How to read file in a Eclipse Plugin? [message #327175] |
Sun, 13 April 2008 11:23 |
Originally posted by: jefftymc.yahoo.com
Hi All,
In a plugin project I want to save and load info from
"plugin.properties" file. This file is placed under the root folder.
Code is like this:
String pluginPath = null;
URL bundleRootURL = TestPlugin.getDefault().getBundle().getEntry("/");
try {
URL pluginUrl = FileLocator.resolve(bundleRootURL);
pluginPath = pluginURL.getPath();
} catch (IOException e) {
// get the plugin path such as
// "D:/workspace/TestPlugin/"
pluginPath = pluginPath.substring(1);
Properties prop = new Properties();
String path = pluginPath + "plugin.properties";
InputStream is = new FileInputStream(path);
prop.load(is);
In Running & Debug mode it works well. But when I export the
project to myplugin.jar and place it into Eclipse's plugin folder it
didn't work.
BTW: Loading from the file is for a PreferencePage. I download the
some example source code and found that they all use like this: (in a
PreferencePage)
IPreferenceStore ps = getPreferenceStore();
String s1 = ps.getValue(key1, value1); // for save
String s2 = ps.getString(key2); // for load
We can only choose IPreferenceStore for saving & loading? Cann't we
do the same with reading & writting from/into the file in the plugin
project?
Would u please help me with that? Thanks in advance!
Re: How to read file in a Eclipse Plugin? [message #327176 is a reply to message #327175] |
Sun, 13 April 2008 12:43 |
--------------060002020007010804070209
The plugin.properties is intended to be a read-only set of
internationalized strings. I think it's best to access it like this so
you'll be sure to get the version that's appropriate for the locale.
Platform.getResourceBundle(getBundle());
jeffty wrote:
> Hi All,
> Code is like this:
> try {
> prop.load(is);
> didn't work.
> PreferencePage)
> we do the same with reading & writting from/into the file in the
> plugin project?
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
you'll be sure to get the version that's appropriate for the locale.<br>
<blockquote> Platform.getResourceBundle(getBundle()); <br>
</blockquote>
<br>
jeffty wrote:
<blockquote cite="mid:ftsqg1$4qf$1@build.eclipse.org" type="cite">Hi
All,
<br>
<br>
Code is like this:
<br>
<br>
<br>
URL bundleRootURL =
<br>
try {
<br>
<br>
<br>
} catch (IOException e) { <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
InputStream is = new FileInputStream(path); &nbs p; &nbs p; <br>
prop.load(is);
<br>
<br>
didn't work.
<br>
<br>
PreferencePage)
<br>
<br>
<br>
<br>
<br>
<br>
Cann't we do the same with reading & writting from/into the file in
the plugin project?
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------060002020007010804070209--
Re: How to read file in a Eclipse Plugin? [message #327177 is a reply to message #327176] |
Sun, 13 April 2008 13:24 |
plugin.properties is intended to be a read-only file? Ahhhhh...That
is to say I must create another file if I want to use my own config file ?
I found write info into a file in Eclipse plugin project is very
important.....
Ed Merks 写道:
> jeffty wrote:
>> Hi All,
>> Code is like this:
>> try {
>> prop.load(is);
>> didn't work.
>> PreferencePage)
>> plugin project?
Re: How to read file in a Eclipse Plugin? [message #327178 is a reply to message #327176] |
Sun, 13 April 2008 13:25 |
important.....
Ed Merks 写道:
> jeffty wrote:
>> Hi All,
>> Code is like this:
>> try {
>> prop.load(is);
>> didn't work.
>> PreferencePage)
>> plugin project?
Re: How to read file in a Eclipse Plugin? [message #327185 is a reply to message #327178] |
Sun, 13 April 2008 15:40 |
It's important to keep in mind that an Eclipse installation might well
be shared by many users, so information that a particular uses might
store needs to be associated with their works. Code that modifies
itself is usually a very bad idea...
> Ahhhhh...That is to say I must create another file if I want to use my
> own config file ?
> important.....
> Ed Merks 写道:
>> so you'll be sure to get the version that's appropriate for the locale.
>> jeffty wrote:
>>> Hi All,
>>> Code is like this:
>>> URL bundleRootURL =
>>> try {
>>> } catch (IOException e) { }
>>> prop.load(is);
>>> didn't work.
>>> the some example source code and found that they all use like this:
>>> (in a PreferencePage)
>>> plugin project?
Re: How to read file in a Eclipse Plugin? [message #327191 is a reply to message #327185] |
Mon, 14 April 2008 01:39 |
Errr... I c.
After setting in a preference page of Eclipse and restart Eclipse, I
find that my configuration has been saved successfully. How Eclipse do
that? It must write the info into a file but we don't know which one is it.
>> own config file ?
>> important.....
>> Ed Merks 写道:
>>> jeffty wrote:
>>>> Hi All,
>>>> Code is like this:
>>>> URL bundleRootURL =
>>>> try {
>>>> prop.load(is);
>>>> didn't work.
>>>> plugin project?
Re: How to read file in a Eclipse Plugin? [message #327209 is a reply to message #327191] |
Mon, 14 April 2008 07:41 |
On Mon, 14 Apr 2008 09:39:21 +0800, jeffty <jefftymc@yahoo.com> wrote:
> Errr... I c.
The preference settings are stored using IPreferenceStore, you can get
an instance using the AbstractUIPlugin.getPreferenceStore() method.
The data is stored in the workspace directory in a subdirectory called
".metadata". You may store data by yourself inside a directory you
created for your plug-in or you may use the preference store (no need
to use the preference dialog for this, just store your data in
key/value pairs).
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/career/eclipse.html
Achim Lörke
Re: How to read file in a Eclipse Plugin? [message #327239 is a reply to message #327209] |
Mon, 14 April 2008 13:27 |
"You may store data by yourself inside a directory you
created for your plug-in or you may use the preference store"
If what I want to load are not simple key/value paris, how to do
that? i.e. I want to read a velocity template like:
<html>
<body>
hi $name,
This is the No. &number letters.
<body>
</html>
As a matter of convenience I want to packed the template into the
plugin jar file. When eclipse load the plugin how can I read from the file?
In most cases the key/value paris that loaded from IPreferenceStore
is enough, but if a special file is needed to read inside the plugin
jar, must we use like this?
IPreferenceStore ps = AbstractUIPlugin.getPreferenceStore();
ps.setValue("template", "<html><body>hi $name,This is the No.
&number letters.<body></html>");
>> Errr... I c.
> key/value pairs).
> Achim
Re: How to read file in a Eclipse Plugin? [message #327274 is a reply to message #327239] |
Tue, 15 April 2008 06:58 |
Anyway thanks to Merks and Achim, I've learnt much from you. :)
> <html>
> <body>
> hi $name,
> <body>
> </html>
>>> Errr... I c.
>>> I find that my configuration has been saved successfully. How Eclipse
>>> do that? It must write the info into a file but we don't know which
>>> one is it.
>> key/value pairs).
>> Achim
Re: How to read file in a Eclipse Plugin? [message #327276 is a reply to message #327239] |
Tue, 15 April 2008 07:15 |
><html>
> <body>
> hi $name,
> <body>
></html>
You may create a file in the workspace .metada directory. I'm not
familiar with the API, I believe you will find it in the IResource
surroundings, see IResource.getWorkspace(). You may also use
BundleContext.getDataFile().
To read from the plugins jar you can either use the BundleClassloader
and call one of the *Resource* methods or you may use BundleFile to
get your files.
This is from memory and some brief glances at the API so please be
carefull :-)
Achim
Achim Lörke
Achim Lörke
Re: How to read file in a Eclipse Plugin? [message #327347 is a reply to message #327276] |
Wed, 16 April 2008 00:46 |
I'll try it,Thanks a lot!
>> <html>
>> <body>
>> hi $name,
>> <body>
>> </html>
> get your files.
> carefull :-)
> Achim
FUDForum. Page generated in 0.04842 seconds
