Home » Eclipse Projects » Eclipse Platform » instantiating a class from another plugin
instantiating a class from another plugin [message #307756] Wed, 30 August 2006 13:51 Go to next message
Originally posted by: vik_ram.hotmail.com
Is it possible to instantiate a class from another plugin without
defining a dependency on that plugin.
The way our product is bundled is that we may ship plugin A alone OR
plugin A and plugin B. plugin B depends on plugin A but plugin A can run
independently. We want to define a documentProvider common to both
plugins - so we define it in plugin A. The problem is that the
documentProvider class should be able to invoke classes in both A and B
depending on certain criteria ( strategy pattern ) . But as it is
defined in plugin A , it cannot instantiate classes in plugin B.
Vikram
Re: instantiating a class from another plugin [message #307758 is a reply to message #307756] Wed, 30 August 2006 14:06 Go to previous messageGo to next message
That's what extensions are for.
See:
http://www.eclipse.org/articles/Article-Plug-in-architecture /plugin_architecture.html#3.
Rich Kulp
Re: instantiating a class from another plugin [message #307759 is a reply to message #307756] Wed, 30 August 2006 14:08 Go to previous messageGo to next message
vikram wrote:
That is the most common use for the extension points/extensions.
ex: plugin A creates a "document provider" extension point and the
interface class, com.example.text.IDocumentProvider. If it also comes
with a document provider, plugin A implements the extension as well:
<documentProvider name="MyDocs"
class="com.example.a.text.MyDocsProvider"/>
Then plugin B creates the extension for its document provider:
<documentProvider name="RedDocs"
class="com.example.b.text.RedDocsProvider"/>
In plugin A, your extension point processing code walks through
IConfigurationElements ... you can use
createExecutableExtension("class") to instantiate a document provider,
and never have to depend on its plugin.
Later,
PW
Re: instantiating a class from another plugin [message #307760 is a reply to message #307756] Wed, 30 August 2006 14:30 Go to previous messageGo to next message
Vikram,
I agree with Rich's good advice.
But here's a way you could load classes without using an extension point.
Bundle xsdPlugin = Platform.getBundle("org.eclipse.xsd");
if (xsdPlugin != null)
try
Class theGeneratorClass =
xsdPlugin.loadClass
("org.eclipse.xsd.ecore.Ecore" + type + "SchemaBuilder");
vikram wrote:
> run independently. We want to define a documentProvider common to
> both plugins - so we define it in plugin A. The problem is that the
> B depending on certain criteria ( strategy pattern ) . But as it is
> Vikram
Re: instantiating a class from another plugin [message #307761 is a reply to message #307760] Wed, 30 August 2006 15:05 Go to previous message
Rich, Paul and Ed,
Thanks for the responses.
Ed Merks wrote:
> Vikram,
> try
> xsdPlugin.loadClass
> vikram wrote:
>> Hi,
>> Thanks,
>> Vikram
Previous Topic:Common Navigator Framework
Next Topic:Monitor build status
Current Time: Sun Oct 26 17:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.04720 seconds
