Home » Eclipse Projects » Eclipse Platform » Ant wants a JAVA_HOME or com.sun.tools.javac.Main class.....
- Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #28748] Thu, 08 May 2003 03:23 Go to next message
Originally posted by: pismute.doit.ajou.ac.kr
I'm trying to build a project by running Ant from inside Eclipse. All I get
is the following error-message:
[javac] BUILD FAILED: file:D:/System/http/build.xml:162: Unable to
find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
I'm using W2K, JDK1.4.2, eclipse2.1
Where to set JAVA_HOME? Nothing works, neither setting the environment-var
in Eclipse (Preferences - Java - Classpath variables) nor setting it in W2K
Workspace.
Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #28790 is a reply to message #28748] Thu, 08 May 2003 10:07 Go to previous messageGo to next message
You do not need to set JAVA_HOME it is not used in this context.
You need to add a jdk tools.jar to the Ant runtime classpath using the Ant
preference pages.
Are you sure you are starting Eclipse with JDK 1.4.2?
If you start Eclipse using the -vm arg so that Eclipse is launched using
your JDK install VM, Eclipse will automatically add the tools.jar to the Ant
runtime classpath.
HTH
Darins
"ChangWoo Park" <pismute@doit.ajou.ac.kr> wrote in message
news:b9d0k5$chj$1@rogue.oti.com...
get
W2K
> Workspace.
> Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #28826 is a reply to message #28790] Thu, 08 May 2003 13:05 Go to previous messageGo to next message
I'm having the problem even though I did add JDK's tools.jar to Ant's
runtime classpath. It seems that fix is not working and you would need to
start Eclipse in JDK VM to get Ant to work (compile Java files).
Jerry
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:b9do9e$vm2$1@rogue.oti.com...
> preference pages.
Ant
> runtime classpath.
> HTH
> Darins
> get
to
environment-var
> W2K
> > Workspace.
> > Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #28834 is a reply to message #28826] Thu, 08 May 2003 14:27 Go to previous messageGo to next message
Exactly how did you add the JDK's tools.jar to the Ant runtime classpath?
We did have https://bugs.eclipse.org/bugs/show_bug.cgi?id=36574
Darins
"Jerry III" <jerryiii@hotmail.com> wrote in message
news:b9e2p4$9kb$1@rogue.oti.com...
> Jerry
Ant
> > preference pages.
> Ant
> > runtime classpath.
> > HTH
> > Darins
I
> > get
> to
> environment-var
in
> > W2K
> > > Workspace.
> > > Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #29301 is a reply to message #28834] Thu, 08 May 2003 18:08 Go to previous messageGo to next message
Originally posted by: magellan94.hotmail.com
Is it possible to configure ANT to use a JRE other than the one used to
launch eclipse? I get a related error when I run a build script from
eclipse:
[javac] E:\mydocs\projects\main\peso\src\com\oxygen\wms\proposal\Pro posal
Bo.java:41: cannot access java.lang.Object
[javac] bad class file: E:\java\j2sdk1.4.2\jre\lib\rt.jar(java/lang/Objec
t.class)
[javac] class file has wrong version 48.0, should be 47.0
[javac] Please remove or make sure it appears in the correct subdirectory
of the classpath.
I need for ant to use rt.jar and tools.jar from JDK 1.3, but I use JDK 1.4
to run eclipse.
Dave
news:b9e7hp$dji$1@rogue.oti.com...
> Darins
to
> > Jerry
> Ant
> > > preference pages.
using
the
> > Ant
> > > runtime classpath.
> > > HTH
> > > Darins
All
> I
> > > get
Unable
> > to
> > environment-var
> in
> > > W2K
> > > > Workspace.
> > > > Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #29487 is a reply to message #29301] Thu, 08 May 2003 20:32 Go to previous messageGo to next message
Dave,
You have a few options open to you:
Take the latest Eclipse integration builds where you can specify the JRE
used to launch Ant (run Ant in a separate VM).
This is still a work in progress..see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24129
You can specify the source and target using the appropriate attributes
on the javac task
For example <javac target="1.3" source="1.4" ...
HTH
Darins
"Dave Smith" <magellan94@hotmail.com> wrote in message
news:b9ekki$nl4$1@rogue.oti.com...
> eclipse:
> t.class)
> of the classpath.
> to run eclipse.
> Dave
classpath?
> > Darins
> to
> > > Jerry
the
> > Ant
> > > > preference pages.
> using
> the
> > > Ant
> > > > runtime classpath.
> > > > HTH
> > > > Darins
> All
> > I
> > > > get
> Unable
> > > to
> > > environment-var
it
> > in
> > > > W2K
> > > > > Workspace.
> > > > > Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #29687 is a reply to message #29487] Fri, 09 May 2003 15:51 Go to previous messageGo to next message
Thanks, Darin. Do you know when eclipse plans to release a milestone drop?
The eclipse 2.2 project plan had a drop scheduled for May 2nd, and if it's
coming in the next few days I'll wait for it. Otherwise I'll grab the
integration build.
Dave
news:b9esta$s5e$1@rogue.oti.com...
> Dave,
JRE
> on the javac task
> HTH
> Darins
> > eclipse:
> > [javac]
> > t.class)
subdirectory
> > of the classpath.
1.4
> > to run eclipse.
> > Thanks,
> > Dave
> classpath?
> > > Darins
Ant's
need
> > to
> > > > Jerry
> the
> > > Ant
> > > > > preference pages.
> > using
to
> > the
> > > > Ant
> > > > > runtime classpath.
> > > > > HTH
> > > > > Darins
Eclipse.
> > All
> > > I
> > > > > get
> > Unable
> > > > to
> > > > environment-var
setting
> it
> > > in
> > > > > W2K
> > > > > > Workspace.
> > > > > > Any suggestions?
- Re: Ant wants a JAVA_HOME or com.sun.tools.javac.Main class..... [message #29689 is a reply to message #29687] Fri, 09 May 2003 15:56 Go to previous message
I have not heard of a date for the next milestone.
Darins
news:b9h103$7rm$1@rogue.oti.com...
> integration build.
> Dave
> > Dave,
> JRE
attributes
> > on the javac task
> > HTH
> > Darins
to
> > > eclipse:
> > > [javac]
> > > t.class)
> subdirectory
> > > of the classpath.
> 1.4
> > > to run eclipse.
> > > Thanks,
> > > Dave
> > classpath?
> > > > Darins
> Ant's
> need
> > > to
> > > > > Jerry
using
> > the
> > > > Ant
> > > > > > preference pages.
launched
> > > using
tools.jar
> to
> > > the
> > > > > Ant
> > > > > > runtime classpath.
> > > > > > HTH
> > > > > > Darins
> Eclipse.
> > > All
> > > > I
> > > > > > get
> > > Unable
> > > > > to
> > > > > environment-var
> setting
> > it
> > > > in
> > > > > > W2K
> > > > > > > Workspace.
> > > > > > > Any suggestions?
Previous Topic:Changing Package Explorer View
Next Topic:Deployable plug-ins and fragments + JARS -
Current Time: Tue Apr 29 23:02:40 EDT 2025
Powered by FUDForum. Page generated in 0.04927 seconds
