Home » Eclipse Projects » Eclipse Platform » ContentAssist dilemma--keep getting BadLocationException on an insert
ContentAssist dilemma--keep getting BadLocationException on an insert [message #326528] |
Sat, 22 March 2008 13:05  |
I have content assist implemented on my editor.
Say, I start out a very fresh document and type in "ab" then Ctrl+Space
to activate the content assist. Then I choose a proposal from the list
and it has the string "foo(a,b)" to insert.
I keep encountering the below exception from the AbstractDocument class.
the 'pos + length' is always greater than what getLength() returned,
which is 2, the length of 'ab'. Any tips? Thanks.
public void replace(int pos, int length, String text, long
modificationStamp) throws BadLocationException {
if ((0 > pos) || (0 > length) || (pos + length > getLength()))
throw new BadLocationException();
Re: ContentAssist dilemma--keep getting BadLocationException on an insert [message #326530 is a reply to message #326528] |
Sat, 22 March 2008 13:31   |
AL wrote:
Just to clarify that my insertion offset is zero, that is, attempting to
replace "ab" with "foo(a,b)".
Re: ContentAssist dilemma--keep getting BadLocationException on an insert [message #326583 is a reply to message #326559] |
Tue, 25 March 2008 14:03   |
Daniel Megert wrote:
> AL wrote:
>> Hi,
>> Ctrl+Space to activate the content assist. Then I choose a proposal
>> from the list and it has the string "foo(a,b)" to insert.
> Check that the offsets and lengths in your proposal is correct.
Double-check with debugging sessions, still something is wrong. My
replacement offset is zero, that is, positioning at the 'a' in "ab",
which is to be replaced. My replacement length is 8, which is the
length of "foo(a,b)".
And keep encountering the below exception.
> Dani
Re: ContentAssist dilemma--keep getting BadLocationException on an insert [message #326635 is a reply to message #326583] |
Wed, 26 March 2008 21:25  |
Dud! the replacement length to use is 2 NOT 8; it's the length of the
text to be replaced by the new text. I had done ContentAssist
before...Somehow misunderstood the parameter description!
Current Time: Wed Apr 16 03:41:20 EDT 2025
Powered by FUDForum. Page generated in 0.07349 seconds
