Home » Eclipse Projects » Eclipse Platform » [JDT] wrong source editor opened during debugging
Re: [JDT] wrong source editor opened during debugging [message #326947 is a reply to message #326902] |
Thu, 03 April 2008 14:19 |
Will Horn Messages: 265 Registered: July 2009 |
Thanks for the response. No, I do not have any swt fragments other than
the win32 one selected in the plugins tab. Also, under the Preferences
Page for Target Platform, I verified that the target environment is
win32, win32, x86.
However, I do notice that in the Preferences Page for Target Platform,
under Source Code Locations, all the fragment source bundles are listed.
This makes sense because they are all in the target, but maybe the
debugger is choosing one at random?
-Will
Darin Swanson wrote:
> Do you have the swt linux fragment included in the plugins to launch with on
> the Plug-ins tab of your launch configuration?
> HTH
> Darins
> http://runnerwhocodes.blogspot.com
> "Will Horn" <will.horn@gmail.com> wrote in message
> news:fss3r1$d8n$1@build.eclipse.org...
>> I am developing on windows against a target platform that includes the
>> delta pack (both 3.4M5). When I open a SWT class (like Widget) using
>> Ctrl+Shift+T, I see the win32 version (the editor title is Widget.class and
>> if I link with the package explorer I see it under the win32 fragment).
>> If I put a breakpoint in this editor, the debugger will stop at the
>> correct point. However, it will open the gtk source file which does not
>> correspond to the running code (the green highlight is on the line number
>> from the win32 source file). Additionally, the editor title is
>> Widget.java and it does not link to any file in my workspace.
>> Is this a bug? Or is there a way for me to change it?
>> Thanks in advance,
>> Will
Re: [JDT] wrong source editor opened during debugging [message #327609 is a reply to message #326947] |
Fri, 25 April 2008 16:33 |
I realized this issue extends beyond SWT fragments. It happens when I
debug any object in the target. To reproduce it I:
1) Navigate to any object in the target (using Ctrl+Shift+T, Ctrl+click,
etc). This opens the "ClassFileEditor".
2) I put a breakpoint in this editor (I can see the little blue dot).
3) I run the application and it stops at my breakpoint. However, a new
editor is opened, a "CompilationUnitEditor". I do not see my blue
breakpoint dot, I do not have Ctrl+Shift+I inspection*, and in the case
of SWT files, the wrong OS specific file is often opened (which I
described in my first post).
This is on 3.4 M5. I assume I just have something set up incorrectly,
but any help would be greatly appreciated.
-Will
*Ctrl+Shift+I gives this error - "Unable to evaluate the selected
expression: To perform an evaluation, an expression must be compiled in
the context of a Java project's build path. The current execution
context is not associated with a Java project in the workspace."
> win32, win32, x86.
> -Will
>> with on the Plug-ins tab of your launch configuration?
>> HTH
>> Darins
>>> the delta pack (both 3.4M5). When I open a SWT class (like Widget)
>>> using Ctrl+Shift+T, I see the win32 version (the editor title is
>>> Widget.class and if I link with the package explorer I see it under
>>> not correspond to the running code (the green highlight is on the
>>> line number from the win32 source file). Additionally, the editor
>>> title is Widget.java and it does not link to any file in my workspace.
>>> Thanks in advance,
>>> Will
Re: [JDT] wrong source editor opened during debugging [message #327616 is a reply to message #327609] |
Sat, 26 April 2008 01:34 |
Cross posting to PDE in case this is a PDE issue.
> -Will
>> than the win32 one selected in the plugins tab. Also, under the
>> Preferences Page for Target Platform, I verified that the target
>> environment is win32, win32, x86.
>> listed. This makes sense because they are all in the target, but
>> maybe the debugger is choosing one at random?
>> -Will
>>> HTH
>>> Darins
>>>> Thanks in advance,
>>>> Will
Re: [JDT] wrong source editor opened during debugging [message #332099 is a reply to message #327616] |
Thu, 02 October 2008 21:28 |
For anyone stumbling upon this later, here's a link to the bug report I
created:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247766
>> Ctrl+click, etc). This opens the "ClassFileEditor".
>> new editor is opened, a "CompilationUnitEditor". I do not see my blue
>> case of SWT files, the wrong OS specific file is often opened (which I
>> -Will
>> in the context of a Java project's build path. The current execution
>>> Platform, under Source Code Locations, all the fragment source
>>> bundles are listed. This makes sense because they are all in the
>>> target, but maybe the debugger is choosing one at random?
>>> -Will
>>>> HTH
>>>> Darins
>>>>> does not correspond to the running code (the green highlight is on
>>>>> the line number from the win32 source file). Additionally, the
>>>>> editor title is Widget.java and it does not link to any file in my
>>>>> workspace.
>>>>> Thanks in advance,
>>>>> Will
Current Time: Wed Oct 16 12:33:18 GMT 2024
Powered by FUDForum. Page generated in 0.16212 seconds
