WNQBDlWEJBpG6wUn7B+oHBpd6k1JzSt05Oj46sJyawFLxd1hu P29yHXCHjx8F
 hk/Qy3/fTr5+9co3VW/wTkn5RtwMEPKYlQmQslUftPTi73n/QEGbvlzfMP8t NkzXZdcgz2yJ
 cIh+3a4B8o1HHAMr6AikQkhjPkGzLJrLN/PN7WTzYvM+ggBPy3H8dtcpyrGu nodRYH+/iFMw
 ke53wi5+/zJdKEixO/CGCniaJDHDUrQ5JzAx6c1xBEuC3hVlaZhHWLSHPZjG ergDFOlhDvYr
 SWhtmrl+2h4r9bGYNNP03/7jVXQcbdq/ahTrJN3tMhr6V69WbLXH0fjulp5c vwh6WCvdj3X6
 bKoC6zPOC+Bf+oelvTFAmKwShzk68u0LoDMltaLIlWkj6U4rxL3Yz4/3jxO0 iL60B8a65kVZ
 ja9VOZEtAP6GwrTP63zM01LS3wenke1KZdCXxyDxsyxZq61NGcsO8fEPjO5g jjER2iWeJ7mg
 5BeU9nSiQLTc9oVEPqvr57B13Dk1+tTP1HVA+ZxiLLCCKor/BtkcSO6jLRLL LEEfwltbNkys
 0dUyryd+ssWQAfrZJ6g5IhZikurWY9cI6DN0bJ7frKa78zJ5T6ErL1+VK8fB 8tMfufwCD90T
 HVuiZ0esvLDDy3kQemmMmPsBRVOYBTXuWLNl2RQv6Y3eNXjPmQ6Doc2EM6Tj 7ylwDXdOkjf6
 ZtqmqWbrTyJqF8k5WgUp8/6yk3xtozUZiQJ9Y1O7QptqbPt61xlCD++qcuKC ZTbSlL0MBB7i
 efnFd6TfpF+b1TipiK7SvzuR1CdnsHft0gWfpf5MtTMgqurHXfLn5D851Yx4 4/B1bmPv8MVW
 FyprOVw+8zK73HGdy/y2c5UfcEi7xn2AMtL+wbvdD+/P17ojXq7cEUbBMleC qWtpWzdNr9kD
 y19g3HksO4gVH7wEIayQK/DG5bFuXxkaOunpnMNeORaT06r/oCCbQt037vu4 TQQwuBnqC/pK
 aBtMg0EnLpPBGmYbffWB+0vrSLq5nI+nYnwtJptb4XKEcbCGNe9RfP+1uGOY B08ZKJPABNPR
 XnvO/KvMtKaLGMwuVgXE+qvZ8X51+PLaD7F1zpe845NWYqBov0glwpIsoUW8 7W+rplIZFeON
 IkEMmvAHayKfzSzi/PXuHbwFQ0oVvZTDIgFaiFqyrF7BpefrS+YXWdHOhbI7 IoJ5QcgoGXba
 d7cb4SMndd6PzqOdd3gXgcdkkoh8+nm1sOgZK5ydRofcuwy0S5de05TWZYzo F7swWFFyZtTp
 Ld0b4RhcWKwDEnVmxJYdjAW0Rnt6Sp21s4cncYnrbH2oY5ybMJcoCR2MF9Vi uZB0n1p7zmJq
 cteN0FyZeJgzXeQ+FMoyd+aSCtVVZTIPGPHM+YN5KeaSpGumnsUHkKk+K7EO Q/TtpdUYNJaO
 eODizP3eTkbnoAZ+k9fmY+M9wnfQxJulRCucKSLDNyEet/v3ugy7aLcX35tt SHbadd8MnybJ
 7viGKXK/dcI0/BkOza/DyhmQr7ovDp8CQfu2rC7yUpWQqbqco92Kn0s5RvBV vGmEXjsDLsab
 EXVzebSQx8lK5+QU5PqupDSdz8Bl4bvVSc4sg2iLHj3U9AtneBmSaSAxJxGC 21AAQA2cBR7T
 hdY1/C7vMlfX/HpEZoHAYGHuC+oSWkVfKoEO05AJq25NYMROMEw8MWkaQc4D IWt9wklLlusQ
 8Jxo0s5MGUgmkQJq0iiSlSQNMWl34dFPt1zhMc3K9IB0LeJf37rdwZY+vBUn 2oCr+KannsrU
 win3MIAfQI2GkqOnoUdBwrp2nlDJNoYJ3ftFYo+PPK0Ou3BnInK8SBwziqJ6 CCTkNucJRAyP
 N5I9kkaVuoSFDKEAsI5Ls9hi95MZRzNbO7U3gRDlnHT5MLwLfPgUWCPLKCKs mD02agRlJ3D4
 AkTT3K2KCXWjlR28WaEbSJm9J2wIrwU4QtORE9GAF3yrU4FQqknbeSKc9s6E Sa1GBy2jaBD2
 NaeOrERpEvm8CNOaKkF/G9/O7RYqmiAdpcxnvFIutenOT0diwYwuHD93RVIZ xlFYdHeXuqrh
 MhKGb1tXv+pSjgZ5xSnmOJgeW/J2WgDLHbJSA1o1kx6hhSzlCwtVU0kFbovJ lWhaasOj4m88
 GLd8Ccu/GJtBRCGHK6BZuaIqawTlEUAMDSfcTWN/K1YX61qxWL4wEybUVWfQ PRLG0tZKA8oT
 i6q03vcUQy6x1F2C0bWynQv+WcJMzamWu67sZ8ZI0rSVKn5rxW1lqEae5Tfi SAi6P6yL9Txi
 nvBuOS/wFTDv+WJxJxUOi4x7V2i6PKzm6jDCf3aRulhcHWS6a+xIUqfkw8C+ l3mJMbhKwGYZ
 0VTaZUy1rejSdmKpGNQ8XphsLjwpd1BSUzJWnjI12Eujj0/OR8dHn852fzj4 dHz0/sdPo3f6
 3vH97WRIqU+HB4fHpz9++ubDu3cHp4ZLwKj3NRFAAzMKFphqF0Rxk5DFpmJu 9CbIk7KCpcek
 vrgFyMxfNPp2Clhnk0VNNXkh5uMpm6qP5vr5Qyx5Z/O+sA6VxIxz1VU45cw0 EiFOoFxhPu9i
 flNdA2u9RVZHEpDtBgYgAx7Wo0vrmxvau2nm7aINt5F4FgppSC1iQCLvQEOc teitwWwlFfgH
 yJ23Az7I8hJczZeqnsJcEbFobCxUyBPU0zDLBr+wD2UyH4pCmntJ4xf7efcP tW6g7LpU24KI
 5VOGKKyQS9zfTv8SuZxovXcMMmjMknpn/R2XEGrMHHJppJd7R+VmW+rEbNVC Z1MickzHrYbu
 eXYPfRMZ39LqJqLotUNblMIbN6ZOeLPtEIrbZcy1sypZH6r7ec1vxTW9P4pd 4dKP5H41t+eZ
 D7qRozM/ULhBEJFtKoVblLlv68pkVVA57Ocv/CSAD7rt6r5/mS3693pm9CXo A6JH+p5LCIEJ
 SC8EkMKFwWRDmDBhlDa/uCQ5FuVM4+yMUYG5lJrWY/1xNQf6STcW+RkuwqxZ dE5M6e/xuitk
 N0oelU0t8lmWPL1q2rqbixOzFl3VO8CUhdfLsunAPBJdzwhwDf+gJFIwX3tm uvByYzowYG2l
 nCKrxCtMy1T9hHkuLZyMc+gppcuT25cSx+5x5bc3AEWshS2tZUzVTad1r7zN 71iSSADFihDK
 CDuvGpOEEWVElQRuHTey9UrPyKN35W5ZVrco9XpStJm/+PhkZS+We46sb/3i 7a51Y1FPiniT
 3GkflODJv8eJu5VATTG6jU7vmtFJ3kyTBf6z4zWvtzdsCXNHGxpKsVywP0d4 4ZySgHasyCo1
 ocQcVUba03JLVWlcwXrUIkMBaiZEADslgDAapU7KvMH7dE1/iEqkhmC7UBdH lWJmdO3VY06l
 VO5B7Jnny8OaWyEWrTFrt+/XwoeXLOti2yheBJzeiPRbz8jjzuVQucZpgh70 ltAKOnraHtEl
 Zynvy5Sxd3myj9gmv99zlTKmhf8rz+yrNml4EKaMDiq/l1r+YbUyZeTnvaKb yBfWTH+E2yIs
 QNBrjTJUICOkYk1m1SvrS5KO1N9E3d+pF9yxJXc/KUUx3C0Qq7RLysEPeVlM 0HSZHe6efg/a
 oMUg7b0OS7/bKFM6IqtryL7ljcBm+bR7fn46+ubD+cG2QknNfuhuaN5Y6zoa vZehF4e0evfZ
 WlamPjB3v+m/QzitrpMSwngnzpSCTbfUgqvjgrP4DQstKD5i0lfMTqrzzm2t MEwNvFD1wfJl
 hyFH5z2dLGm1JWbZXi6ej3XhJZhGQkc2lKhMLiuomdQ8y8U0PSFhwkY9e6s9 vnGBS1TGBndl
 FERQN/a8d8EeVIUVTA4aMCWU1mKbqqOvYYb88irz+8nx2bm28qyZFHWtpzsS HHCIY/Zy1KjL
 TxZDfzgWJnLlRS8olhVWjW59o73I2L1MP1FacnU6IrNRayus714mkzuw05eg 08vAJh63SBIv
 p+wqJd+ev7kJWnGtwBPMkeph7dOEmi/z/nQqBHReYwZL75BtPc4P7gjWd/do XQEGJNp8XeN0
 qCtrh8zFHrxUyS3J1EEqr3//rrtEZM2n3N75XM+hdjCNCTsI1UYzsu+u3sDJ 65bjj928hq6a
 slnLRUgl5Y+4CWm/CAc2I8AyJkT7biLPdm1RG5CeSR/i2If3YcbuNUGjdutS jaiDrlI9Vvnx
 vU6G6SZvXPxBG9aAf3p37Ax1etjoukB0kMdDU+FuczkybwsSWl0rmaQoEydF j3Ng369esxP1
 cFjqigVKNxzG9R5VSno+02e8m8y4fgGKwnUgU6vevma9aXWGLvCI3aiLl3/v Q+tX5McROOqQ
 4oSn+2x8zucjPPh/0MjOSHMIRrdNcK4a40Rc5kDyHjmlhxia1ep3BLsX61kr SHtFV4DF1BnP
 56AXNhsx13s+X1bVtURH9Rztq7ic2sdpQUI1cAr1I1vYQOw1HTQvakx2YC8I 1ZvLzbB+4eJb
 NBft1tpcXRPUMXgGWoPeRrdoOpFN5PJCNkWzXJMEMXgazOl2Ir9+1Ixst3K7 y6/jAaiDxRB9
 3+qI3yJDAshUlAvcN6WLkNG3/mh/uzF3+HYnHDgMKrZeUQN72L2ols15hffj dDq8G8tf6o0Q
 owmduq3YT9xrcisLe+KNPwu39xKJx6BMOqH3fWFWNjR8Wp5l4NwnNpAXvIF1 u7wGtZ4F6uBm
 Wxeopt8EwPtM9texV2CeAjoPU5CtPmr/YrUxR6mOD7LnRKP7tXFJNddrX8Kq /mxmdmBMkFy5
 W25MqkBy0eRpinp8q4OqzuZ773puO8N/ucJb3huA19bqcNxIBEe0NeVY7n3q uIHGnJ+H13my
 C+wxJhY6defouC/XGcFuDjDbIbAdB5jw3/8BUEsHCNDxV/vnKAAAKtkAAFBL AwQUAAgACAB3
 tLs4AAAAAAAAAAAAAAAAPQAAAGRlbW8uZWRpdG9yL3NyYy9kZW1vL3ByZXNl bnRhdGlvbi9E
 ZW1vTWFzdGVyRGV0YWlsc0Jsb2NrLmphdmGdF9tu2kj0mUj5h9k8DVLWSVfq UxRpIRAVlRQE
 bPOwWkWDfYBpjMeaGUirNv++Zy62xwY3tC/2+Nzvc5yz+JmtgSSwFVEuQUGm meYiuzk/Oz/j
 21xITYRcRxCnPFcQxUJClDDNljxLeLaOxFKB3LNlCtFoUp5vfpl5y/JQwAPL f0eG0iAT0Iyn
 obB7Fmshv/26QAU6lDMHfVwGbFc1EcOH+4pLtfOAVT6cLL9A/BPRnmyu5S7W O8nSe2D4boly
 xYH5FDsZQzTzh+MMX1Ysrodgz+EFpIoqJ8Zc6YUEuBOZxhqZSrHnCcjfF4gJ HrMlpKdIKrhH
 c0gxUFiedxuWrSExVkF2GnOTd7hHP05hNG5/tufj1OpFR/PHRTsyZd/ETkf3 Qm57WrN4s23V
 3CAfYAhPIhzbYzvpC0/WoFV0JxCvuG6phJDUuH2casejFepU0cB2mpoy2aK6 pBw9sAznTGJs
 fYP0wTaxF91PRfz8BsPcpfUEKwrXjBULIdJnfiqH1xFORTsy+0w9h0PBAgf4 mLrB2sDgOY16
 eZ7CCE/HkFNg0uPOz/LdMuUxiVOmFDFSD2ND4Ct2QKLIEdR3I6OTS75nGkhV xmRfVHOJNMKH
 CccpScC+bhyvM+C4anoAnhZXSQ1qwV1jTafjhJPbFqqoVN55tQb8PdmDlDgf rK1CYxogIXvB
 ExJLHILgZJjc0xXPWErCSiPb6nxJytonOZPYgd6koBiI9u/bkDPCCvAEtGtM 6/hqIMq/bwvG
 yBnl8dTpuST+O1qMFuPhU783Iz9K2GA4v5uNpovR5JMT7oWau2eByaUXDyKB lLg7Ql0cEA1A
 xZLnVuHFYgMkxaFIYpzTjGeKCMdHVlJsiUb01op72QhlcmVjT9BOm3czmAk6 ZOgkX290Q92W
 yTXPHnmiN+j0u+sjyA9g+BD73iLrgSlTMAeMDcNUU8/t9FQpwkbE0B1EtiQo +DC4j4vocdab
 OgnVMCRuPKKIDF5IBfc59MOz7tFfh6jSH4dzdpm4e2mO2Mk0LUa0eTTtNhjq eJ3F/clsMJz9
 MMcPT1gBk/HYfnz2H5U35g4gqyTww0C8F6skSmEVOlndMBWJFvkbFNI7eYTm 3fV1SbYUWmMZ
 /ZzOBKAKkDV2lXRr1ZBjaeq+wFVNKhTjI3NQ2ncWXMO6Jg9GPlG5eTqTAni9 sMJ2ZkniCAyj
 Q7uB6IVUg5IaV0IKw9u2g1DD27qhUD9tipFqR5hqENOjOwqBfTWt6q6suIQm j/Pr0nGZ2VUS
 0K7zxcxWfJiPq6vSNRPv+nJnPbrD6l3j8tzEdWtxaWF+c390QTvY1GnX3V1l uAISP/grAHWj
 kWjsV6jixFeEOhDBOahZFoNYEXdhl0QdCbhIZ6S+sPtfAGs0pX4973oFlyS4 36MxziJcyFXU
 780/DhdPT/ezf0aLuQ+0i3SpJdulaZCBjk3DpQX7cNZ/NshzJl6yYQqmwRSW J6VvRrTrM7I+
 zEi3a6AfQ5n0QC3u5f/+R3wA8MOobUTH2h5Q0JqZl7aJDn9WUOr3o5GzEXt6 +tR7GL42i6r2
 i9AoqeYfBA1M6hazRLtOHmV5MflPXCzMjd9nsmc7R9G2tcJX0tUVWUwGE9Lb afHn2jQ8M/K2
 oDcC+1zvlobqFO0S1tytNGtQNNiwi8vanL3WABKFfLRcMSO7O7qUWGCwqVEX Zh+qVlnFRhqK
 MrA2Sa+HPjXT4Kz3bcsNzNZ28ZfadVugKVazk+L/40Bs8cagtn4LKuyPOkC5 T3rt6txXfwW1
 bpqp4Kf9H7eu8/wsqIrOWWnt8n3scfA1Z1nSS1PfNq9FQs/P8PU/UEsHCIDc s/lTBQAATBEA
 AFBLAwQUAAgACAB3tLs4AAAAAAAAAAAAAAAAPAAAAGRlbW8uZWRpdG9yL3Ny Yy9kZW1vL3By
 ZXNlbnRhdGlvbi9EZW1vTWFzdGVyRGV0YWlsc1BhZ2UuamF2Ya1U32vbMBB+ TiD/w9EnpzR2
 OvbUMljTX2QsLGyFPRZFvthaZclIcrIy9r/vTnKTrGV0DzXGtuTvvrv77rOL 47c9RkM4hkvb
 PjpV1QEyOYZ30+n0hK/vYT5b0EvXWieCsgaEKcGGGp3PY+CF1hADPTj06DZY 5nBXKw+ts5UT
 TYygABBS2qYV5lGZChoR0CmhfSQRDmmnJMxGKC1WGqEzJboYR8DGg13HxbXU qvUIy26llYTP
 SqKh5eY0n0amba1kvUul0FMU1VIqH5xaddzCSayINvfJRIjBdQjtWVFst9sc U57cuqrQWAld
 YKsnm9NpXodGM7qXzSRe6/xZ3OHjuWYTUEYF6hYulvOUvWk1NmhCBHDg2x7F aNgK+SAqhBIb
 m7c8mz7b+WhI6a0LQM3tGu1UvrYkdD5fCENx5Q2tXoFiqajxnJHX8fH/8UtK 8Qp6q8oKg8+/
 SWe13hVU9I79KLpQW0f9/RBRQYiXOwuyFoYaT94hoclqQJTJCRUapLEgefKx RSCf8BigshAs
 fFemtFuYRKalwzU6NJJMNIFP5Ba6XVpy6W3iSKONOzzTy0QVHc36J4dKLbyH KxrCQniy8hUG
 cp3n/gF/BjSlhydB4NdoOGid2nDFL0Jm2soHWPH1nHGJn2FJfEjynsPfL1+k zfbz6kPGMfHA
 dy26LG2dwNHadi7UR/SUKKDnOBpz+gGr2U8UPkC2r2P8VAijYrn03uD2Hx1l TBQpf8fubUDJ
 49lYVYJ0SFpwwfylkbrZWhn6jg5NSn+O3XPfSQIdGocN0FAdB9ic3MX3LPVT FLy4s1Y/qEBm
 SPcXET2gD2LW3NMujTJ7plPsN4pVFHvkjD7Lyln6vc0bHsb1T8H/Ar/UXaUM Z7jCteg0ZeBF
 AiWKweAZeL64vb/58nVxP7sdj/dy50m1J8UO5ellpvMPUEsHCL4mZJC6AgAA RgYAAFBLAwQU
 AAgACAB3tLs4AAAAAAAAAAAAAAAANgAAAGRlbW8uZWRpdG9yL3NyYy9kZW1v L3ByZXNlbnRh
 dGlvbi9QZWFyRGV0YWlsc1BhZ2UuamF2Ya1X32/iOBB+ZqX9HyyegsSZ7Ur3 sit01/Kjh0QL
 Itz2sTJkAO86cWQ79Hqn+99vHDshCXDQVaUWEs/MN+OZz+MhZesfbAskgljS VIGGxDDDZfL1
 44ePH3icSmWIVFsKa8FTDXQtFdCIGbbiScSTLR3i8517HsjEwF/m63WGcqVB 7dlKAN0zkQGd
 zMqVb3bhNA7EmxrM6GF8bQgnTA8u9Wmb7xu2rsetXwwNn5Y/Ybnn8AJK02/u +0qEwmoSgoC1
 r81F7aUCcH5Oa/tdnBcK9iozQ+8Vj2x+r1Kc5o/nVV94tAWj6UCiXHNzpsRV 1eXZamacbqSK
 MTFDMIwLPUciX1Id49ecqYuQDyxBtMiqX1AtArWqSynFD34JvLAI/6+aR9pL S5QnxdLz1Thv
 UxamtMsP/BA/5q4D5LI0Wwm+JmvBtCZzYKqSWYKGAmLsD5pUM07+sZatVPE9 M0AOvCP7gn6l
 sJpWEm9ccq3c+W14DI6wOtZZq2V2XHuik37Fzb9VsL3kEVkrQL95U8C4g5J3 JGUKVzxeI03E
 MRqhE3ghDWHQsZ5anvRGpg9MbXmCyr+ioNcrRQI2piYrJYpvd01Rr+eFK2mM jEvp51zqoqUa
 jA/CKeehWHmFe8T47z5BCvhFH7QnHNE3KPV61KXIiwLnqUv8Ox2OwsFiMl9O Zo8OQ9/QOA/u
 iUdmhzg3n4p1DM+e1qBt69ju+HQ4wRD0WvE092Hj4kZAda3j0GskJyZq1sAu B7U3Op5Mp8/3
 i9u7TiUOl6Zc20ROUN9vyYQQcMvMSBXoG6d4IAkeK0zGUa5KhdLk0PvItkae g8CXwIsbOayv
 /gGWIBW3mLA7qSJQoXkVEHT6fezc9G62GI4Wv3368rmGnGTxQIosTnRJH7eP Cn22B/4cp2bK
 ViACZ9Ml7UcWw5d2oWoLTBJcOspKXvrSqo0UwhjDyeP9dOS2bq0atSlSlL9Y fVtMZ+mejMqg
 SzZMaOiUbHclHuSuvEfnwf4fzwJkVX91lTk5NvgiNQcRooubF42PL28/yUCI QALKWzrwPes0
 ZCwjEO6xT+qDSIHnWmGuE9T3YBmB6zzKR7UFMBEHne4hzC6pdHY6RaoqTCEd L/6cLJ+fH28f
 RmeisiEXQdVnnCKovMy2lK5MDzLim1eH1ojRvrrgS9RuZdtdkmRCuE/PLte/ f5/tQSEpoNnL
 ZRxjK1sh64AlRCYh24Pv4L0eWc6GM3KbGfnLFhLcr4GIxGB2MiLaZKsrHERc 47nG8/WOmDzh
 hmOl/oagdvnZu696m+WXISbd34nnUYvtcz3kyry+JdhWS4HJVOLO05VeQsPE m1LyBi95hhRs
 8GfH7l2zju1hLNeZfi/QIh05roonSYpNdLb6jqcNK4wv75Cfevz+IA92LEHK BOXcagcX7K+H
 3wIH3Z/Za6qkQWuUV0eI6uDgQH3IOUtpc65AKPz7D1BLBwjjfj1fPgQAAEoO AABQSwECFAAU
 AAgACAB3tLs49KWx0tAAAAB4AQAADwAAAAAAAAAAAAAAAAAAAAAAZGVtby8u Y2xhc3NwYXRo
 UEsBAhQAFAAIAAgAd7S7OCorfbzkAAAAmQIAAA0AAAAAAAAAAAAAAAAADQEA AGRlbW8vLnBy
 b2plY3RQSwECFAAUAAgACAB3tLs4w7mUpIwAAADwAAAAFQAAAAAAAAAAAAAA AAAsAgAAZGVt
 by9idWlsZC5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgAd7S7OHzcCLj1AAAApgIA ABYAAAAAAAAA
 AAAAAAAA+wIAAGRlbW8vcGx1Z2luLnByb3BlcnRpZXNQSwECFAAUAAgACAB3 tLs4HoxPUtkA
 AABcAQAADwAAAAAAAAAAAAAAAAA0BAAAZGVtby9wbHVnaW4ueG1sUEsBAhQA FAAIAAgAd7S7
 OL0jniT7AAAAsQEAABkAAAAAAAAAAAAAAAAASgUAAGRlbW8vTUVUQS1JTkYv TUFOSUZFU1Qu
 TUZQSwECFAAUAAgACAB3tLs43fFALnQBAAAYBAAAFQAAAAAAAAAAAAAAAACM BgAAZGVtby9t
 b2RlbC9UZXN0LmVjb3JlUEsBAhQAFAAIAAgAd7S7OHcBE/zIAQAAlwQAABgA AAAAAAAAAAAA
 AAAAQwgAAGRlbW8vbW9kZWwvVGVzdC5nZW5tb2RlbFBLAQIUABQACAAIAHe0 uzisxAxNGwEA
 APYBAAAZAAAAAAAAAAAAAAAAAFEKAABkZW1vL3RleHQvZGVzY3JpcHRpb24u dHh0UEsBAhQA
 FAAIAAgAd7S7OInl9hdTAQAAQAMAACAAAAAAAAAAAAAAAAAAswsAAGRlbW8u ZWRpdG9yL01F
 VEEtSU5GL01BTklGRVNULk1GUEsBAhQAFAAIAAgAd7S7OOfVYFlyBAAAzw8A ADcAAAAAAAAA
 AAAAAAAAVA0AAGRlbW8uZWRpdG9yL3NyYy9kZW1vL3ByZXNlbnRhdGlvbi9B cHBsZURldGFp
 bHNQYWdlLmphdmFQSwECFAAUAAgACAB3tLs40PFX++coAAAq2QAAMQAAAAAA AAAAAAAAAAAr
 EgAAZGVtby5lZGl0b3Ivc3JjL2RlbW8vcHJlc2VudGF0aW9uL0RlbW9FZGl0 b3IuamF2YVBL
 AQIUABQACAAIAHe0uziA3LP5UwUAAEwRAAA9AAAAAAAAAAAAAAAAAHE7AABk ZW1vLmVkaXRv
 ci9zcmMvZGVtby9wcmVzZW50YXRpb24vRGVtb01hc3RlckRldGFpbHNCbG9j ay5qYXZhUEsB
 AhQAFAAIAAgAd7S7OL4mZJC6AgAARgYAADwAAAAAAAAAAAAAAAAAL0EAAGRl bW8uZWRpdG9y
 L3NyYy9kZW1vL3ByZXNlbnRhdGlvbi9EZW1vTWFzdGVyRGV0YWlsc1BhZ2Uu amF2YVBLAQIU
 ABQACAAIAHe0uzjjfj1fPgQAAEoOAAA2AAAAAAAAAAAAAAAAAFNEAABkZW1v LmVkaXRvci9z
 cmMvZGVtby9wcmVzZW50YXRpb24vUGVhckRldGFpbHNQYWdlLmphdmFQSwUG AAAAAA8ADwCe
BAAA9UgAAAAA
--------------080403010306060206020904--
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328610 is a reply to message #328579] |
Wed, 28 May 2008 10:35    |
Eclipse User  |
Michael,
Boris helped me play with your sample.  The problem really seems to be a
design flaw in your use of the framework.  You hook up an observable to
the viewer, but what you're displaying doesn't work uniformly for all
selections the viewer can generate.  So you could use this logic to
ensure that only valid selections are forwarded.
        final IObservableValue sel =
        IObservableValue selection = new ComputedValue() {
          protected Object calculate()
           return sel.getValue() instanceof Pear/*or Apple*/ ?
sel.getValue() : null;
Or it might be better to react to the actual selectionChanged method
call since that's called only when your page is applicable to that
selection...
> Ed,
> have to generate model (a basket containing apples and pears), edit
> am working in a 3.3 workspace but use all databinding stuff from 3.4.
> a pear in the basket and then go to the master-detail page. select the
> Michael
> Ed Merks wrote:
>> Michael,
>> Comments below.
>>> Ed,
>>> comments below.
>>> Ed Merks wrote:
>>>> Michael,
>>>> Comments below.
>>>>> Ed,
>>>>> I'd like to continue this discussion a little bit. I've put some
>>>>> Ed Merks wrote:
>>>>>> Michael,
>>>>>>> Ed,
>>>>>> support XML Schema-based models.
>>>>>>> general?
>>>>>> a type where the feature is applicable.
>>>>> the base framework "only" handles a special case in Master-Detail
>>>>> elements of the same type, whereas the usecase described by me is
>>>>> handled by the framework at all or if customizations are unavoidable.
>>>> a feature that's multi-valued so you return a list that can be
>>>> downstream code can deal with it sometimes being modifiable and
>>>> sometimes not.
>> an application I'm at a loss to provide anything insightful to say.
>>>>>> I understand it.  Whatever makes it work for you is fine.  You
>>>>>> just talked about opening a bug, and I'm commentingon the fact
>>>>>> that I don't see the behavior in the base framework as a bug.
>>>>>> The framework is not intended to gracefully support creating
>>>>> what I mean, consider the a file system model like the one that
>>>>> you presented in
>>>>> is a feature of "target" (using the variable names of the
>>>> disabled?
>> gather insights...
>>>> Hopefully in the next release I'll have an opportunity for that.
>>>>>>> Thanks,
>>>>>>> Michael
>>>>>>> Ed Merks wrote:
>>>>>>>> Michael,
>>>>>>>> features, i.e., features of a document root that are accepted
>>>>>>>> by a wildcard feature of the actual class.  I don't think you
>>>>>>>> should be applying it for invalid cases.  I believe it fails
>>>>>>>> with an exception right now if you do that, which seems to me
>>>>>>>> the right approach.
>>>>>>>>>         if
>>>>>>>>> target).eClass()))
>>>>>>>>> Michael
>>>>>>>>>> Hi,
>>>>>>>>>> I am using a
>>>>>>>>>> childList});
>>>>>>>>>>             List list = new
>>>>>>>>>>             list.addAll(list1);
>>>>>>>>>>             list.addAll(list2);
>>>>>>>>>>             return list;
>>>>>>>>>>         if
>>>>>>>>>>         return null;
>>>>>>>>>> different?
>>>>>>>>>> Thanks,
>>>>>>>>>> Michael
| Re: [Databinding] Problem with MasterDetail and EObjectObservableMap [message #328611 is a reply to message #328610] |
Wed, 28 May 2008 11:28   |
Eclipse User  |
Ed and Boris,
thank you a lot for your big help! This is the clearly the most appropriate solution! Sorry for bothering you so much.
I like the approach with the ComputedValue since it seems to be more according to the databinding paradigm (actually I
could not figure out quickly how to use databinding methods in selectionChanged...), and I do not experience performance
problems with it.
Thanks again,
Michael
Ed Merks wrote:
> Michael,
> selection...
>> Ed,
>> Michael
>> Ed Merks wrote:
>>> Michael,
>>> Comments below.
>>>> Ed,
>>>> comments below.
>>>> Ed Merks wrote:
>>>>> Michael,
>>>>> Comments below.
>>>>>> Ed,
>>>>>> Ed Merks wrote:
>>>>>>> Michael,
>>>>>>>> Ed,
>>>>>>>> general?
>>>>> sometimes not.
>>>>>> you presented in
>>>>> disabled?
>>> gather insights...
>>>>>>>> Thanks,
>>>>>>>> Michael
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Michael,
>>>>>>>>> the right approach.
>>>>>>>>>>         if
>>>>>>>>>> target).eClass()))
>>>>>>>>>> Michael
>>>>>>>>>>> Hi,
>>>>>>>>>>> I am using a
>>>>>>>>>>> childList});
>>>>>>>>>>>             List list = new
>>>>>>>>>>>             list.addAll(list1);
>>>>>>>>>>>             list.addAll(list2);
>>>>>>>>>>>             return list;
>>>>>>>>>>>         if
>>>>>>>>>>>         return null;
>>>>>>>>>>> different?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Michael
 Current Time: Tue Nov 04 06:25:15 EST 2025
 Powered by  FUDForum. Page generated in 0.14463 seconds
