| resource loading [message #314211] |
Wed, 04 April 2007 18:22  |
I have a file in my plugin that I am trying to read. I am using
getClass().getResource() to load the file but always get
NullPointerException. What's the input string to getResource() should be
to correctly identify the file? I am trying to pass the whole package
path to the file, but nothing works.
thanks,
Alex
| Re: resource loading [message #314245 is a reply to message #314231] |
Thu, 05 April 2007 10:32   |
Thanks Ed,
Right, the file that is in the same package as executing class I can
get, but I meant file in the plugin's root directory:
com.ak.myplugin:
src
xslt
file.xslt
I want to read file.xslt from class in src directory.
Also, when I create file from with the executing class' directory:
URL url = this.getClass().getResource("file.xslt");
File file = new File(url.toString());
I get file with path:
bundleresource:\1187\com\ak\wizard\file.xslt
Then, when I try to read this file using BufferedReader, the file cannot
be found.
thanks,
Alex
Ed Merks wrote:
> Alex,
> Most often you'd use a path that doesn't start with "/" to look up the
> resource in the same folder as the .class file itself.
> Aleksandr Krvavets wrote:
>> Hello,
>> be to correctly identify the file? I am trying to pass the whole
>> package path to the file, but nothing works.
>> thanks,
>> Alex
| Re: resource loading [message #314254 is a reply to message #314245] |
Thu, 05 April 2007 11:42  |
Alex,
I think you'd use this.getClass().getResource("/file.xslt") but you
can't assume that the URL that comes back is a file: URL. It could be a
jar, or as you see, an OSGi-specific scheme. Can't you use
URL.openStream directly? You could also use a URL of the form
platform:/plugin/<plugin-ID>/file.xslt directly and open the stream for
that.
> Thanks Ed,
> com.ak.myplugin:
> src
> xslt
> file.xslt
> cannot be found.
> thanks,
> Alex
> Ed Merks wrote:
>> Alex,
>> the resource in the same folder as the .class file itself.
>>> Hello,
>>> should be to correctly identify the file? I am trying to pass the
>>> whole package path to the file, but nothing works.
>>> thanks,
>>> Alex
FUDForum. Page generated in 0.04585 seconds
