Home » Eclipse Projects » Eclipse Platform » Add jar for plugin dynamically
Add jar for plugin dynamically [message #317632] Tue, 10 July 2007 14:02 Go to next message
In order to run a plugin I am writing, I need to reference a jar that cannot
be shipped with the plugin. I need to reference it on the fly after the
plugin is loaded.
How can I do that?
Re: Add jar for plugin dynamically [message #317641 is a reply to message #317632] Tue, 10 July 2007 18:26 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Get them to ship it as a plugin, and then depend on that :-)
Alex.
Re: Add jar for plugin dynamically [message #317650 is a reply to message #317632] Wed, 11 July 2007 07:20 Go to previous messageGo to next message
> plugin is loaded.
> How can I do that?
As Alex said, if you can get them to create an OSGi MANIFEST for their
jar, then you could just use it :-)
2 other solutions that come to mind: 1) have your installer create a
plugin and copy the jar into it for use. If you do it as part of your
install, then you won't have to worry about dynamically updating
classpaths and stuff. 2) create the plugin and use the external:
modifier in the Bundle-ClassPath header, like
external:/opt/local/libs/log4j-1.0.0.jar
Later,
PW
Re: Add jar for plugin dynamically [message #317662 is a reply to message #317650] Wed, 11 July 2007 09:16 Go to previous message
(Be aware that the external: support is something specific to Equinox, not an OSGi thing).
One last idea; distribute a placeholder plugin as an expanded directory with a Bundle-ClassPath: .,external.jar, and then ask the users upon installation to put the 'external.jar' into your expanded bundle directory. That would just work.
You could configure an activator to try and load the class, so you'd know if they'd done it properly or not.
Alex.
Previous Topic:Event context
Next Topic:ProgressMonitorDialog in background
Current Time: Tue Nov 04 08:29:43 EST 2025
Powered by FUDForum. Page generated in 0.44574 seconds
