Home » Eclipse Projects » Eclipse Platform » Creating/forking a new process/thread in eclipse
Creating/forking a new process/thread in eclipse [message #295169] Fri, 25 November 2005 03:41 Go to next message
hi,
I want to run a process of indexing a database when i click on an
action.How do i create a new thread/process using the eclipse api, should
I be using the "jobs API" or make it run in a class that implements
"Runnable"
Which one is a better approach or are there any other better methods...
thanks
Vijai
Re: Creating/forking a new process/thread in eclipse [message #295172 is a reply to message #295169] Fri, 25 November 2005 06:33 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Using a job is better, because (a) the user can see it is happening, and (b) they have control of killing it off if necessary. You can change the priority of the job so that it is a low priority (so that others can overtake it). Your action then becomes launching the job.
http://help.eclipse.org/help30/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/runtime_jobs.htm
Re: Creating/forking a new process/thread in eclipse [message #295360 is a reply to message #295169] Mon, 28 November 2005 17:32 Go to previous message
Originally posted by: john.eclipsefaq.org
I highly recommend this article on jobs from eclipse.org:
http://www.eclipse.org/articles/Article-Concurrency/jobs-api .html
Vijai wrote:
> hi,
> should I be using the "jobs API" or make it run in a class that
> implements "Runnable"
> thanks
> Vijai
Previous Topic:3.1 Help stopped opening, HTTP 500 server error. Tomcat problem?
Next Topic:find out the Eclipse version
Current Time: Mon Oct 20 22:18:02 EDT 2025
Powered by FUDForum. Page generated in 0.06359 seconds
