Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Cannot import device
Cannot import device [message #31628] Thu, 02 July 2009 08:32 Go to next message
I've used EclipseME in the past with Eclipse 3.4 and with those versions I
was able to program for a Siemens TC65T. I decided to give Eclipse 3.5 a
try with MJT 1.0. Everything installed fine. I tried to import the Siemens
WTK, the one that worked with my previous setup, but it fails to find any
device. What can I do to figure out what is wrong and how can I fix it?
Re: Cannot import device [message #31699 is a reply to message #31628] Thu, 02 July 2009 13:21 Go to previous messageGo to next message
mtj can import any UEI compliant SDK. maybe this sdk that you mention is
no UEI compliant. can you send a link to where we can download this sdk?
i remember that an old eclipseme version has a specific handling to a
siemens sdk, but i think that this was removed later from eclipseme itself
and then from mtj.
if you can send the link we can at least investigate to see if there is
problem with it
gep
Re: Cannot import device [message #31739 is a reply to message #31699] Thu, 02 July 2009 16:25 Go to previous messageGo to next message
I couldn't load devices from SMTK with MTJ too.
I've used SMTK from here http://www.siemens-club.ru/soft-emul.php
First of all I've installed
http://download.siemens-club.ru/files/smtk/smtk_2_00_3b.exe and then
http://download.siemens-club.ru/files/smtk/S65_11_119_41.exe and
http://download.siemens-club.ru/files/smtk/S65_11_119_41_pat ch.exe
Problem is MTJ doesn't see any devices in SMTK directory at all.
Pls, fix this problem or, at least, advice your SMTK version which is
compatible with MTJ
Re: Cannot import device [message #31773 is a reply to message #31739] Fri, 03 July 2009 16:40 Go to previous messageGo to next message
Hi Andrey,
is the SMTK an official Siemens SDK??
Re: Cannot import device [message #31808 is a reply to message #31773] Sat, 04 July 2009 12:10 Go to previous messageGo to next message
Sure.
SMTK is Siemens Mobile ToolKit for 6x series and MTK for 7x series mobile
phones. Also see this
http://www.eclipse.org/dsdp/mtj/development/tutorial/support ed.php
Re: Cannot import device [message #31842 is a reply to message #31699] Mon, 06 July 2009 04:21 Go to previous messageGo to next message
I've been trying to find a link to the SMTK I have. I have been unable to
find it. I've also not been able to find the version number. All I can
tell you is that it came on the CD that came with my TC65T. The CD refers
to it as "Siemens Mobility Toolkit (SMTK) for Java(TM) enabled
GSM/GPRS-module". I hope this helps.
Re: Cannot import device [message #31975 is a reply to message #31808] Thu, 09 July 2009 09:20 Go to previous messageGo to next message
hi guys,
i just did some investigation on this sdk. This SDK is not UEI compliant.
thats why it is not imported on MTJ. Eclipse 1.5.0 used to support it, but
the support was removed on later version, since new siemens SDKs were
already UEI compliant.
we raised the issue on MTJ developers list to see if anyone is interested
to add this sdk support to MTJ.
in the meantime, i assume that the only way to use it is to go back to
eclipseme 1.5
gep
PS.: that URL with the list of supported sdks is quite old and need to be
updated. sorry for the confusion. MTJ supports: UEI compliant SDKs (nokia
seria 40, motorola, sonyercisson, samsung, sprint, wtk) and javase based
sdks (microemu and mpowser player).
Re: Cannot import device [message #32010 is a reply to message #31975] Fri, 10 July 2009 02:32 Go to previous messageGo to next message
I have currently installed Eclipse 3.5 with EclipseME 1.7.9 and it works
(as far as I can tell).
Re: Cannot import device [message #32045 is a reply to message #31975] Fri, 10 July 2009 17:26 Go to previous messageGo to next message
Thanks for answer ;(
And what SMTK versions does MTJ support? Probably, I'll be use one of
correctly supported SMTK version...
Re: Cannot import device [message #32251 is a reply to message #32045] Mon, 13 July 2009 10:10 Go to previous messageGo to next message
MTJ will support any version that is UEI compliant. i really don't know
which siemens sdk is UEI compliant :( sorry for answer.
if you really need to use then probably the only way to do it now is to go
back to eclipseme.
gep
Re: Cannot import device [message #467854 is a reply to message #32251] Mon, 03 August 2009 04:06 Go to previous messageGo to next message
Can anyone tell me of the S60 3rd edition SDK with FP1 is compatible with
MTJ 1.0?
I'm having trouble importing that device. I need that device because it
is the only one that I know (someone please let me know if there are
others) that works with eclipse and plays MP3 files.
Re: Cannot import device [message #468063 is a reply to message #467854] Mon, 03 August 2009 17:11 Go to previous messageGo to next message
S60 FP1 SDK is a bit problematic at the moment. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278171 for details
> with MTJ 1.0?
Re: Cannot import device [message #468433 is a reply to message #468063] Wed, 05 August 2009 10:18 Go to previous messageGo to next message
I've sent a patch with a possible solution for importing this SDK, but i
need someone to test it before i commit to SVN.
Re: Cannot import device [message #480076 is a reply to message #468433] Thu, 13 August 2009 13:08 Go to previous messageGo to next message
I was trying to apply your patches ... unfortunately on the last release (1393 ???) some packages havebeen moved and the whole project org.eclipse.mtj.toolkit.nokia is empty.
If you send me the jar files I would be happy to test your patches.
cheers.
Re: Cannot import device [message #480086 is a reply to message #480076] Thu, 13 August 2009 14:03 Go to previous messageGo to next message
I fixed the problems in the repository. I believe you may now be able to
apply the patch.
Diego
Re: Cannot import device [message #480584 is a reply to message #480086] Mon, 17 August 2009 14:05 Go to previous message
The patch was integrated. The fix was not the best solution, but it works.
We have some problems when trying to run the emulator that will be fixed
on bug 273720 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=273720)
Re: Cannot import device [message #574374 is a reply to message #31628] Thu, 02 July 2009 13:21 Go to previous message
and then from mtj.
problem with it
gep
Re: Cannot import device [message #574400 is a reply to message #31699] Thu, 02 July 2009 16:25 Go to previous message
compatible with MTJ
Re: Cannot import device [message #574424 is a reply to message #31739] Fri, 03 July 2009 16:40 Go to previous message
Hi Andrey,
Re: Cannot import device [message #574446 is a reply to message #31773] Sat, 04 July 2009 12:10 Go to previous message
Sure.
Re: Cannot import device [message #574473 is a reply to message #31699] Mon, 06 July 2009 04:21 Go to previous message
Re: Cannot import device [message #574563 is a reply to message #31808] Thu, 09 July 2009 09:20 Go to previous message
hi guys,
eclipseme 1.5
gep
Re: Cannot import device [message #574577 is a reply to message #31975] Fri, 10 July 2009 02:32 Go to previous message
Re: Cannot import device [message #574596 is a reply to message #31975] Fri, 10 July 2009 17:26 Go to previous message
Re: Cannot import device [message #574755 is a reply to message #32045] Mon, 13 July 2009 10:10 Go to previous message
back to eclipseme.
gep
Re: Cannot import device [message #575484 is a reply to message #32251] Mon, 03 August 2009 04:06 Go to previous message
MTJ 1.0?
Re: Cannot import device [message #575599 is a reply to message #467854] Mon, 03 August 2009 17:11 Go to previous message
> with MTJ 1.0?
Re: Cannot import device [message #575649 is a reply to message #468063] Wed, 05 August 2009 10:18 Go to previous message
Re: Cannot import device [message #575727 is a reply to message #468433] Thu, 13 August 2009 13:08 Go to previous message
cheers.
Re: Cannot import device [message #575747 is a reply to message #575727] Thu, 13 August 2009 14:03 Go to previous message
apply the patch.
Diego
Re: Cannot import device [message #575815 is a reply to message #480086] Mon, 17 August 2009 14:05 Go to previous message
Previous Topic:MIDP Emulator is empty
Next Topic:Avoid showing errors in editor that are caused because of preprocessed directives
Current Time: Wed Apr 16 03:37:05 EDT 2025
Powered by FUDForum. Page generated in 0.05825 seconds
