instantiating a class from another plugin [message #307756] |
Wed, 30 August 2006 13:51  |
Originally posted by: vik_ram.hotmail.com
Is it possible to instantiate a class from another plugin without
defining a dependency on that plugin.
The way our product is bundled is that we may ship plugin A alone OR
plugin A and plugin B. plugin B depends on plugin A but plugin A can run
independently. We want to define a documentProvider common to both
plugins - so we define it in plugin A. The problem is that the
documentProvider class should be able to invoke classes in both A and B
depending on certain criteria ( strategy pattern ) . But as it is
defined in plugin A , it cannot instantiate classes in plugin B.
Vikram
Re: instantiating a class from another plugin [message #307761 is a reply to message #307760] |
Wed, 30 August 2006 15:05  |
Rich, Paul and Ed,
Thanks for the responses.
Ed Merks wrote:
> Vikram,
> I agree with Rich's good advice.
> But here's a way you could load classes without using an extension point.
> Bundle xsdPlugin = Platform.getBundle("org.eclipse.xsd");
> if (xsdPlugin != null)
> try
> Class theGeneratorClass =
> xsdPlugin.loadClass
> ("org.eclipse.xsd.ecore.Ecore" + type + "SchemaBuilder");
> vikram wrote:
>> Hi,
>> run independently. We want to define a documentProvider common to
>> both plugins - so we define it in plugin A. The problem is that the
>> B depending on certain criteria ( strategy pattern ) . But as it is
>> Thanks,
>> Vikram
FUDForum. Page generated in 7.32615 seconds
