Native windows dll access problem from PlugIn [message #318496] |
Tue, 31 July 2007 07:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: pzabawa.poczta.onet.pl
I would like to make use of sun JNA library to communicate to my C++ dll.
The communication works perfectly when I load and call the dll from a Java
project (Java Application). However when I do the same from my Eclipse
PlugIn the library does not load and the plugin hungs during this process.
What shall I do step by step to be able both to load dll and call
functions from it from Eclispe PlugIn?
Thank you in advance.
Piotr
Re: Native windows dll access problem from PlugIn [message #318505 is a reply to message #318496] |
Tue, 31 July 2007 11:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Piotr,
You posted this same question on the SWT newsgroup separately. Please
don't do that. If you must post to multiple newsgroups, please do so
with a single posting addressed to all the groups so that an answer on
one group appears on all groups. Someone already tried to answer your
question on the other newsgroup...
> dll. The communication works perfectly when I load and call the dll
> from a Java project (Java Application). However when I do the same
> from my Eclipse PlugIn the library does not load and the plugin hungs
> during this process. What shall I do step by step to be able both to
> load dll and call functions from it from Eclispe PlugIn?
> Piotr
Re: Native windows dll access problem from PlugIn [message #319623 is a reply to message #318496] |
Tue, 28 August 2007 12:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: gerold.broser.easyklick.com
Piotr:
> dll. The communication works perfectly when I load and call the dll from
> a Java project (Java Application). However when I do the same from my
> Eclipse PlugIn the library does not load and the plugin hungs during
> this process. What shall I do step by step to be able both to load dll
> Piotr
Hi Piotr,
1. It is called JNI (Java Native Interface ;)
2. A C wrapper DLL is useful, since it is like Matthew mentioned: the functions have to be named specially. I created a
separate Eclipse C project to create this DLL.
3. One (or more) Java wrapper class(es) is/are helpful, since the function names in the C wrapper DLL are derived from
the package structure + wrapper class name + method name + arguments. I put the Java wrapper class(es) in a separate
Eclipse plugin project, and defined this project as dependency of my main plugin project.
4. http://java.sun.com/docs/books/jni/html/preface.html and http://www.codeproject.com/java/jnibasics1.asp are good
starting points.
Regards, and good luck!
Geri
FUDForum. Page generated in 0.02895 seconds
