ResourceNavigator [message #301586] |
Mon, 03 April 2006 05:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: marek.dabrowski.interia.pl
Hello
I would like use navigator view to represent my data. In help system I
found that org.eclipse.ui.views.navigator has class ResourceNavigator
which one I can use it for that, but when I try import
org.eclipse.ui.views.navigator Eclipse don't know what it's. In manifest
dependencies I added or.eclise.ui.views.
What do I wrong?
Marek
Re: ResourceNavigator [message #301594 is a reply to message #301586] |
Mon, 03 April 2006 07:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Marek Dabrowski napisał(a):
> Hello
> What do I wrong?
> Regards
> Marek
I explain what I would like to do with ResoruceNavigator - I write
program to manage network devices like hub, servers, switches. That
resources I would like put to ResourceNavigator. Mabey my idea is wrong,
mabey I should create my view to represent this data?
Re: ResourceNavigator [message #301598 is a reply to message #301594] |
Mon, 03 April 2006 07:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
>> Hello
>> manifest dependencies I added or.eclise.ui.views.
>> What do I wrong?
Sorry. I found solution - dependencies org.eclipse.ui.ide.
>> Regards
>> Marek
But this question is still active.
Re: ResourceNavigator [message #301628 is a reply to message #301622] |
Mon, 03 April 2006 14:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Michael Valenta napisał(a):
> Marek,
> If yu're using 3.2, you probably want to look at the Common Navigator
> framework in the org.eclipse.ui.navigator plugin. An example of how to
> use it can be found in the org.eclipse.ui.navigator.resources plugin.
Michael, forgive me I'm completly noob in eclipse ...
Could you give me link for org.eclipse.ui.navigator.resources examples?
FUDForum. Page generated in 0.04137 seconds
