Home » Eclipse Projects » Eclipse Platform » Wizard Dialog as a View
Wizard Dialog as a View [message #325870] Fri, 29 February 2008 08:14 Go to next message
Is it possible to take an existing Wizard Dialog and implement it as an
RCP View? The requirement is to have a standalone view as a top view in
the RCP application that is basically a wizard and will always be present.
I have looked at the Wizard Dialog code and was curious if something
similar exists for Views where I can pass the Wizard as a constructor
parameter. Does anyone have an example of this or any advice as to what
direction I should go with this??? Thanks for any help in advance!!!
-Kyle
Re: Wizard Dialog as a View [message #325883 is a reply to message #325870] Fri, 29 February 2008 11:16 Go to previous message
> present. I have looked at the Wizard Dialog code and was curious if
> something similar exists for Views where I can pass the Wizard as a
> constructor parameter. Does anyone have an example of this or any advice
> as to what direction I should go with this??? Thanks for any help in
> advance!!!
I would explore the idea of making the View implement IWizardContainer -
dialogs can't be embedded in a View as far as I know.
Hope this helps,
Eric
Previous Topic:External JAR, NoClassDefFoundError
Next Topic:help not working?
Current Time: Thu Oct 23 12:50:13 EDT 2025
Powered by FUDForum. Page generated in 0.03334 seconds
