Re: Global Preferences in 3.3? [message #321623 is a reply to message #321601] |
Tue, 23 October 2007 06:21 |
Originally posted by: wharley.bea.com
"Miles Daffin" <miles.daffin@morganstanley.com> wrote in message
news:4830a752ecdff23c6590fb4d308f70b9$1@www.eclipse.org...
> Can anyone tell me if it is possible to provide global (as opposed to
> workspace scope) preferences in eclipse 3.3? [...]
> Previously I achieved this using the -plugincustomization argument but
> this was not very convenient.
AFAIK, -plugincustomization is still the only means. It sure would be nice
to have something more efficient.
Re: Global Preferences in 3.3? [message #321638 is a reply to message #321601] |
Tue, 23 October 2007 13:35 |
Originally posted by: klammer.utanet.at
Miles Daffin schrieb:
> Folks,
> workspace scope) preferences in eclipse 3.3? And by this I mean is it
> possible to configure an eclipse 3.3 install in such a way that each
> workspace starts out with the same set of defaults?
> Context: I am trying to create an install for my company that points to
> the right update policy and uses the 'right' code style etc. out of the
> box (no preferences import necessary). Previously I achieved this using
> the -plugincustomization argument but this was not very convenient. I
> had to configure my preferences, export them, and strip some stuff from
> the resulting epf which is then referenced by the above command line
> argument.
> Miles
We are dealing with the same problem. For now there seems to be no
mature solution. What we are doing is to use the 'configuration' scope
as storage for global settings and copy them at startup over the
appropriate 'instance' settings.
If you can use an IPreferenceStore instance it should be possible to
configure the scope context to use the configuration scope for
preference lookups too.
Let me know if you find a more suitable solution.
claus
Re: Global Preferences in 3.3? [message #321701 is a reply to message #321689] |
Wed, 24 October 2007 16:07 |
Originally posted by: eclipse6.rizzoweb.com
Miles Daffin wrote:
> I recall someone telling me, on this forum, that global preferences were
> on the plan for 3.3. Ideally (I suppose) one would want the following
> scopes:
> 1) Global - apply as defaults to all workspaces/projects
> 2) Workspace - apply as defaults for all projects in the workspace
> 3) Project - apply just to the project
> In practice 1 & 2 would suffice.
2 and 3 are already provided. It is 1 that is not there yet.
Eric
FUDForum. Page generated in 0.03638 seconds
