Home » Eclipse Projects » Eclipse Platform » How to get current project's name and path
How to get current project's name and path [message #322730] Tue, 27 November 2007 10:48 Go to next message
Originally posted by: noyanculum.yahoo.com
Hello all,
I'm writing a plugin for Eclipse and since somedays i'm searching how to
get current project's name and full path (i.e.
C:\...\workspace\projectname).
I've read all articles and all emails and i tried all codes given but
unfortunately no success no success.
Please kindly can anyone give me a working solution. I think i need
dependencies, import declerations lines and codeline.
Any help will be really very very appreciated.
Thanx in advance.
Best Regards,
Ran
Re: How to get current project's name and path [message #322731 is a reply to message #322730] Tue, 27 November 2007 11:03 Go to previous messageGo to next message
Ran,
IResource.getLocation()/getLocationURI() should do the trick.
Noyan Culum wrote:
> Hello all,
> to get current project's name and full path (i.e.
> Thanx in advance.
> Best Regards,
> Ran
Re: How to get current project's name and path [message #322732 is a reply to message #322731] Tue, 27 November 2007 12:01 Go to previous messageGo to next message
Ed,
Thank you but org.eclipse.core.resources.IResource don't have
getLocation() method.
I tried also
org.eclipse.core.resources.Resourcesplugin.getWorkspace().ge tRoot().getLocation()
but this give this path:
"C:\...\My Documents\runtime-EclipseApplication".
But I'm searching how to get this path:
"C:\...\My Documents\workspace".
+ additionally i'm searching how to get projectname.
Re: How to get current project's name and path [message #322735 is a reply to message #322732] Tue, 27 November 2007 13:10 Go to previous messageGo to next message
--------------080301000708020704090502
Noyan.
You mustn't be looking properly
< http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/resources/IResource.htm l#getLocation%28%29>
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/resources/IResource.htm l#getLocation()
The getName method is in that API as well.
Noyan wrote:
> Ed,
> I tried also
<html>
<head>
http-equiv="Content-Type">
</head>
Noyan.<br>
<br>
You mustn't be looking properly<a
href=" http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/resources/IResource.htm l#getLocation%28%29"><br>
</a>
<blockquote><a
href=" http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/resources/IResource.htm l#getLocation%28%29"> http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/resources/IResource.htm l#getLocation()</a><br>
</blockquote>
The getName method is in that API as well.<br>
<br>
<br>
Noyan wrote:
<blockquote
cite="mid:e59b1ae69f58802a612d53455e7c78f8$1@www.eclipse.org"
type="cite">Ed,
<br>
<br>
<br>
<br>
I tried also
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------080301000708020704090502--
Re: How to get current project's name and path [message #322744 is a reply to message #322735] Tue, 27 November 2007 16:39 Go to previous messageGo to next message
Dear Ed,
I saw, yes you have reason, there is getLocation() method here. Than i
tried different uses with this, for example:
org.eclipse.core.resources.IResource iresource;
System.out.println(iresource.getLocation());
But this returns a null response, so unfortunately, i can't find the exact
code solution with this (and others) suggestion. If you (or anotherone)
can kindly give me a working codeline, it will be really very appreciated.
Thanx again.
Ran
Re: How to get current project's name and path [message #322746 is a reply to message #322744] Tue, 27 November 2007 17:16 Go to previous messageGo to next message
Noyan,
Perhaps the resource doesn't actually exist or something else is wrong?
The getLocationURI is more general, you might try that. If these are
both returning null there's likely something going on you've not told us
about.
Noyan wrote:
> Dear Ed,
> exact code solution with this (and others) suggestion. If you (or
> anotherone) can kindly give me a working codeline, it will be really
> very appreciated.
> Thanx again.
> Ran
Re: How to get current project's name and path [message #322755 is a reply to message #322746] Wed, 28 November 2007 03:51 Go to previous messageGo to next message
Ed How i can determine IProject?
Is there a method such:
org.eclipse.core.resources.IResource iresource = new IResource(this);
Or the code below automatically detect the current selected project?
Re: How to get current project's name and path [message #322756 is a reply to message #322755] Wed, 28 November 2007 04:00 Go to previous messageGo to next message
Well because IResource is an interface this is not very likely :-)
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to get current project's name and path [message #322758 is a reply to message #322730] Wed, 28 November 2007 05:28 Go to previous messageGo to next message
Hello Ed and others,
I found the trick for workspace location. Here is my code:
org.eclipse.core.resources.ResourcesPlugin.getWorkspace().ge tRoot().getLocation()
When i run this for testing via "Launc an Eclipse Application" or "Run
Eclipse Application" buttons, it returns this location:
workspace: C:/Documents and Settings/rbt/My
Documents/runtime-EclipseApplication
But when i export it as a "Deployable Plug-in" (File->Export->Deployable
plug-ins and fragments), restart Eclipse and execute it as deployable
plugin. This time, it returns this location:
C:/Documents and Settings/rbt/My Documents/workspace
I wrote this for future researchers. I hope this help them.
NOW I HAVE STILL MY OTHER QUESTION
and it is more important now. Beause i want to obtain this path:
C:/Documents and Settings/rbt/My Documents/workspace/projectname
How can i get the project's name? I tried
org.eclipse.core.resources.ResourcesPlugin.getWorkspace().ge tRoot().getProject()
but this returns null..
Thank you in advance
Re: How to get current project's name and path [message #322764 is a reply to message #322755] Wed, 28 November 2007 08:08 Go to previous messageGo to next message
--------------030307080608090006060707
Noyan,
I get the feeling you haven't read any of the basic documentation about
Eclipse's workspace APIs. I'd suggest becoming familiar with what's
available in help:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.user/concepts/concepts-12.htm
Folks will be far more likely to answer questions if it's clearly you've
done a little bit of homework first.
<html>
<head>
</head>
Noyan,<br>
<br>
Re: How to get current project's name and path [message #322765 is a reply to message #322758] Wed, 28 November 2007 08:12 Go to previous messageGo to next message
Noyan,
Good, you've done some homework.
> (File->Export->Deployable plug-ins and fragments), restart Eclipse and
> execute it as deployable plugin. This time, it returns this location:
This will always reflect where the workspace itself is located. Project
will not necessarily be physically nested within that folder since when
a project is created you can specify anywhere in the file system at
which to locate it.
You really need to read some basic information. To root itself is not
in a project and projects cannot nest. If you look at the API for
IWorkspaceRoot you'll see methods like getProject(String) and
getProjects. Please try to use the Javadoc to help answer your questions...
Re: How to get current project's name and path [message #322769 is a reply to message #322765] Wed, 28 November 2007 08:55 Go to previous messageGo to next message
> You really need to read some basic information. To root itself is not in a
> IWorkspaceRoot you'll see methods like getProject(String) and getProjects.
Dear Ed,
Do you know how i can get the selected project's name? or do you not?
However i have to thank you for all your kindly responses..
Best Regards,
Noyan
Re: How to get current project's name and path [message #322770 is a reply to message #322769] Wed, 28 November 2007 08:57 Go to previous messageGo to next message
Noyan,
Do you already have the selected project in hand? If not, it becomes
important to understand where you will expect this to come from...
>> not in a project and projects cannot nest. If you look at the API for
>> questions...
> Dear Ed,
> Best Regards,
> Noyan
Re: How to get current project's name and path [message #322772 is a reply to message #322765] Wed, 28 November 2007 09:07 Go to previous messageGo to next message
Dear Ed,
Do you know how to get the name of the selected project? Or do you not?
However, i thank you for all your kindly responses.
Best Regards,
Noyan
Re: How to get current project's name and path [message #322775 is a reply to message #322772] Wed, 28 November 2007 09:26 Go to previous messageGo to next message
Noyan,
You seem to have repeated your question... Of course the answer is you
call IProject.getName, but I think you are asking about how to get "the
selected project" but you've not provided any context in which to answer
that. The IDE is full of views and can even have multiple windows, so
you'll need to narrow down the context of your question for anyone to be
able to answer it...
>> for IWorkspaceRoot you'll see methods like getProject(String) and
>> questions...
> Dear Ed,
> Best Regards,
> Noyan
Re: How to get current project's name and path [message #520370 is a reply to message #322730] Fri, 12 March 2010 01:51 Go to previous messageGo to next message
Hi Noyan,
I have an novice user to eclipse PDE. Currently I am developing one plugin. In this pluging I am generating some java classes.
This is done by Wizard.
Wizard asks some question and in the end it executes the command.
So
1) Before executing the wizard i want to check whether the workspace contains any project of not? If no project then Error message.
2) If their are some projects in the workspace then which is the current active project? I mean if instead of clicking on the Project Tree if user directly invokes the Wizard from toolbar then to which project I should add those classes? I mean is their any concept like active project or main project? If yes then how to get the main project?
Can you help me in above 2 scenarios(What hooks and where they should be added)?
This is the code of execute method of command
public Object execute(ExecutionEvent event) throws ExecutionException {
MySupportWizard wizard = new MySupportWizard();
WizardDialog dialog = new WizardDialog(HandlerUtil.getActiveShell(event), wizard);
dialog.open();
return null;
sHrik
Re: How to get current project's name and path [message #523086 is a reply to message #520370] Wed, 24 March 2010 20:43 Go to previous message
Hi Shrikant,
Did you find what you were looking for...?
I am somewhat looking for the same thing...
Rohit
Previous Topic:Debug JUnit test multiple times - automation? parameters?
Next Topic:Dragging around views on secondary monitor doesn't display placement hints
Current Time: Sun Oct 19 02:07:06 EDT 2025
Powered by FUDForum. Page generated in 0.07053 seconds
